Hey all I am trying to supress my warnings when I compile using nvcc due to the fact that the terminal I have to vpn through wont scroll and I need to see the errors that are being outputted.
I normally run command
nvcc -o filename.so --compiler-options -fPIC -shared filename.cu
To supress all warnings I think I need to send gcc the -w option so I tried
nvcc -o filename.so --compiler-options -w -fPIC -shared filename.cu
-Xcompiler=-w does work for warnings generated by gcc (add a .c source file with a #warning statement to verify this), but it doesn’t work for warnings generated by nvcc as far as I know.
To solve your problem, try
nvcc (your options and files here) 2>&1 | less
or even
nvcc (your options and files here) 2>&1 | grep -v error | less
This should enable you to ‘scroll’ through your output.
