Hi! I have problem with runnig cuPHYController on out GH200 server. The text below is the result log of “sudo -E ./cuphycontroller_scf F08_CG1”. In summary, I have repeated kernel timeout error on slots. Can you find some problem on the result log?
Started cuphycontroller on CPU core 70
AERIAL_LOG_PATH unset
Using default log path
Log file set to /tmp/phy.log
Aerial metrics backend address: 127.0.0.1:8081
05:41:45.003763 WRN phy_init 0 [CTL.SCF] Config file: /opt/nvidia/cuBB/cuPHY-CP/cuphycontroller/config/cuphycontroller_F08_CG1.yaml
05:41:45.004388 WRN phy_init 0 [CTL.SCF] low_priority_core=23
05:41:45.005824 WRN phy_init 0 [NVLOG.CPP] Using /opt/nvidia/cuBB/cuPHY/nvlog/config/nvlog_config.yaml for nvlog configuration
YAML invalid key: enable_l1_param_sanity_check Using default value of 0 to YAML_PARAM_ENABLE_L1_PARAM_SANITY_CHECK
YAML invalid key: ul_order_max_rx_pkts Using default value of 0 to UL_ORDER_MAX_RX_PKTS
YAML invalid key: pusch_nMaxLdpcHetConfigs Using default value of 32 to PUSCH-N-MAX-LDPC-HET-CONFIGS
05:41:45.017391 ERR phy_init 0 [AERIAL_CONFIG_EVENT] [CTL.YAML] cuphycontroller config. yaml does not have cpu_init_comms key; defaulting to 0.
05:41:45.017543 WRN phy_init 0 [CTL.YAML] cell_id 1 nic_index :0
05:41:45.017648 WRN phy_init 0 [CTL.YAML] Num Slots: 8
05:41:45.017648 WRN phy_init 0 [CTL.YAML] Enable UL cuPHY Graphs: 1
05:41:45.017648 WRN phy_init 0 [CTL.YAML] Enable DL cuPHY Graphs: 1
05:41:45.017648 WRN phy_init 0 [CTL.YAML] Accurate TX scheduling clock resolution (ns): 500
05:41:45.017648 WRN phy_init 0 [CTL.YAML] DPDK core: 23
05:41:45.017649 WRN phy_init 0 [CTL.YAML] Prometheus core: -1
05:41:45.017649 WRN phy_init 0 [CTL.YAML] UL cores:
05:41:45.017649 WRN phy_init 0 [CTL.YAML] - 5
05:41:45.017649 WRN phy_init 0 [CTL.YAML] - 6
05:41:45.017650 WRN phy_init 0 [CTL.YAML] DL cores:
05:41:45.017650 WRN phy_init 0 [CTL.YAML] - 11
05:41:45.017650 WRN phy_init 0 [CTL.YAML] - 12
05:41:45.017650 WRN phy_init 0 [CTL.YAML] - 13
05:41:45.017650 WRN phy_init 0 [CTL.YAML] Debug worker: -1
05:41:45.017651 WRN phy_init 0 [CTL.YAML] Data Lake core: -1
05:41:45.017651 WRN phy_init 0 [CTL.YAML] SRS starting Section ID: 3072
05:41:45.017651 WRN phy_init 0 [CTL.YAML] PRACH starting Section ID: 2048
05:41:45.017651 WRN phy_init 0 [CTL.YAML] USE GREEN CONTEXTS: 0
05:41:45.017651 WRN phy_init 0 [CTL.YAML] MPS SM PUSCH: 82
