Hi sevm89,
Could you try rel-32.2 ? This command was verified on rel-32.2. If you just want to erase the whole emmc, I don’t think the release version would matter.
Hi sevm89,
We get the same error also with rel-32.2.
Are you using devkit to verify?
Hi WanyeWWW
As the module is in recovery mode, why does it matter if we use the DevKit or our carrier board?
I just tried this command with rel-32.2 again and it can erase the emmc.
~/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader$ sudo ./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --applet mb1_t194_prod.bin --cmd "erase /sdmmc_boot/3/; erase /sdmmc_user/3/" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a02.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.1262 ] Generating RCM messages
[ 0.1367 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.1378 ] Header already present for mb1_t194_prod.bin
[ 0.1701 ]
[ 0.1892 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.1909 ] Assuming zero filled SBK key
[ 0.1970 ]
[ 0.1981 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.1990 ] Assuming zero filled SBK key
[ 0.2143 ]
[ 0.2161 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.2210 ]
[ 0.2383 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.2582 ]
[ 0.2647 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.2662 ] RCM 0 is saved as rcm_0.rcm
[ 0.2770 ] RCM 1 is saved as rcm_1.rcm
[ 0.2771 ] RCM 2 is saved as rcm_2.rcm
[ 0.2771 ] List of rcm files are saved in rcm_list.xml
[ 0.2771 ]
[ 0.2771 ] Signing RCM messages
[ 0.2786 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.2794 ] Assuming zero filled SBK key
[ 0.2800 ]
[ 0.2800 ] Copying signature to RCM mesages
[ 0.2808 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.2826 ]
[ 0.2827 ] Boot Rom communication
[ 0.2835 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 0.2843 ] BR_CID: 0x880219116420f0c12400000009038080
[ 0.2853 ] RCM version 0X190001
[ 0.2856 ] Boot Rom communication completed
[ 1.3044 ]
[ 2.3065 ] tegrarcm_v2 --isapplet
[ 2.3077 ] Applet version 01.00.0000
[ 2.3122 ]
[ 2.3133 ] tegrasign_v2 --key None --getmode mode.txt
[ 2.3145 ] Assuming zero filled SBK key
[ 2.3148 ]
[ 2.3148 ] Parsing partition layout
[ 2.3485 ] tegraparser_v2 --pt flash.xml.tmp
[ 2.3543 ]
[ 2.3543 ] Creating list of images to be signed
[ 2.3557 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 2.3571 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 2.3579 ] Header already present for mb1_t194_prod_sigheader.bin
[ 2.3585 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 2.3633 ] Header already present for mb1_t194_prod_sigheader.bin
[ 2.3639 ] adding BCH for spe_t194.bin
[ 2.3891 ] adding BCH for spe_t194.bin
[ 2.3916 ] adding BCH for nvtboot_t194.bin
[ 2.4017 ] adding BCH for nvtboot_t194.bin
[ 2.4071 ] Header already present for preboot_c10_prod_cr.bin
[ 2.4144 ] Header already present for preboot_c10_prod_cr.bin
[ 2.4148 ] Header already present for mce_c10_prod_cr.bin
[ 2.4327 ] Header already present for mce_c10_prod_cr.bin
[ 2.4348 ] adding BCH for mts_c10_prod_cr.bin
[ 2.4604 ] adding BCH for mts_c10_prod_cr.bin
[ 2.5624 ] adding BCH for cboot_t194.bin
[ 2.6905 ] adding BCH for cboot_t194.bin
[ 2.7049 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 2.7365 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 2.7453 ] adding BCH for tos-trusty_t194.img
[ 2.7547 ] adding BCH for tos-trusty_t194.img
[ 2.7635 ] adding BCH for eks.img
[ 2.7851 ] adding BCH for eks.img
[ 2.7853 ] adding BCH for bpmp_t194.bin
[ 2.7945 ] adding BCH for bpmp_t194.bin
[ 2.8217 ] adding BCH for tegra194-a02-bpmp-p2888-a02.dtb
[ 2.8794 ] adding BCH for tegra194-a02-bpmp-p2888-a02.dtb
[ 2.8985 ] adding BCH for camera-rtcpu-rce.img
[ 2.9187 ] adding BCH for camera-rtcpu-rce.img
[ 2.9265 ] adding BCH for adsp-fw.bin
[ 2.9516 ] adding BCH for adsp-fw.bin
[ 2.9546 ] Header already present for warmboot_t194_prod.bin
[ 2.9587 ] Header already present for warmboot_t194_prod.bin
[ 2.9598 ] adding BCH for boot.img
[ 3.2293 ] adding BCH for boot.img
[ 4.4445 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 5.6607 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 5.9207 ]
[ 5.9208 ] Filling MB1 storage info
[ 5.9208 ] Generating br-bct
[ 5.9226 ] Performing cfg overlay
