Hi everyone?
I have question with how to set CSI and mipi on DT and device driver.
Most of examples are using CSI0 or CSI1 and i want to know how to set CSI 6, 7 setting.
where is MIPI and CSI points?
I think that imx390 is reference and finding some points.
and HW connection is like this.
I tried to change DT first and modify like this.
devnode = “video5”; // “video0”
tegra_sinterface = “serial_a” → “serial_g” : // CSI 6
or tegra_sinterface = “serial_b” → "serial_g " // CSI 7
gmsl-link {
src-csi-port = “b”; → “f”
dst-csi-port = “a”; → “g”
vc_id = “5”; // “0”;
is it right?
i2c@3180000 {
tp2854_a@44 {
compatible = "nvidia,tp2854";
reg = <0x44>;
sensor_model ="tp2854_a";
avdd-reg = "vana";
iovdd-reg = "vif";
dvdd-reg = "vdig";
use_sensor_mode_id = "true";
cam-index = <6>; // ..?
physical_w = "3.674";
physical_h = "2.738";
vana-supply = <&en_vdd_cam_hv_2v8>;
vif-supply = <&en_vdd_cam>;
/* V4L2 device node location */
devnode = "video5"; //
mode0 { // tp2854_MODE_1280X720
mclk_khz = "27000";
num_lanes = "4";
vc_id = "0";
phy_mode = "DPHY";
discontinuous_clk = "no";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
tp2854_vi_out6: endpoint {
vc-id = <0>;
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&tp2854_csi_in6>;
gmsl-link {
src-csi-port = "c";
dst-csi-port = "a";
serdes-csi-link = "a";
csi-mode = "1x4";
st-vc = <0>;
vc-id = <0>;
num-lanes = <4>;
streams = "ued-u1", "yuv422";
