Both • DeepStream Version
6.0.1 • JetPack Version (valid for Jetson only)
4.6.1 • TensorRT Version
8.2.1 • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs)
Question/observation • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
We’ve been trying to use the Gst-nvdspreprocess plugin for a few scenarios but we’ve been observing some unexpected results… or perhaps we don’t quit understand how the preproc plugin works.
So just as a simple test…
Using a sample set of 1920x1080 pixel images as a single standard, we inferred on the images using three different approaches with the results show below… all using the same TensorRT model. Average inference confidence is show in the far right column.
the first table is produced using Pytorch.
the second table is produced with a DeepStream pipeline.
the third table is produced with the same DeepStream pipeline but with the preproc plugin and a single ROI of 1920x1080.
The difference between the first and second tables are understandable, but we’re trying to understand why adding the preproc would have such an effect on the results in the third table. One would think they would be near identical to the second table. Can anyone explain these results?
Hi @prominence_ai ,
We are still working on this, need more time.
As you claimed that this is reproduced on both platforms but gave Jetson version, would like to confirm with you if you can also reproduce this on dGPU platform?
And, have you tried “scaling-pool-compute-hw=1” to use GPU to do the scale.
And, did you try different “scaling-filter=” ?
Hi @prominence_ai
Thanks! So “scaling-pool-compute-hw=0/1” is the key which cause the accuracy difference, right? If it’s, that’s almost aligned with our observation.