[ 5.9226 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 5.9236 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1.cfg
[ 6.1394 ]
[ 6.1396 ] Updating dev and MSS params in BR BCT
[ 6.1396 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 6.1901 ]
[ 6.1901 ] Updating bl info
[ 6.1915 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 6.1938 ]
[ 6.1938 ] Generating signatures
[ 6.1950 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 6.1962 ] Assuming zero filled SBK key
[ 6.8722 ]
[ 6.8723 ] Send BCT from Host
[ 6.8723 ] Generating br-bct
[ 6.8738 ] Performing cfg overlay
[ 6.8738 ] ['/home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1.cfg']
[ 6.8738 ] Updating dev and MSS params in BR BCT
[ 6.8739 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 6.9322 ]
[ 6.9323 ] Updating bl info
[ 6.9338 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 6.9379 ]
[ 6.9379 ] Updating smd info
[ 6.9390 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 6.9408 ]
[ 6.9408 ] Get Signed section of bct
[ 6.9420 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 6.9434 ]
[ 6.9444 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 6.9454 ] Assuming zero filled SBK key
[ 6.9457 ]
[ 6.9457 ] Updating BCT with signature
[ 6.9467 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 6.9479 ]
[ 6.9480 ] Generating coldboot mb1-bct
[ 6.9706 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 6.9719 ] MB1-BCT version: 0x1
[ 6.9722 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 6.9729 ] Added Platform Config 0 data with size :- 3008
[ 6.9811 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 6.9816 ] Added Platform Config 1 data with size :- 19640
[ 7.0042 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 7.0048 ] Added Platform Config 2 data with size :- 24
[ 7.0051 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg
[ 7.0059 ] Added Platform Config 4 data with size :- 348
[ 7.0064 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 7.0072 ] Added Platform Config 3 data with size :- 92
[ 7.0211 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 7.0216 ] Added Platform Config 5 data with size :- 56
[ 7.0244 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 7.0249 ] Added Platform Config 7 data with size :- 392
[ 7.0257 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 7.0258 ] Added Platform Config 8 data with size :- 12
[ 7.0258 ]
[ 7.0258 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 7.0258 ] Added Platform Config 9 data with size :- 32
[ 7.0258 ]
[ 7.0259 ] Updating mb1-bct with firmware information
[ 7.0271 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 7.0280 ] MB1-BCT version: 0x1
[ 7.0284 ]
[ 7.0285 ] Updating mb1-bct with storage information
[ 7.0296 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 7.0306 ] MB1-BCT version: 0x1
[ 7.0311 ]
[ 7.0320 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 7.0330 ]
[ 7.0344 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 7.0352 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 7.0362 ]
[ 7.0374 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 7.0382 ] Assuming zero filled SBK key
[ 7.0386 ]
[ 7.0399 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 7.0413 ]
[ 7.0414 ] Generating recovery mb1-bct
[ 7.0425 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 7.0436 ] MB1-BCT version: 0x1
[ 7.0439 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 7.0444 ] Added Platform Config 0 data with size :- 3008
[ 7.0460 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 7.0464 ] Added Platform Config 1 data with size :- 19640
[ 7.0651 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 7.0657 ] Added Platform Config 2 data with size :- 24
[ 7.0660 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg
[ 7.0667 ] Added Platform Config 4 data with size :- 348
[ 7.0671 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 7.0672 ] Added Platform Config 3 data with size :- 92
[ 7.0672 ]
[ 7.0672 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 7.0672 ] Added Platform Config 5 data with size :- 56
[ 7.0673 ]
[ 7.0673 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 7.0673 ] Added Platform Config 7 data with size :- 392
[ 7.0673 ]
