I need to port to OpenACC a code like this:
module storage_1
integer, parameter :: N=1000
real, dimension(:,:), allocatable :: A,B,C
end module storage_1
subroutine allocate_1()
use storage_1
allocate(A(N,N),B(N,N),C(N,N))
A = 1. ; B = 2. ; C = 0.
end subroutine allocate_1
module storage_2
end module storage_2
subroutine allocate_2()
use storage_2
A = 2. ; B = 3. ; C = 0.
end subroutine allocate_2
subroutine matadd_sub_1()
use storage_1; implicit none
integer :: i,j
!$acc kernels loop present(A,B,C)
do i=1,N
do j=1,N
C(i,j) = A(i,j) + B(i,j)
enddo
enddo
!$acc end kernels
end subroutine matadd_sub_1
subroutine matadd_sub_2()
use storage_2; implicit none
integer :: i,j
do i=1,N
do j=1,N
enddo
enddo
!$acc end kernels
end subroutine matadd_sub_2
subroutine print_1
print*,"1: C: ",C(6,3)
end subroutine print_1
subroutine print_2
print*,"2: C: ",C(6,3)
end subroutine print_2
program matadd
implicit none
call allocate_1 ;
call allocate_2
!$acc data region create(???)
!$acc update device(???)
call matadd_sub_1
call matadd_sub_2
!.... many other calls for 1 and 2.....
!$acc update host(???)
!$acc end data region
call print_1
call print_2
end program matadd
where I need to control CPU-GPU copies by means of update directives.
The problem is that I cannot specify the list of variables when declaring the data region because the main programm cannot see the storage variables which have the same names but are defined in different modules.
Maybe, the declare directive could help if the allocate subroutines become module subprograms of the corresponding storage modules, according to the standard (If my understanding is correct):
“If the directive appears in a Fortran MODULE subprogram, the associated region is the implicit region for the whole program”.
Is this feature implemented in PGI 12.5? I cannot have it working but maybe I am in a mistake.
Or the best would be to use declare directly in the storage modules but I think the standard does not allow for it. Is it?
I thank you very much for any help,
Francesco
