I had tried exporting according to this but failed using both dynamo_export and export. Wonder if it is possible to try exporting through TAO.
For the pth model which is trained via TAO Toolkit, it is sure to export it to onnx file.
For example, https://github.com/NVIDIA/tao_pytorch_backend/blob/e5010af08121404dfb696152248467eee85ab3a7/nvidia_tao_pytorch/cv/dino/scripts/export.py,
https://github.com/NVIDIA/tao_pytorch_backend/blob/e5010af08121404dfb696152248467eee85ab3a7/nvidia_tao_pytorch/cv/metric_learning_recognition/scripts/export.py, etc.
The command line can be found in corresponding user guide or notebook.
Refer to DINO - NVIDIA Docs.
Or https://github.com/NVIDIA/tao_tutorials/blob/95aca39c79cb9068593a6a9c3dcc7a509f4ad786/notebooks/tao_launcher_starter_kit/dino/dino.ipynb.
There is several docker from TAO. See TAO Toolkit | NVIDIA NGC. One is from pytorch backend.
You can login into the docker. And run the export command.
$ docker run --runtime=nvidia -it --rm nvcr.io/nvidia/tao/tao-toolkit:5.1.0-pyt /bin/bash,
Then inside the docker in the command without “tao” in the beginning. For example, for DINO network,
$ dino export xxx
