System Info : Ubuntu 20.04
Reason : When I try importing VPI in Python for more than two instances I get a double corruption free error
Error: “double free or corruption (out)
Aborted (core dumped)”
Please share the details on how to reproduce this issue.
There is a known issue that uses together with PyTorch in our document:
https://docs.nvidia.com/vpi/release_notes.html#autotoc_md5
There is a similar topic that can be fixed by changing the importing order.
Please check if the WAR can work in your environment:
On the Jetson Orin -
Please find attached the image.
Thanks for the details.
Confirmed that we can reproduce the same error in our environment.
We are checking this with our internal team and will let you know the following.
Thank you for the update. Is there any progress on this issue?
It worked perfectly fine on Xavier but porting to Orin is now blocking majority of the code base from being run.
Our internal team is still working on this.
Do you mean you can import 3x vpi module on Xavier?
If yes, is the device set up with r35.2.1?
Noticed one more thing -
Thanks for the update.
We are checking this issue internally.
Will share more information with you later.
Thanks for your patience.
We have narrowed down the cause and found the error is related to the PVA limit.
Are you using the PVA backend in your use case?
Since there is a limit on the number of PVA-based processes, we turn off the PVA backend when the limit is reached.
Will this affect your use case?
We are not using PVA right now. It is just VPI backend. Sure, PVA can be turned of when the limit will be reached.
Thank you!
Thanks. The fix is included in our next VPI release.
