Question: Why is Nvblox dynamic mode not supported with ZED / ZED X?
I would like to understand why the Isaac ROS Nvblox ZED example does not support dynamic mapping mode with ZED cameras, particularly ZED X.
Nvblox provides different mapping modes, including:
  • static
  • people
  • dynamic
The dynamic mode is intended to handle general dynamic objects in the environment.
However, the ZED integration appears to be limited to the static configuration.
I would like to understand whether this limitation is caused by:
  1. ZED depth estimation
  2. ZED positional tracking / pose estimation
  3. Depth and pose timestamp synchronization
  4. Depth image characteristics produced by the ZED SDK
  5. ZED X hardware limitations
  6. GPU / computational resource requirements
  7. Nvblox’s ZED integration
  8. Another limitation in the current implementation
Why I am asking
I have tested ZED X with Nvblox dynamic reconstruction.
Although the system can be configured to run with dynamic reconstruction, the resulting reconstruction is not as stable as expected.
For example, dynamic objects can leave residual voxels / artifacts in the reconstruction, and the behavior is noticeably different from the expected dynamic mapping behavior.
Therefore, I would like to understand whether this is an expected limitation of the ZED + Nvblox combination or whether there is a recommended configuration that is currently missing from the documentation.
Questions
1. Why is ZED not supported for Nvblox dynamic mode?
Is there a specific technical reason why the ZED example is restricted to static reconstruction?
2. Is the limitation specific to ZED / ZED X?
For example, is dynamic reconstruction expected to work with other depth cameras such as RealSense, while ZED is excluded because of characteristics of its depth data?
3. Is the limitation related to depth quality?
Does Nvblox dynamic reconstruction require specific properties from the depth camera, such as:
  • stable per-frame depth
  • low depth noise
  • reliable invalid-depth regions
  • consistent depth confidence
  • accurate depth discontinuities
  • sufficient temporal consistency
If so, are there specific ZED depth settings that are required?
4. Is ZED positional tracking involved?
Does dynamic reconstruction require a particular quality or behavior from the camera pose estimation?
For example, could pose jitter or small frame-to-frame pose errors cause dynamic objects to be incorrectly integrated into the static TSDF?
5. Is there a recommended ZED configuration?
If ZED X dynamic reconstruction is technically possible, could you provide a recommended configuration for:
depth:
  depth_mode: ...
  depth_confidence: ...
  depth_texture_conf: ...
pos_tracking:
general:
  grab_frame_rate: ...
  pub_frame_rate: ...
together with the corresponding Nvblox parameters?
6. Is support planned?
If ZED / ZED X dynamic mode is currently unsupported by design, is there a plan to support it in a future Isaac ROS Nvblox release?
Thank you.
Hello @leo.si.wang,
Thanks for posting in the Isaac ROS forum!
Currently, the Isaac ROS nvblox ZED example supports static reconstruction only, and this is
explicitly enforced in the launch code. Please refer to the supported-configurations table ( Nvblox — Isaac ROS ) for the available camera, platform, and reconstruction-mode combinations.
The RealSense example includes a dynamic-mode launch configuration and uses Isaac ROS Visual SLAM for pose estimation. The ZED example instead uses ZED positional tracking and is currently configured and restricted to static reconstruction. Both use the same underlying nvblox mapping node. This difference does not imply that ZED depth or tracking is inherently unsuitable for dynamic reconstruction. However, we do not currently have a validated ZED dynamic-reconstruction configuration to recommend for the parameters you listed.
Please also note that ZED X is marked as not SQA tested in our camera compatibility table.
Regarding positional tracking, the dynamic-reconstruction documentation requires accurate pose estimation and notes that objects moving slower than odometry drift cannot be detected as dynamic. This is a general requirement, rather than a confirmed explanation for the current ZED restriction.
We’ll update our documentation once ZED/ZED X dynamic reconstruction is officially supported.
