Each source has a parameter called “type” in the config file. The config parser location,
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://admin:admin%40123@172.16.16.22:554/streaming/channels/201
num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
/opt/nvidia/deepstream/deepstream-4.0/sources/apps/apps-common/src/deepstream_config_file_parser.c
if (!g_strcmp0 (*key, CONFIG_GROUP_SOURCE_TYPE)) {
config->type =
g_key_file_get_integer (key_file, group,
CONFIG_GROUP_SOURCE_TYPE, &error);
CHECK_ERROR (error);
Definition of config->type param,
/opt/nvidia/deepstream/deepstream-4.0/sources/apps/apps-common/includes/deepstream_sources.h
typedef enum
NV_DS_SOURCE_CAMERA_V4L2 = 1,
NV_DS_SOURCE_URI,
NV_DS_SOURCE_URI_MULTIPLE,
NV_DS_SOURCE_RTSP,
NV_DS_SOURCE_CAMERA_CSI
} NvDsSourceType;
typedef struct
NvDsSourceType type;
gboolean enable;
gboolean loop;
gboolean live_source;
gboolean Intra_decode;
gint source_width;
gint source_height;
gint source_fps_n;
gint source_fps_d;
gint camera_csi_sensor_id;
gint camera_v4l2_dev_node;
gchar *uri;
gint latency;
guint num_sources;
guint gpu_id;
guint camera_id;
guint select_rtp_protocol;
guint num_decode_surfaces;
guint num_extra_surfaces;
guint nvbuf_memory_type;
guint cuda_memory_type;
NvDsDewarperConfig dewarper_config;
guint drop_frame_interval;
} NvDsSourceConfig;
How does the config parser even work with config->type being a custom structure and config->type is being assigned an integer?