[ 7.0673 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 7.0673 ] Added Platform Config 8 data with size :- 12
[ 7.0673 ]
[ 7.0673 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 7.0673 ] Added Platform Config 9 data with size :- 32
[ 7.0673 ]
[ 7.0674 ] Updating mb1-bct with firmware information
[ 7.0685 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 7.0694 ] MB1-BCT version: 0x1
[ 7.0699 ]
[ 7.0699 ] Updating mb1-bct with storage information
[ 7.0709 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 7.0732 ] MB1-BCT version: 0x1
[ 7.0737 ]
[ 7.0748 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 7.0758 ]
[ 7.0766 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 7.0775 ] adding BCH for mb1_bct_MB1.bct
[ 7.0784 ]
[ 7.0796 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 7.0806 ] Assuming zero filled SBK key
[ 7.0808 ]
[ 7.0820 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 7.0836 ]
[ 7.0837 ] Generating coldboot mem-bct
[ 7.0846 ] tegrabct_v2 --chip 0x19 0 --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1.cfg --membct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_1.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_2.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_3.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_4.bct
[ 7.0856 ] Packing sdram param for instance[0]
[ 7.1456 ] Packing sdram param for instance[1]
[ 7.1461 ] Packing sdram param for instance[2]
[ 7.1464 ] Packing sdram param for instance[3]
[ 7.1464 ] Packing sdram param for instance[4]
[ 7.1464 ] Packing sdram param for instance[5]
[ 7.1464 ] Packing sdram param for instance[6]
[ 7.1464 ] Packing sdram param for instance[7]
[ 7.1465 ] Packing sdram param for instance[8]
[ 7.1465 ] Packing sdram param for instance[9]
[ 7.1465 ] Packing sdram param for instance[10]
[ 7.1465 ] Packing sdram param for instance[11]
[ 7.1465 ] Packing sdram param for instance[12]
[ 7.1465 ] Packing sdram param for instance[13]
[ 7.1465 ] Packing sdram param for instance[14]
[ 7.1465 ] Packing sdram param for instance[15]
[ 7.1465 ]
[ 7.1465 ] Getting sector size from pt
[ 7.1478 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 7.1490 ]
[ 7.1490 ] BlockSize read from layout is 200
[ 7.1502 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_1.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_2.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_3.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_4.bct
[ 7.1511 ] adding BCH for /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_1.bct
[ 7.1546 ]
[ 7.1556 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 7.1565 ]
[ 7.1576 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[ 7.1584 ] Header already present for mem_coldboot.bct
[ 7.1589 ]
[ 7.1601 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml
[ 7.1609 ] Assuming zero filled SBK key
[ 7.1614 ]
[ 7.1626 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 7.1642 ]
[ 7.1642 ] Generating recovery mem-bct
[ 7.1651 ] tegrabct_v2 --chip 0x19 0 --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1.cfg --membct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_1.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_2.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_3.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmp96Z7KD1_4.bct
[ 7.1661 ] Packing sdram param for instance[0]
[ 7.2163 ] Packing sdram param for instance[1]
[ 7.2165 ] Packing sdram param for instance[2]
[ 7.2169 ] Packing sdram param for instance[3]
[ 7.2170 ] Packing sdram param for instance[4]
[ 7.2170 ] Packing sdram param for instance[5]
[ 7.2170 ] Packing sdram param for instance[6]
[ 7.2170 ] Packing sdram param for instance[7]
[ 7.2170 ] Packing sdram param for instance[8]
[ 7.2170 ] Packing sdram param for instance[9]
[ 7.2170 ] Packing sdram param for instance[10]
[ 7.2170 ] Packing sdram param for instance[11]
[ 7.2170 ] Packing sdram param for instance[12]
[ 7.2170 ] Packing sdram param for instance[13]
[ 7.2170 ] Packing sdram param for instance[14]
[ 7.2170 ] Packing sdram param for instance[15]
[ 7.2171 ]
[ 7.2185 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 7.2197 ]
[ 7.2208 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 7.2219 ] adding BCH for mem_rcm.bct
[ 7.2236 ]
[ 7.2254 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml
