Hi there,
I’m about to port a working application to a new platform in need of more computing cores to speed it up, tk-1 is a promising contender.
Unfortunately I haven’t found the information that I need about the memory allocation by the host cpu and the device gpu on the nvidia website. (I’m not a registered developer, yet)
So, the tk-1 has 2 GB of ram, how much ram can be assigned at the max to the device gpu? Is all device memory automatically shared memory which is also accessible by the host cpu?
What is the default memory split (host, device, shared) in numbers? Can I freely change it?
I do not need any video output at all, can I use the graphic memory for program data instead or is a certain amount of memory always reserved for video?
Thank you very much in advance!
Best,
Fred