05:41:45.017651 WRN phy_init 0 [CTL.YAML] MPS SM PUCCH: 20
05:41:45.017651 WRN phy_init 0 [CTL.YAML] MPS SM PRACH: 2
05:41:45.017651 WRN phy_init 0 [CTL.YAML] MPS SM UL ORDER: 20
05:41:45.017651 WRN phy_init 0 [CTL.YAML] MPS SM PDSCH: 102
05:41:45.017651 WRN phy_init 0 [CTL.YAML] MPS SM PDCCH: 10
05:41:45.017652 WRN phy_init 0 [CTL.YAML] MPS SM PBCH: 2
05:41:45.017652 WRN phy_init 0 [CTL.YAML] MPS SM GPU_COMMS: 16
05:41:45.017652 WRN phy_init 0 [CTL.YAML] PDSCH fallback: 0
05:41:45.017652 WRN phy_init 0 [CTL.YAML] Massive MIMO enable: 0
05:41:45.017652 WRN phy_init 0 [CTL.YAML] Enable SRS : 0
05:41:45.017652 WRN phy_init 0 [CTL.YAML] ul_order_timeout_gpu_log_enable: 0
05:41:45.017652 WRN phy_init 0 [CTL.YAML] ue_mode: 0
05:41:45.017652 WRN phy_init 0 [CTL.YAML] Aggr Obj Non-availability threshold: 5
05:41:45.017653 WRN phy_init 0 [CTL.YAML] sendCPlane_timing_error_th_ns: 0
05:41:45.017653 WRN phy_init 0 [CTL.YAML] pusch_aggr_per_ctx: 3
05:41:45.017654 WRN phy_init 0 [CTL.YAML] prach_aggr_per_ctx: 2
05:41:45.017654 WRN phy_init 0 [CTL.YAML] pucch_aggr_per_ctx: 4
05:41:45.017654 WRN phy_init 0 [CTL.YAML] srs_aggr_per_ctx: 2
05:41:45.017654 WRN phy_init 0 [CTL.YAML] max_harq_pools: 384
05:41:45.017654 WRN phy_init 0 [CTL.YAML] ul_input_buffer_per_cell: 10
05:41:45.017655 WRN phy_init 0 [CTL.YAML] ul_input_buffer_per_cell_srs: 4
05:41:45.017655 WRN phy_init 0 [CTL.YAML] ul_order_timeout_gpu_log_enable: 0
05:41:45.017655 WRN phy_init 0 [CTL.YAML] GPU-initiated comms DL: 1
05:41:45.017655 WRN phy_init 0 [CTL.YAML] CPU-initiated comms : 0
05:41:45.017655 WRN phy_init 0 [CTL.YAML] Cell group: 1
05:41:45.017655 WRN phy_init 0 [CTL.YAML] Cell group num: 1
05:41:45.017655 WRN phy_init 0 [CTL.YAML] puxchPolarDcdrListSz: 8
05:41:45.017655 WRN phy_init 0 [CTL.YAML] split_ul_cuda_streams: 0
05:41:45.017655 WRN phy_init 0 [CTL.YAML] serialize_pucch_pusch: 0
05:41:45.017655 WRN phy_init 0 [CTL.YAML] Number of Cell Configs: 1
05:41:45.017655 WRN phy_init 0 [CTL.YAML] L2Adapter config file: /opt/nvidia/cuBB/cuPHY-CP/cuphycontroller/config/l2_adapter_config_F08_CG1.yaml
05:41:45.017656 WRN phy_init 0 [CTL.YAML] Cell name: O-RU 0
05:41:45.017656 WRN phy_init 0 [CTL.YAML] MU: 1
05:41:45.017656 WRN phy_init 0 [CTL.YAML] ID: 1
05:41:45.017656 WRN phy_init 0 [CTL.YAML] Number of MPlane Configs: 1
05:41:45.017656 WRN phy_init 0 [CTL.YAML] Mplane ID: 1