[ 7.2265 ] Assuming zero filled SBK key
[ 7.2268 ]
[ 7.2285 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 7.2306 ]
[ 7.2306 ] Sending BCTs
[ 7.2316 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 7.2325 ] Applet version 01.00.0000
[ 7.2371 ] Sending bct_bootrom
[ 7.2373 ] [................................................] 100%
[ 7.2401 ] Sending bct_mb1
[ 7.2457 ] [................................................] 100%
[ 7.2514 ] Sending bct_mem
[ 7.3020 ] [................................................] 100%
[ 7.4064 ]
[ 7.4065 ] Generating blob
[ 7.4078 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[ 7.4086 ]
[ 7.4095 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[ 7.4104 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[ 7.4298 ]
[ 7.4317 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml
[ 7.4330 ] Assuming zero filled SBK key
[ 7.4336 ]
[ 7.4349 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 7.4411 ]
[ 7.4424 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[ 7.4436 ]
[ 7.4445 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[ 7.4455 ] adding BCH for blob_nvtboot_recovery_t194.bin
[ 7.4511 ]
[ 7.4525 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml
[ 7.4534 ] Assuming zero filled SBK key
[ 7.4538 ]
[ 7.4553 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 7.4593 ]
[ 7.4604 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[ 7.4617 ]
[ 7.4626 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[ 7.4640 ] Header already present for blob_preboot_c10_prod_cr.bin
[ 7.4645 ]
[ 7.4659 ] tegrasign_v2 --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml
[ 7.4668 ] Assuming zero filled SBK key
[ 7.4671 ]
[ 7.4692 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.4709 ]
[ 7.4722 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[ 7.4733 ]
[ 7.4744 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[ 7.4756 ] Header already present for blob_mce_c10_prod_cr.bin
[ 7.4790 ]
[ 7.4806 ] tegrasign_v2 --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml
[ 7.4816 ] Assuming zero filled SBK key
[ 7.4823 ]
[ 7.4838 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.4884 ]
[ 7.4900 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[ 7.4912 ]
[ 7.4925 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[ 7.4937 ] adding BCH for blob_mts_c10_prod_cr.bin
[ 7.6043 ]
[ 7.6059 ] tegrasign_v2 --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml
[ 7.6069 ] Assuming zero filled SBK key
[ 7.6124 ]
[ 7.6145 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.6717 ]
[ 7.6742 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[ 7.6756 ]
[ 7.6765 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --appendsigheader blob_bpmp_t194.bin zerosbk
[ 7.6775 ] adding BCH for blob_bpmp_t194.bin
[ 7.7064 ]
[ 7.7082 ] tegrasign_v2 --key None --list blob_bpmp_t194_sigheader.bin_list.xml
[ 7.7092 ] Assuming zero filled SBK key
[ 7.7105 ]
[ 7.7122 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[ 7.7281 ]
[ 7.7295 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a02.dtb
[ 7.7305 ]
[ 7.7317 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --appendsigheader blob_tegra194-a02-bpmp-p2888-a02.dtb zerosbk
[ 7.7326 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a02.dtb
[ 7.7557 ]
[ 7.7577 ] tegrasign_v2 --key None --list blob_tegra194-a02-bpmp-p2888-a02_sigheader.dtb_list.xml
[ 7.7588 ] Assuming zero filled SBK key
[ 7.7597 ]
[ 7.7614 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a02_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a02_sigheader.dtb.hash zerosbk
[ 7.7746 ]
[ 7.7764 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[ 7.7774 ]
[ 7.7787 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --appendsigheader blob_spe_t194.bin zerosbk
[ 7.7799 ] adding BCH for blob_spe_t194.bin
[ 7.7828 ]
[ 7.7843 ] tegrasign_v2 --key None --list blob_spe_t194_sigheader.bin_list.xml
[ 7.7853 ] Assuming zero filled SBK key
[ 7.7856 ]
[ 7.7869 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[ 7.7896 ]
[ 7.7924 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[ 7.7935 ]
[ 7.7954 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --appendsigheader blob_tos-trusty_t194.img zerosbk
[ 7.7965 ] adding BCH for blob_tos-trusty_t194.img
