JETSON
• DeepStream Version
5.0
4.4
• TensorRT Version
7
Hi.
There was no problem when using nvmultistreamtiler plugin
but I need a variety of tile layouts, so i made a new customtiler plugin.
When use my custom plugin, no problem in situations where objects are not detected.
→ it means, no object in the frame & no drawing nvosd objects (bbox rectangle)
But the moment deepstream detect an object, start drawing nvosd objects [bbox rectangle]
at the same time occured memory leak(vmsize, vmrss)
below is full source code my custom tiler plugin
I implemented the function of converting nBatch NvBufSurface to 1Batch NvBufSurface in the same way as the existing nvmultistreamtiler.
gstcustomtiler.cpp (33.8 KB)
gstcustomtiler.h (3.3 KB)
and memory leak log
//Normal [ no object detect & no draw nvosd ]
PID: 10201 03:01:06 Total used hardware memory: 227.1406 MiB hardware memory: 227.1406 MiB VmSize: 10931.0820 MiB VmRSS: 973.9102 MiB RssFile: 314.9414 MiB RssAnon: 660.1094 MiB lsof: 449
PID: 10201 03:01:07 Total used hardware memory: 416.6094 MiB hardware memory: 416.6055 MiB VmSize: 12452.1484 MiB VmRSS: 1111.5781 MiB RssFile: 343.2891 MiB RssAnon: 750.3672 MiB lsof: 747
PID: 10201 03:01:08 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12453.9062 MiB VmRSS: 1111.8594 MiB RssFile: 359.6914 MiB RssAnon: 754.7422 MiB lsof: 747
PID: 10201 03:01:09 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12434.0234 MiB VmRSS: 1100.9922 MiB RssFile: 354.8281 MiB RssAnon: 754.7930 MiB lsof: 746
PID: 10201 03:01:11 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12452.1484 MiB VmRSS: 1111.2031 MiB RssFile: 360.5664 MiB RssAnon: 755.6992 MiB lsof: 745
PID: 10201 03:01:12 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12448.5234 MiB VmRSS: 1113.9570 MiB RssFile: 344.0234 MiB RssAnon: 755.7266 MiB lsof: 743
PID: 10201 03:01:13 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12452.1484 MiB VmRSS: 1114.7305 MiB RssFile: 344.0625 MiB RssAnon: 756.6055 MiB lsof: 747
PID: 10201 03:01:14 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12439.2969 MiB VmRSS: 1100.8164 MiB RssFile: 344.1992 MiB RssAnon: 756.6172 MiB lsof: 743
PID: 10201 03:01:15 Total used hardware memory: 416.6094 MiB hardware memory: 416.6055 MiB VmSize: 12455.6641 MiB VmRSS: 1104.1914 MiB RssFile: 344.0586 MiB RssAnon: 756.6172 MiB lsof: 747
PID: 10201 03:01:17 Total used hardware memory: 416.6016 MiB hardware memory: 416.6055 MiB VmSize: 12452.1484 MiB VmRSS: 1111.5469 MiB RssFile: 344.6250 MiB RssAnon: 756.6328 MiB lsof: 747
PID: 10201 03:01:18 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12452.1484 MiB VmRSS: 1114.0547 MiB RssFile: 359.2812 MiB RssAnon: 756.6367 MiB lsof: 744
PID: 10201 03:01:19 Total used hardware memory: 416.6016 MiB hardware memory: 416.6016 MiB VmSize: 12452.1484 MiB VmRSS: 1114.0273 MiB RssFile: 358.9141 MiB RssAnon: 756.6562 MiB lsof: 747
PID: 10201 03:01:20 Total used hardware memory: 416.6055 MiB hardware memory: 416.6055 MiB VmSize: 12444.8984 MiB VmRSS: 1101.0977 MiB RssFile: 344.4375 MiB RssAnon: 756.6602 MiB lsof: 747
PID: 10201 03:01:22 Total used hardware memory: 416.6055 MiB hardware memory: 416.6055 MiB VmSize: 12452.1484 MiB VmRSS: 1119.5703 MiB RssFile: 344.5625 MiB RssAnon: 757.5391 MiB lsof: 743
//Detect [ object detect & draw nvosd]
PID: 10201 03:01:23 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12476.6289 MiB VmRSS: 1135.7070 MiB RssFile: 384.2305 MiB RssAnon: 759.1484 MiB lsof: 797
PID: 10201 03:01:24 Total used hardware memory: 416.6055 MiB hardware memory: 416.6055 MiB VmSize: 12578.2383 MiB VmRSS: 1240.7617 MiB RssFile: 483.4453 MiB RssAnon: 760.8008 MiB lsof: 799