05:41:45.017656 WRN phy_init 0 [CTL.YAML] VLAN ID: 2
05:41:45.017656 WRN phy_init 0 [CTL.YAML] Source Eth Address: 9c:63:c0:d8:ea:b6
05:41:45.017657 WRN phy_init 0 [CTL.YAML] Destination Eth Address: 9c:63:c0:d8:eb:9a
05:41:45.017657 WRN phy_init 0 [CTL.YAML] NIC port: 0000:01:00.0
05:41:45.017657 WRN phy_init 0 [CTL.YAML] RU Type: 3
05:41:45.017657 WRN phy_init 0 [CTL.YAML] U-plane TXQs: 1
05:41:45.017657 WRN phy_init 0 [CTL.YAML] DL compression method: 1
05:41:45.017657 WRN phy_init 0 [CTL.YAML] DL iq bit width: 9
05:41:45.017657 WRN phy_init 0 [CTL.YAML] UL compression method: 1
05:41:45.017657 WRN phy_init 0 [CTL.YAML] UL iq bit width: 9
05:41:45.017658 WRN phy_init 0 [CTL.YAML]
05:41:45.017658 WRN phy_init 0 [CTL.YAML] Flow list SSB/PBCH:
05:41:45.017658 WRN phy_init 0 [CTL.YAML] 8
05:41:45.017658 WRN phy_init 0 [CTL.YAML] 0
05:41:45.017658 WRN phy_init 0 [CTL.YAML] 1
05:41:45.017658 WRN phy_init 0 [CTL.YAML] 2
05:41:45.017658 WRN phy_init 0 [CTL.YAML] Flow list PDCCH:
05:41:45.017659 WRN phy_init 0 [CTL.YAML] 8
05:41:45.017659 WRN phy_init 0 [CTL.YAML] 0
05:41:45.017659 WRN phy_init 0 [CTL.YAML] 1
05:41:45.017659 WRN phy_init 0 [CTL.YAML] 2
05:41:45.017659 WRN phy_init 0 [CTL.YAML] Flow list PDSCH:
05:41:45.017659 WRN phy_init 0 [CTL.YAML] Flow list CSIRS:
05:41:45.017660 WRN phy_init 0 [CTL.YAML] 2
05:41:45.017660 WRN phy_init 0 [CTL.YAML] Flow list PUSCH:
05:41:45.017660 WRN phy_init 0 [CTL.YAML] 8
05:41:45.017660 WRN phy_init 0 [CTL.YAML] 0
05:41:45.017660 WRN phy_init 0 [CTL.YAML] 1
05:41:45.017660 WRN phy_init 0 [CTL.YAML] Flow list PUCCH:
05:41:45.017660 WRN phy_init 0 [CTL.YAML] Flow list SRS:
05:41:45.017661 WRN phy_init 0 [CTL.YAML] 2
05:41:45.017661 WRN phy_init 0 [CTL.YAML] Flow list PRACH:
05:41:45.017661 WRN phy_init 0 [CTL.YAML] 15
05:41:45.017661 WRN phy_init 0 [CTL.YAML] 7
05:41:45.017661 WRN phy_init 0 [CTL.YAML] 0
05:41:45.017661 WRN phy_init 0 [CTL.YAML] PUSCH TV: /opt/nvidia/cuBB/testVectors/cuPhyChEstCoeffs.h5
05:41:45.017661 WRN phy_init 0 [CTL.YAML] SRS TV: /opt/nvidia/cuBB/testVectors/cuPhyChEstCoeffs.h5
05:41:45.017661 WRN phy_init 0 [CTL.YAML] Section_3 time offset: 58369
05:41:45.017661 WRN phy_init 0 [CTL.YAML] nMaxRxAnt: 4
05:41:45.017661 WRN phy_init 0 [CTL.YAML] PUSCH PRBs Stride: 273
05:41:45.017661 WRN phy_init 0 [CTL.YAML] PRACH PRBs Stride: 12
05:41:45.017662 WRN phy_init 0 [CTL.YAML] SRS PRBs Stride: 273