[ 7.8089 ]
[ 7.8107 ] tegrasign_v2 --key None --list blob_tos-trusty_t194_sigheader.img_list.xml
[ 7.8117 ] Assuming zero filled SBK key
[ 7.8123 ]
[ 7.8145 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[ 7.8219 ]
[ 7.8230 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[ 7.8240 ]
[ 7.8248 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --appendsigheader blob_eks.img zerosbk
[ 7.8256 ] adding BCH for blob_eks.img
[ 7.8259 ]
[ 7.8269 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 7.8278 ] Assuming zero filled SBK key
[ 7.8281 ]
[ 7.8296 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 7.8308 ]
[ 7.8320 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[ 7.8331 ]
[ 7.8342 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 7.8352 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[ 7.8455 ]
[ 7.8477 ] tegrasign_v2 --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml
[ 7.8488 ] Assuming zero filled SBK key
[ 7.8497 ]
[ 7.8514 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 7.8581 ]
[ 7.8597 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 7.8606 ] number of images in blob are 11
[ 7.8610 ] blobsize is 6080040
[ 7.8612 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 236320
[ 7.8646 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 129808
[ 7.8654 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 23968
[ 7.8663 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 144144
[ 7.8671 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3372048
[ 7.8680 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 853856
[ 7.8688 ] Added binary blob_tegra194-a02-bpmp-p2888-a02_sigheader.dtb.encrypt of size 609952
[ 7.8697 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[ 7.8704 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 324608
[ 7.8712 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[ 7.8720 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 285056
[ 7.8728 ]
[ 7.8728 ] Sending bootloader and pre-requisite binaries
[ 7.8742 ] tegrarcm_v2 --download blob blob.bin
[ 7.8751 ] Applet version 01.00.0000
[ 7.8842 ] Sending blob
[ 7.8844 ] [................................................] 100%
[ 8.7495 ]
[ 8.7511 ] tegrarcm_v2 --boot recovery
[ 8.7523 ] Applet version 01.00.0000
[ 8.7617 ]
[ 9.7644 ] tegrarcm_v2 --isapplet
[ 10.0390 ]
[ 10.0405 ] tegrarcm_v2 --ismb2
[ 10.0463 ]
[ 10.0592 ] tegradevflash_v2 --iscpubl
[ 10.0604 ] Bootloader version 01.00.0000
[ 10.0704 ] Bootloader version 01.00.0000
[ 10.0744 ]
[ 10.0745 ] Writing partition
[ 10.0757 ] tegradevflash_v2 --erase /sdmmc_boot/3/
[ 10.0766 ] Bootloader version 01.00.0000
[ 10.0814 ] [Done]
[ 11.2318 ]
[ 11.2319 ] Generating RCM messages
[ 11.2336 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 11.2348 ] Header already present for mb1_t194_prod.bin
[ 11.2411 ]
[ 11.2423 ] tegrasign_v2 --key None --getmode mode.txt
[ 11.2435 ] Assuming zero filled SBK key
[ 11.2437 ]
[ 11.2450 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 11.2464 ] Assuming zero filled SBK key
[ 11.2471 ]
[ 11.2483 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 11.2530 ]
[ 11.2546 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 11.2564 ]
[ 11.2577 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 11.2589 ] RCM 0 is saved as rcm_0.rcm
[ 11.2640 ] RCM 1 is saved as rcm_1.rcm
[ 11.2641 ] RCM 2 is saved as rcm_2.rcm
[ 11.2641 ] List of rcm files are saved in rcm_list.xml
[ 11.2641 ]
[ 11.2641 ] Signing RCM messages
[ 11.2656 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 11.2671 ] Assuming zero filled SBK key
[ 11.2682 ]
[ 11.2682 ] Copying signature to RCM mesages
[ 11.2694 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 11.2711 ]
[ 11.2712 ] Boot Rom communication
[ 11.2725 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 11.2734 ] BootRom is not running
[ 16.3981 ]
[ 17.4009 ] tegrarcm_v2 --isapplet
[ 17.4069 ]
[ 17.4085 ] tegrarcm_v2 --ismb2
[ 17.4146 ]
[ 17.4164 ] tegradevflash_v2 --iscpubl
[ 17.4180 ] Bootloader version 01.00.0000
[ 17.4227 ] Bootloader version 01.00.0000
[ 17.4269 ]
[ 17.4294 ] tegrasign_v2 --key None --getmode mode.txt
[ 17.4308 ] Assuming zero filled SBK key
[ 17.4311 ]
[ 17.4312 ] Parsing partition layout
[ 17.4327 ] tegraparser_v2 --pt flash.xml.tmp
