Hi
I try to customize Jetson’s TX2 flashing process to support our motherboard and I’ve missed description between module’s revision encoded into the its serial number (xxx-BOO E.0 as an example) and configuration files used by flash.sh et al: revision A00 hardcoded everywhere. May someone explain me and/or point to the correlation between file’s revision numbers and board’s revisions?
I.e. the file bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb correspond to the board’s revision A00, or something else? Also may be somewhere exist the document described differences between file tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb and tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb? If yes, may someone share it with me?