05:41:45.017662 WRN phy_init 0 [CTL.YAML] PUSCH nMaxPrb: 273
05:41:45.017662 WRN phy_init 0 [CTL.YAML] PUSCH nMaxRx: 4
05:41:45.017662 WRN phy_init 0 [CTL.YAML] UL Gain Calibration: 48.68
05:41:45.017662 WRN phy_init 0 [CTL.YAML] Lower guard bw: 845
05:41:45.209720 WRN phy_init 0 [DRV.CTX] CUDA_DEVICE_MAX_CONNECTIONS 8
05:41:45.209726 WRN phy_init 0 [DRV.CTX] use_green_contexts 0
EAL: Detected CPU lcores: 72
EAL: Detected NUMA nodes: 1
EAL: Detected shared linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/cuphycontroller/mp_socket
EAL: Selected IOVA mode 'VA'
EAL: VFIO support initialized
EAL: Probe PCI driver: gpu_cuda (10de:2342) device: 0009:01:00.0 (socket 0)
EAL: Probe PCI driver: mlx5_pci (15b3:a2dc) device: 0000:01:00.0 (socket 0)
gRPC Server listening on 0.0.0.0:50051
05:41:48.392492 WRN phy_init 0 [NVIPC.RING] nv_ipc_ring_open: name=R_cell_cfg ring_len=16 buf_size=8 OK
05:41:48.392498 WRN phy_init 0 [NVIPC.RING] nv_ipc_ring_open: name=R_generic_async_test ring_len=16 buf_size=8 OK
05:41:48.392499 WRN phy_init 0 [NVIPC.RING] nv_ipc_ring_open: name=R_cpu_stall ring_len=16 buf_size=8 OK
05:41:48.392500 WRN phy_init 0 [NVIPC.RING] nv_ipc_ring_open: name=R_fapi_delay_test ring_len=16 buf_size=8 OK
05:41:48.392502 WRN phy_init 0 [NVIPC.RING] nv_ipc_ring_open: name=R_ul_u_plane_drop_requests ring_len=32 buf_size=8 OK
05:41:48.392503 WRN phy_init 0 [NVIPC.RING] nv_ipc_ring_open: name=R_sfn_slot_sync_requests ring_len=16 buf_size=8 OK
05:41:48.403782 WRN phy_init 0 [CTL.SCF]
====> PhyDriver initialized!
05:41:48.410197 WRN phy_init 0 [NVIPC.SHM] nvipc server initialized
05:41:48.410278 WRN phy_init 0 [NVIPC.SHM] shm_ipc_open: forward_enable=0 fw_max_msg_buf_count=0 fw_max_data_buf_count=0
05:41:48.410279 WRN phy_init 0 [NVIPC.SHM] create_shm_nv_ipc_interface: OK
05:41:48.410280 WRN phy_init 0 [L2A.TRANSPORT] phy_mac_transport[0] created. phy_cell_map=0 mac_cell_map=0 mapped=false
05:41:48.410281 WRN phy_init 0 [L2A.TRANSPORT] init: loaded 1 nvipc instance
05:41:48.425680 WRN 12118 0 [NVIPC.EFD] [nvipc][core 23 ] share event_fd thread info: sched_policy=0 sched_priority=0
05:41:48.425743 WRN 12118 0 [NVIPC.EFD] [nvipc] Listening for nvipc client to connect ...
05:41:48.428427 WRN phy_main 0 [CTL.SCF] cuPHYController configured for 1 cells
05:41:48.428428 WRN phy_main 0 [CTL.SCF]
====> cuPHYController initialized, L1 is ready!
