Hi WayneWWW
It gives the following output:
sudo ./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --applet mb1_t194_prod.bin --cmd “erase /sdmmc_boot/3/; erase /sdmmc_user/3/” --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin “mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a02.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb”
File “./tegraflash.py”, line 1222, in
chip = chip.replace(’ ', ’ ')
AttributeError: ‘NoneType’ object has no attribute ‘replace’
erase: command not found
mts_preboot: command not found
mts_mce: command not found
mts_proper: command not found
bpmp_fw: command not found
bpmp_fw_dtb: command not found
spe_fw: command not found
Command ‘tlk’ not found, did you mean:
command ‘tlf’ from deb tlf
command ‘elk’ from deb elk
command ‘talk’ from deb inetutils-talk
command ‘talk’ from deb talk
command ‘talk’ from deb ytalk
command ‘tla’ from deb tla
command ‘tlp’ from deb tlp
Try: apt install
Command ‘eks’ not found, did you mean:
command ‘eos’ from deb elk-lapw
command ‘sks’ from deb sks
command ‘ecs’ from deb ecere-dev
Try: apt install
We have to use it on the x86 host, right?
