I’m using PGI CDK on a cluster with Opteron 6128 processors. I would like to know if “-tp = k8-64e” or something else is the optimal target for this processor. Thanks in advance.
Are you building your application on the target system? If so, just leave the “-tp” off since the compiler will default to targeting the build system.
You can also use the PGI utility “pgcpuid” or “-V” to see what the compiler thinks the target system is. Note we treat Mangy-cours the same as an Istanbul since Mangy-Cours is essentially two Istanbuls on the same die.