05:41:48.428441 WRN phy_main 0 [CTL.STARTUP_TIMES] {TI PERCENTAGE} <cuphycontroller main> Start Main:0.0,Parse Cuphycontroller YAML:0.0,Init nvlog:0.4,Cuda Set Device:4.6,Cuphy PTI Init:0.8,Init PHYDriver:93.5,Init cuphydriver:0.0,Make PHYDriverProxy:0.0,Init SCF FAPI:0.0,Create PHY_group:0.7,Start PHY_group:0.0, (total: 3425436.8us),
05:41:48.428444 WRN phy_main 0 [CTL.STARTUP_TIMES] {TI DURATION} <cuphycontroller main> Start Main:730.584,Parse Cuphycontroller YAML:680.218,Init nvlog:13261.276,Cuda Set Device:158573.177,Cuphy PTI Init:26307.483,Init PHYDriver:3201241.625,Init cuphydriver:0.576,Make PHYDriverProxy:9.376,Init SCF FAPI:1.888,Create PHY_group:24453.965,Start PHY_group:176.670,
05:41:48.428447 WRN phy_main 0 [CTL.STARTUP_TIMES] {TI TIMESTAMPS} <cuphycontroller main> Start Main:1728970905002990510,Parse Cuphycontroller YAML:1728970905003721094,Init nvlog:1728970905004401312,Cuda Set Device:1728970905017662588,Cuphy PTI Init:1728970905176235765,Init PHYDriver:1728970905202543248,Init cuphydriver:1728970908403784873,Make PHYDriverProxy:1728970908403785449,Init SCF FAPI:1728970908403794825,Create PHY_group:1728970908403796713,Start PHY_group:1728970908428250678,End Main:1728970908428427348,
05:41:48.429136 WRN msg_processing 0 [L2A.MODULE] Thread thread_func on CPU 29 initialized fmtlog
05:41:49.393043 WRN UlPhyDriver06 0 [DRV.WORKER] Thread UlPhyDriver06(worker_default) on CPU 6 initialized fmtlog
05:41:49.393095 WRN UlPhyDriver05 0 [DRV.WORKER] Thread UlPhyDriver05(worker_default) on CPU 5 initialized fmtlog
05:41:49.393184 WRN DlPhyDriver13 0 [DRV.WORKER] Thread DlPhyDriver13(worker_default) on CPU 13 initialized fmtlog
05:41:49.393253 WRN DlPhyDriver12 0 [DRV.WORKER] Thread DlPhyDriver12(worker_default) on CPU 12 initialized fmtlog
05:41:49.393280 WRN DlPhyDriver11 0 [DRV.WORKER] Thread DlPhyDriver11(worker_default) on CPU 11 initialized fmtlog
05:49:44.716998 WRN 12118 0 [NVIPC.EFD] [nvipc] nvipc unix socket server connected
05:49:44.717038 WRN 12118 0 [NVIPC.EFD] [nvipc] Received peer event_fd: 497
05:49:44.917121 WRN 12118 0 [NVIPC.EFD] Share event_fd succeed: efd_tx=497, efd_rx=504
05:49:44.917123 WRN 12118 0 [NVIPC.EFD] [nvipc][core 23 ] nvipc unix socket exit
05:49:45.736070 WRN msg_processing 0 [SCF.PHY] CONFIG_TLV_INDICATION_INSTANCES_PER_SLOT indPerSlotPtr[0] = 0
05:49:45.736071 WRN msg_processing 0 [SCF.PHY] CONFIG_TLV_INDICATION_INSTANCES_PER_SLOT indPerSlotPtr[1] = 0
05:49:45.736071 WRN msg_processing 0 [SCF.PHY] CONFIG_TLV_INDICATION_INSTANCES_PER_SLOT indPerSlotPtr[2] = 0
05:49:45.736071 WRN msg_processing 0 [SCF.PHY] CONFIG_TLV_INDICATION_INSTANCES_PER_SLOT indPerSlotPtr[3] = 0
05:49:45.736071 WRN msg_processing 0 [SCF.PHY] CONFIG_TLV_INDICATION_INSTANCES_PER_SLOT indPerSlotPtr[4] = 0
05:49:45.736071 WRN msg_processing 0 [SCF.PHY] CONFIG_TLV_INDICATION_INSTANCES_PER_SLOT indPerSlotPtr[5] = 0
05:49:45.736071 WRN msg_processing 0 [SCF.PHY] txPortTlvPresent absent. Setting nTxAnt to 4
05:49:45.736071 WRN msg_processing 0 [SCF.PHY] txPortTlvPresent absent. Setting nRxAnt to 4
05:49:45.736081 WRN msg_processing 0 [SCF.PHY] PHY Cell Id = 41, M-Plane Id= 1
05:49:45.742629 WRN msg_processing 0 [DRV.PUSCH] tvStatPrms: PUSCH enableDeviceGraphLaunch=1 enableCsiP2Fapiv3 = 0 nMaxLdpcHetConfigs = 32
05:49:45.742630 WRN msg_processing 0 [DRV.PUSCH] Early-HARQ is enabled. Timeout values for wait kernels are 5000us and 5000us
05:49:45.742633 WRN msg_processing 0 [DRV.PUSCH] static_params.nMaxPrb: 273
05:49:45.742634 WRN msg_processing 0 [DRV.PUSCH] static_params.nMaxRx: 4
05:49:45.750253 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 55.367 MiB for cuPHY PUSCH channel object (0x5d0654c0000).