[ 17.4354 ]
[ 17.4355 ] Creating list of images to be signed
[ 17.4368 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 17.4380 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 17.4392 ] Header already present for mb1_t194_prod_sigheader.bin
[ 17.4400 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 17.4448 ] Header already present for mb1_t194_prod_sigheader.bin
[ 17.4455 ] adding BCH for spe_t194.bin
[ 17.4490 ] adding BCH for spe_t194.bin
[ 17.4518 ] adding BCH for nvtboot_t194.bin
[ 17.4552 ] adding BCH for nvtboot_t194.bin
[ 17.4607 ] Header already present for preboot_c10_prod_cr.bin
[ 17.4661 ] Header already present for preboot_c10_prod_cr.bin
[ 17.4666 ] Header already present for mce_c10_prod_cr.bin
[ 17.4670 ] Header already present for mce_c10_prod_cr.bin
[ 17.4686 ] adding BCH for mts_c10_prod_cr.bin
[ 17.4728 ] adding BCH for mts_c10_prod_cr.bin
[ 17.5759 ] adding BCH for cboot_t194.bin
[ 17.6786 ] adding BCH for cboot_t194.bin
[ 17.6927 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 17.7087 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 17.7184 ] adding BCH for tos-trusty_t194.img
[ 17.7272 ] adding BCH for tos-trusty_t194.img
[ 17.7369 ] adding BCH for eks.img
[ 17.7485 ] adding BCH for eks.img
[ 17.7488 ] adding BCH for bpmp_t194.bin
[ 17.7499 ] adding BCH for bpmp_t194.bin
[ 17.7770 ] adding BCH for tegra194-a02-bpmp-p2888-a02.dtb
[ 17.8047 ] adding BCH for tegra194-a02-bpmp-p2888-a02.dtb
[ 17.8237 ] adding BCH for camera-rtcpu-rce.img
[ 17.8436 ] adding BCH for camera-rtcpu-rce.img
[ 17.8529 ] adding BCH for adsp-fw.bin
[ 17.8614 ] adding BCH for adsp-fw.bin
[ 17.8652 ] Header already present for warmboot_t194_prod.bin
[ 17.8695 ] Header already present for warmboot_t194_prod.bin
[ 17.8706 ] adding BCH for boot.img
[ 17.8992 ] adding BCH for boot.img
[ 19.0897 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 20.2727 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 20.5229 ]
[ 20.5229 ] Filling MB1 storage info
[ 20.5229 ] Generating br-bct
[ 20.5247 ] Performing cfg overlay
[ 20.5247 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 20.5249 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1.cfg
[ 20.5850 ]
[ 20.5851 ] Updating dev and MSS params in BR BCT
[ 20.5852 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 20.6378 ]
[ 20.6379 ] Updating bl info
[ 20.6392 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 20.6419 ]
[ 20.6419 ] Generating signatures
[ 20.6430 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 20.6440 ] Assuming zero filled SBK key
[ 21.4166 ]
[ 21.4166 ] Send BCT from Host
[ 21.4166 ] Generating br-bct
[ 21.4177 ] Performing cfg overlay
[ 21.4177 ] ['/home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1.cfg']
[ 21.4177 ] Updating dev and MSS params in BR BCT
[ 21.4178 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 21.4694 ]
[ 21.4695 ] Updating bl info
[ 21.4706 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 21.4739 ]
[ 21.4739 ] Updating smd info
[ 21.4751 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 21.4763 ]
[ 21.4764 ] Get Signed section of bct
[ 21.4774 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 21.4787 ]
[ 21.4797 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 21.4807 ] Assuming zero filled SBK key
[ 21.4810 ]
[ 21.4810 ] Updating BCT with signature
[ 21.4819 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 21.4833 ]
[ 21.4833 ] Generating coldboot mb1-bct
[ 21.4845 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 21.4856 ] MB1-BCT version: 0x1
[ 21.4859 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 21.4864 ] Added Platform Config 0 data with size :- 3008
[ 21.4881 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 21.4886 ] Added Platform Config 1 data with size :- 19640
[ 21.5068 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 21.5075 ] Added Platform Config 2 data with size :- 24
[ 21.5079 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg
[ 21.5084 ] Added Platform Config 4 data with size :- 348
[ 21.5087 ]
[ 21.5087 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 21.5087 ] Added Platform Config 3 data with size :- 92
[ 21.5087 ]
[ 21.5088 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 21.5088 ] Added Platform Config 5 data with size :- 56
