Jestson
• DeepStream Version
6.0.1
4.6.3
• TensorRT Version
8.2.1-1+cuda10.2
Questions
Looking at the RTSP Source bin implementation in deepstream_source_bin.c
I see the following.
First, in the create_rtsp_src_bin
function we have pre-decode tee
linked to the decode queue
which is linked to the decoder
. The tee
is also optionally linked to the recordbin
link_element_to_tee_src_pad(bin->tee_rtsp_pre_decode, bin->dec_que);
NVGSTDS_LINK_ELEMENT (bin->dec_que, bin->decodebin);
if (ctx)
link_element_to_tee_src_pad(bin->tee_rtsp_pre_decode, ctx->recordbin);
In the select-stream callback, the depay
is linked to the parser
which is linked to the pre-decode tee
NVGSTDS_LINK_ELEMENT (bin->depay, bin->parser);
NVGSTDS_LINK_ELEMENT (bin->parser, bin->tee_rtsp_pre_decode);
And in the pad-added callback the rtspsrc
element is linked to the depay
GstPad *sinkpad = gst_element_get_static_pad (bin->depay, "sink");
if (gst_pad_link (pad, sinkpad) != GST_PAD_LINK_OK) {
This gives us
|->queue->decoder->
rtcpsrc->depay->parser->tee
|->recordbin
This is exactly what is show in the diagram here
Looking at the Smart Recording example, in the main function we have the depay
which is linked to the queue
Surprisingly, there is no parser
between the depay
and the decoder
/* Link the elements together till decoder */
if (!gst_element_link_many (depay_pre_decode, tee_pre_decode,
queue_pre_decode, decoder, NULL)) {
Then in the pad-added callback, the rtspsrc
and then the pre-decode tee
which is linked to the recordbin
GstPad *sinkpad = gst_element_get_static_pad (depay_elem, "sink");
if (gst_pad_link (element_src_pad, sinkpad) != GST_PAD_LINK_OK) {
GstElement *parser_pre_recordbin =
gst_element_factory_make ("h264parse", "parser-pre-recordbin");
if (!gst_element_link_many (tee_pre_decode, parser_pre_recordbin,
nvdssrCtx->recordbin, NULL)) {
This gives us
|->queue->decoder->
rtcpsrc->depay->tee
|->parser->recordbin
The approach used in the common RTSP source bin in deepstream_source_bin.c
seems correct to me, and used to work… however, I’m only able to get the recordbin
to link if I follow the approach in the Smart-Recording example. This seems to have change when audio support was added??
Can anyone explain why?
Thanks,
Robert.