05:49:45.750253 WRN msg_processing 0 [CUPHY.PUSCH_RX] PuschRx: Running with eqCoeffAlgo 1
05:49:45.753849 WRN msg_processing 0 [DRV.PUSCH] tvStatPrms: PUSCH enableDeviceGraphLaunch=1 enableCsiP2Fapiv3 = 0 nMaxLdpcHetConfigs = 32
05:49:45.753849 WRN msg_processing 0 [DRV.PUSCH] Early-HARQ is enabled. Timeout values for wait kernels are 5000us and 5000us
05:49:45.753850 WRN msg_processing 0 [DRV.PUSCH] static_params.nMaxPrb: 273
05:49:45.753850 WRN msg_processing 0 [DRV.PUSCH] static_params.nMaxRx: 4
05:49:45.760313 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 55.367 MiB for cuPHY PUSCH channel object (0x5d065530000).
05:49:45.760313 WRN msg_processing 0 [CUPHY.PUSCH_RX] PuschRx: Running with eqCoeffAlgo 1
05:49:45.763917 WRN msg_processing 0 [DRV.PUSCH] tvStatPrms: PUSCH enableDeviceGraphLaunch=1 enableCsiP2Fapiv3 = 0 nMaxLdpcHetConfigs = 32
05:49:45.763917 WRN msg_processing 0 [DRV.PUSCH] Early-HARQ is enabled. Timeout values for wait kernels are 5000us and 5000us
05:49:45.763918 WRN msg_processing 0 [DRV.PUSCH] static_params.nMaxPrb: 273
05:49:45.763918 WRN msg_processing 0 [DRV.PUSCH] static_params.nMaxRx: 4
05:49:45.770966 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 55.367 MiB for cuPHY PUSCH channel object (0x5d065f80000).
05:49:45.770966 WRN msg_processing 0 [CUPHY.PUSCH_RX] PuschRx: Running with eqCoeffAlgo 1
05:49:45.774548 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.437 MiB for cuPHY PUCCH channel object (0x5d0653ad200).
05:49:45.776870 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.437 MiB for cuPHY PUCCH channel object (0x5d0653ae000).
05:49:45.779445 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.437 MiB for cuPHY PUCCH channel object (0x5d0653aee00).
05:49:45.781728 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 3.437 MiB for cuPHY PUCCH channel object (0x5d066b60000).
05:49:45.783660 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.182 MiB for cuPHY PRACH channel object (0x5d06667e400).
05:49:45.784446 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.182 MiB for cuPHY PRACH channel object (0x5d06667e780).
05:49:45.789944 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d065456c00).
05:49:45.795059 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d065458400).
05:49:45.799631 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d065459c00).
05:49:45.804394 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d06545b400).
05:49:45.809649 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d06545cc00).
05:49:45.814338 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d06545e400).
05:49:45.819260 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d060470000).
05:49:45.824308 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d060471800).
05:49:45.829406 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d060473000).
05:49:45.834584 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 98.130 MiB for cuPHY PDSCH channel object (0x5d060474800).
05:49:45.835776 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061346080).
05:49:45.835962 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061346380).
05:49:45.836091 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061346680).
05:49:45.836220 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061346980).
05:49:45.836352 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061346c80).
05:49:45.836469 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061346f80).
05:49:45.836605 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061347280).
05:49:45.836726 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061347580).
05:49:45.836844 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061347880).
05:49:45.836958 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.001 MiB for cuPHY SSB channel object (0x5d061347b80).
05:49:45.837241 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066556e00).
05:49:45.837397 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066557300).