PID: 10201 03:01:25 Total used hardware memory: 416.6016 MiB hardware memory: 416.6016 MiB VmSize: 12650.6289 MiB VmRSS: 1303.0391 MiB RssFile: 528.2773 MiB RssAnon: 760.8672 MiB lsof: 799
PID: 10201 03:01:26 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12650.7383 MiB VmRSS: 1303.1836 MiB RssFile: 528.2539 MiB RssAnon: 760.8672 MiB lsof: 799
PID: 10201 03:01:28 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12764.8711 MiB VmRSS: 1401.4492 MiB RssFile: 633.5508 MiB RssAnon: 760.8672 MiB lsof: 799
PID: 10201 03:01:29 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 12898.9961 MiB VmRSS: 1534.8906 MiB RssFile: 777.1133 MiB RssAnon: 760.8672 MiB lsof: 796
PID: 10201 03:01:30 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 13027.6289 MiB VmRSS: 1657.9141 MiB RssFile: 880.0000 MiB RssAnon: 760.8750 MiB lsof: 799
PID: 10201 03:01:31 Total used hardware memory: 416.6055 MiB hardware memory: 416.6055 MiB VmSize: 13152.7461 MiB VmRSS: 1767.4531 MiB RssFile: 1000.9688 MiB RssAnon: 760.8750 MiB lsof: 797
PID: 10201 03:01:33 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 13266.9883 MiB VmRSS: 1878.8203 MiB RssFile: 1123.3594 MiB RssAnon: 760.8750 MiB lsof: 797
PID: 10201 03:01:34 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 13379.2539 MiB VmRSS: 1989.0469 MiB RssFile: 1222.9648 MiB RssAnon: 760.8750 MiB lsof: 799
PID: 10201 03:01:35 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 13420.9961 MiB VmRSS: 2014.8320 MiB RssFile: 1253.8516 MiB RssAnon: 760.9805 MiB lsof: 799
PID: 10201 03:01:36 Total used hardware memory: 416.6055 MiB hardware memory: 416.6055 MiB VmSize: 13437.3633 MiB VmRSS: 2050.1797 MiB RssFile: 1288.5781 MiB RssAnon: 761.8594 MiB lsof: 796
PID: 10201 03:01:37 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 13442.7461 MiB VmRSS: 2050.2539 MiB RssFile: 1290.1953 MiB RssAnon: 761.8633 MiB lsof: 797
//End Detect
PID: 10201 03:01:39 Total used hardware memory: 416.6055 MiB hardware memory: 416.6055 MiB VmSize: 13462.6289 MiB VmRSS: 2065.9727 MiB RssFile: 1309.3320 MiB RssAnon: 761.8711 MiB lsof: 794
PID: 10201 03:01:40 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 13453.6211 MiB VmRSS: 2051.9375 MiB RssFile: 1295.3477 MiB RssAnon: 761.8711 MiB lsof: 798
PID: 10201 03:01:41 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 13459.0039 MiB VmRSS: 2060.7695 MiB RssFile: 1301.2148 MiB RssAnon: 761.8750 MiB lsof: 799
PID: 10201 03:01:42 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 13460.8711 MiB VmRSS: 2060.6055 MiB RssFile: 1297.3047 MiB RssAnon: 761.8789 MiB lsof: 798
PID: 10201 03:01:44 Total used hardware memory: 416.6055 MiB hardware memory: 416.6094 MiB VmSize: 13459.0039 MiB VmRSS: 2058.4609 MiB RssFile: 1302.3711 MiB RssAnon: 761.8828 MiB lsof: 799
PID: 10201 03:01:45 Total used hardware memory: 416.6016 MiB hardware memory: 416.6094 MiB VmSize: 13457.2461 MiB VmRSS: 2050.3555 MiB RssFile: 1288.4727 MiB RssAnon: 761.8828 MiB lsof: 795
PID: 10201 03:01:46 Total used hardware memory: 416.6094 MiB hardware memory: 416.6094 MiB VmSize: 13460.8711 MiB VmRSS: 2058.1719 MiB RssFile: 1304.9297 MiB RssAnon: 761.8828 MiB lsof: 797
PID: 10201 03:01:47 Total used hardware memory: 416.6094 MiB hardware memory: 416.6055 MiB VmSize: 13442.7461 MiB VmRSS: 2051.8125 MiB RssFile: 1290.6992 MiB RssAnon: 761.8867 MiB lsof: 797
PID: 10201 03:01:48 Total used hardware memory: 196.2305 MiB hardware memory: 159.9805 MiB VmSize: 13203.2383 MiB VmRSS: 2018.5430 MiB RssFile: 1263.2422 MiB RssAnon: 755.3008 MiB lsof: 435
