Regarding Note 4 in Section 9.2 of the Design Guide, which states that RPDs are required for DP1_Dx_HDMI_* pads: does this also apply to the DP0 and DP2/3 pads?
The upcoming release of the next Jetson Thor Design Guide will remove the requirement of the RPDs for HDMI.
Related topics
| Jetson Thor 5000 HDMI design with non-DP1_Dx_HDMI_* pads | 1 | 53 | May 29, 2026 | |
| RPD Implementation in the HDMI Circuit Design of Jetson Thor | 1 | 42 | July 21, 2026 | |
| Thor cannot output HDMI to the screen when using DP0 in version R38.4 | 5 | 111 | June 5, 2026 | |
| Jetson thor hdmi2 display failed | 4 | 190 | November 12, 2025 | |
| DG-12084 Design Guide Question | 6 | 147 | February 26, 2026 | |
| JETSON THOR HDMI design,does the HDMI signal need a 499 ohm pull-down, ferrite bead, and MOSFET? | 1 | 83 | April 15, 2026 | |
| Thor HDMI2 | 1 | 82 | February 24, 2026 | |
| Jetson Thor HDMI 2.1 (8K@30) | 6 | 161 | June 1, 2026 | |
| custom carrier board HDMI requirments | 3 | 787 | June 6, 2018 | |
| How to disabled hpd pin in system | 1 | 66 | June 23, 2026 |