05:49:45.837510 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066556900).
05:49:45.837709 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066557800).
05:49:45.837827 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066557d00).
05:49:45.837924 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066558200).
05:49:45.838099 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066558700).
05:49:45.838307 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066558c00).
05:49:45.838406 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066559100).
05:49:45.838522 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.563 MiB for cuPHY PDCCH channel object (0x5d066559600).
05:49:45.838637 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134c980).
05:49:45.838749 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134cc80).
05:49:45.838857 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134cf80).
05:49:45.838953 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134d280).
05:49:45.839171 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134d580).
05:49:45.839264 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134f080).
05:49:45.839363 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134f380).
05:49:45.839466 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134f680).
05:49:45.839556 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134f980).
05:49:45.839822 WRN msg_processing 0 [CUPHY.MEMFOOT] cuphyMemoryFootprint - GPU allocation: 0.093 MiB for cuPHY CSIRS channel object (0x5d06134fc80).
05:49:45.839834 WRN msg_processing 0 [DRV.API] Update cell: mplane_id=1 dl_grid_sz=273
05:49:45.839835 WRN msg_processing 0 [DRV.API] Update cell: mplane_id=1 ul_grid_sz=273
05:49:45.841747 WRN timer_thread 0 [L2A.TICK] Thread slot_indication_thread_sleep_method initialized fmtlog
05:49:45.841749 WRN timer_thread 0 [L2A.TICK] PTP Configs: gps_alpha: 0 gps_beta: 0
05:49:50.520021 WRN timer_thread 0 [SCF.PHY] Cell 0 | DL 0.00 Mbps 0 Slots | UL 0.00 Mbps 0 Slots CRC 0 ( 0) | Tick 0
05:49:50.524514 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] Slot Map 0, SFN 0 Slot 4 Order kernel timeout error or Exit error for cell index 0 Dyn index 0!
05:49:50.526033 ERR msg_processing 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.API] SFN 0.15 No available Aggr PUSCH objects
05:49:50.526042 WRN msg_processing 0 [SCF.PHY] L1 Enqueue Error on SFN 0.15 for cell-id 0
05:49:50.526908 ERR UlPhyDriver06 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] Slot Map 0, SFN 0 Slot 4 PUSCH Pre Early Harq Wait kernel timeout!
05:49:50.526977 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] Slot Map 0, SFN 0 Slot 4 PUSCH Post Early Harq Wait kernel timeout!
05:49:50.527570 ERR UlPhyDriver06 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] Slot Map 1, SFN 0 Slot 5 Order kernel timeout error or Exit error for cell index 0 Dyn index 0!
05:49:50.531036 ERR msg_processing 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.API] SFN 1.5 No available Aggr PUSCH objects
05:49:50.531043 WRN msg_processing 0 [SCF.PHY] L1 Enqueue Error on SFN 1.5 for cell-id 0
05:49:50.532010 ERR UlPhyDriver05 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] Slot Map 1, SFN 0 Slot 5 PUSCH Pre Early Harq Wait kernel timeout!
05:49:50.532063 ERR UlPhyDriver06 0 [AERIAL_CUPHY_API_EVENT] [DRV.FUNC_UL] Slot Map 1, SFN 0 Slot 5 PUSCH Post Early Harq Wait kernel timeout!
05:49:50.532068 WRN UlPhyDriver05 0 [DRV.FH] sendCPlane_timingCheck : sendCPlane Timing error for ULC. Too late to abort UL tasks start_tx_time 1728971390526664000 current_time 1728971390532067951 start_ch_task_time 1728971390526000000
05:49:50.532068 ERR UlPhyDriver05 0 [AERIAL_CUPHYDRV_API_EVENT] [DRV.FUNC_UL] UL C-plane send timing error for cell index 0 error type 2 Map 2,Error detection too late. No UL Task Abort!
05:49:50.532068 ERR UlPhyDriver05 0 [AERIAL_L2ADAPTER_EVENT] [SCF.PHY] Send SLOT error indication from L1 SFN=0 slot=14 for msg_id=0x07
