I have questions on the sample 15_multivideo_encode:
- In main() function, why have argv+=2?
- what’s the purpose of “stress_test” ?
num_files 2
. The +2
is ot skip the two items.stress_test
is to run the sample in loop. Please check the option: -s <loop-count> Stress test [Default = 1]
Thank you very much.
I still have another question, as you know we can use a created hardware converter to do conversion, we can also use NvBufferTransform to do conversion between hardware memory, so what’s the difference between them? Can the hardware converter convert multi video streaming at the same time like the hardware encoder?
We would suggest use NvBufferTransform(). NvVideoConverter
class will be deprecated soon. Both NvBufferTransform() and NvVideoConverter
uses the same hardware converter(VIC engine). Just two different software frameworks.
For multiple NvBufferTransform() calls in same process, please create NvBufferSession
. Can refer to
Question on NvBufferSession - #3 by DaneLLL
