- Will different DDR/eMMC be used in the same batch of Orin 32G.
- Does Orin32G support customized production for customers?
- Is it possible to trace eMMC/DDR5 by SN#?
Here are the answers:
- Yes
- No.
- Only the part number to identify, see below details on PCN doc:
Any Jetson AGX Orin 32GB with 699 level part number version greater than or equal to 502 may be affected by this PCN. Each module has a label and/or 2D barcode which provides the 699 level part number. For example, a module with 699 level part number 699-13701-0004-502 may be affected. Customers may receive mixed shipments, with 699 level part number versions less than, equal to, or greater than 502. Modules with 699 level part number versions equal to or greater than 502 may be built with the new components described in this PCN, or with the older components