[ 21.5088 ]
[ 21.5088 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 21.5088 ] Added Platform Config 7 data with size :- 392
[ 21.5088 ]
[ 21.5088 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 21.5088 ] Added Platform Config 8 data with size :- 12
[ 21.5088 ]
[ 21.5088 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 21.5088 ] Added Platform Config 9 data with size :- 32
[ 21.5088 ]
[ 21.5089 ] Updating mb1-bct with firmware information
[ 21.5101 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 21.5112 ] MB1-BCT version: 0x1
[ 21.5117 ]
[ 21.5117 ] Updating mb1-bct with storage information
[ 21.5126 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 21.5136 ] MB1-BCT version: 0x1
[ 21.5142 ]
[ 21.5157 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 21.5170 ]
[ 21.5185 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 21.5198 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 21.5209 ]
[ 21.5223 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 21.5232 ] Assuming zero filled SBK key
[ 21.5236 ]
[ 21.5250 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 21.5265 ]
[ 21.5266 ] Generating recovery mb1-bct
[ 21.5277 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 21.5288 ] MB1-BCT version: 0x1
[ 21.5292 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 21.5304 ] Added Platform Config 0 data with size :- 3008
[ 21.5317 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 21.5326 ] Added Platform Config 1 data with size :- 19640
[ 21.5492 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 21.5502 ] Added Platform Config 2 data with size :- 24
[ 21.5507 ]
[ 21.5508 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-p2822-0000.cfg
[ 21.5508 ] Added Platform Config 4 data with size :- 348
[ 21.5508 ]
[ 21.5508 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 21.5508 ] Added Platform Config 3 data with size :- 92
[ 21.5508 ]
[ 21.5508 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 21.5508 ] Added Platform Config 5 data with size :- 56
[ 21.5508 ]
[ 21.5509 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 21.5509 ] Added Platform Config 7 data with size :- 392
[ 21.5509 ]
[ 21.5509 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 21.5509 ] Added Platform Config 8 data with size :- 12
[ 21.5509 ]
[ 21.5509 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 21.5509 ] Added Platform Config 9 data with size :- 32
[ 21.5509 ]
[ 21.5510 ] Updating mb1-bct with firmware information
[ 21.5524 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 21.5533 ] MB1-BCT version: 0x1
[ 21.5537 ]
[ 21.5537 ] Updating mb1-bct with storage information
[ 21.5547 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 21.5560 ] MB1-BCT version: 0x1
[ 21.5565 ]
[ 21.5577 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 21.5588 ]
[ 21.5601 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 21.5612 ] adding BCH for mb1_bct_MB1.bct
[ 21.5623 ]
[ 21.5641 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 21.5650 ] Assuming zero filled SBK key
[ 21.5654 ]
[ 21.5671 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 21.5689 ]
[ 21.5690 ] Generating coldboot mem-bct
[ 21.5701 ] tegrabct_v2 --chip 0x19 0 --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1.cfg --membct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_1.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_2.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_3.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_4.bct
[ 21.5712 ] Packing sdram param for instance[0]
[ 21.6321 ] Packing sdram param for instance[1]
[ 21.6324 ] Packing sdram param for instance[2]
[ 21.6327 ] Packing sdram param for instance[3]
[ 21.6327 ] Packing sdram param for instance[4]
[ 21.6327 ] Packing sdram param for instance[5]
[ 21.6327 ] Packing sdram param for instance[6]
[ 21.6327 ] Packing sdram param for instance[7]
[ 21.6327 ] Packing sdram param for instance[8]
[ 21.6328 ] Packing sdram param for instance[9]
[ 21.6328 ] Packing sdram param for instance[10]
[ 21.6328 ] Packing sdram param for instance[11]
[ 21.6328 ] Packing sdram param for instance[12]
[ 21.6328 ] Packing sdram param for instance[13]
[ 21.6328 ] Packing sdram param for instance[14]
