Hi
I tested on xavier nx dev kit
my qustion.
Is it possible to use SPI0_CS1(pin26 of J12 40pin header) as user gpio I/O ? [Remove the spi function]
Currently, this pin does not seem to work normally. [already used all other 6 GPIO pins]
Hi
my qustion.
hello jchcdev,
according to pinmux spreadsheets, SPI0_CS1 is by default configured as GPIO pin, it’s GPIO3_PZ.07
That’s what I thought.
First of all, I am using the image of this link at https://developer.nvidia.com/jetson-nx-developer-kit-sd-card-image.
but pin 26 does not normally operate in gpio input
our external board has switch & pull up register(51k ohm)
default is detect High when boot up
detect low when push the switch (first once)
26 pin will never return to high again
I tried changing the pull-up resister, but it didn’t work at all.
Is there anything I can test ??
below is my pin configuration
26 pin didn’t set sfio [spi]
hello jchcdev,
please refer to TXB on the carrier board,
you may access applications note, 40-Pin Expansion Header GPIO Usage Considerations for reference,
thanks
