I recently purchased the VL6180X Time-of-Flight Distance Sensor Carrier with Voltage Regulator for short-distance measurement in a personal project. I am using the sensor on the Jetson Nano developer kit and developed my code based off the JetsonHacks VL53L0X library and Pololu VL6180X library. After I was able to successfully read measurement inputs from the sensor I encountered an issue where it could only read a measurement of 135mm. Regardless of if I had an object over the sensor or nothing at all a measurement of 135mm was read in.
My belief is that I’m making mistakes in writing and reading to the sensors registers, however, I can’t quite seem to grasp the i2c_smbus_write/read functions to troubleshoot the issue.
I’ve uploaded the code to a github repo here https://github.com/adani111/VL6180X-Jetson-Nano-Drivers.
If you have any experience in using i2c and sensors on the Jetson Nano please feel free to help out, any advice will be greatly appreciated.
