I found that there is a mismatch between Fig 1 Jetson AGX Xavier Root Port Jetson AGX Xavier Endpoint and Fig 3 in the NVIDIA JESTON AGX XAVIER PCIe ENDPOINT DESIGN GUIDLINES as shown below.
For the circled area, I was wondering why we don’t need 0.22uF cap in the real x16 PCIe Tx/Rx swap module.
I have another question about EE3317-A01 x16 PCIe Tx/R module.
I am counting the pcb for the first option(finger-connector) with two layers. And found it seems a bit hard to connect the ground pins for the golden finger. May I ask how many lays have been used for EE3317-A01 x16 PCIe Tx/R module?
Here is my way to route the golden finger, not sure whether it is good or bad(new to PCIe).
Zoomed in version:
It can be seen that the ground connection is a bit messy. Not sure whether I need another layer.