[ 21.6328 ] Packing sdram param for instance[15]
[ 21.6328 ]
[ 21.6328 ] Getting sector size from pt
[ 21.6339 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 21.6352 ]
[ 21.6353 ] BlockSize read from layout is 200
[ 21.6363 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_1.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_2.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_3.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_4.bct
[ 21.6374 ] adding BCH for /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_1.bct
[ 21.6416 ]
[ 21.6429 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 21.6442 ]
[ 21.6455 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[ 21.6468 ] Header already present for mem_coldboot.bct
[ 21.6475 ]
[ 21.6491 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml
[ 21.6499 ] Assuming zero filled SBK key
[ 21.6507 ]
[ 21.6526 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 21.6541 ]
[ 21.6542 ] Generating recovery mem-bct
[ 21.6553 ] tegrabct_v2 --chip 0x19 0 --sdram /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1.cfg --membct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_1.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_2.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_3.bct /home/carol/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310-TX2/Linux_for_Tegra/bootloader/18924/tmpbZS04E1_4.bct
[ 21.6565 ] Packing sdram param for instance[0]
[ 21.7065 ] Packing sdram param for instance[1]
[ 21.7069 ] Packing sdram param for instance[2]
[ 21.7072 ] Packing sdram param for instance[3]
[ 21.7072 ] Packing sdram param for instance[4]
[ 21.7072 ] Packing sdram param for instance[5]
[ 21.7072 ] Packing sdram param for instance[6]
[ 21.7072 ] Packing sdram param for instance[7]
[ 21.7072 ] Packing sdram param for instance[8]
[ 21.7072 ] Packing sdram param for instance[9]
[ 21.7073 ] Packing sdram param for instance[10]
[ 21.7073 ] Packing sdram param for instance[11]
[ 21.7073 ] Packing sdram param for instance[12]
[ 21.7073 ] Packing sdram param for instance[13]
[ 21.7073 ] Packing sdram param for instance[14]
[ 21.7073 ] Packing sdram param for instance[15]
[ 21.7073 ]
[ 21.7088 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 21.7098 ]
[ 21.7107 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 21.7118 ] adding BCH for mem_rcm.bct
[ 21.7137 ]
[ 21.7153 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml
[ 21.7163 ] Assuming zero filled SBK key
[ 21.7167 ]
[ 21.7182 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 21.7200 ]
[ 21.7201 ] Sending BCTs
[ 21.7210 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 21.7222 ] Applet is not running on device. Continue with Bootloader
[ 21.7268 ]
[ 21.7269 ] Generating blob
[ 21.7282 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[ 21.7295 ]
[ 21.7307 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[ 21.7319 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[ 21.7407 ]
[ 21.7423 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml
[ 21.7431 ] Assuming zero filled SBK key
[ 21.7439 ]
[ 21.7454 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 21.7505 ]
[ 21.7519 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[ 21.7529 ]
[ 21.7541 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[ 21.7553 ] adding BCH for blob_nvtboot_recovery_t194.bin
[ 21.7603 ]
[ 21.7622 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml
[ 21.7633 ] Assuming zero filled SBK key
[ 21.7638 ]
[ 21.7653 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 21.7683 ]
[ 21.7695 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[ 21.7706 ]
[ 21.7717 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[ 21.7726 ] Header already present for blob_preboot_c10_prod_cr.bin
[ 21.7731 ]
[ 21.7744 ] tegrasign_v2 --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml
[ 21.7752 ] Assuming zero filled SBK key
[ 21.7759 ]
[ 21.7776 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 21.7800 ]
[ 21.7813 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[ 21.7827 ]
[ 21.7840 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[ 21.7850 ] Header already present for blob_mce_c10_prod_cr.bin
[ 21.7878 ]
[ 21.7893 ] tegrasign_v2 --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml
[ 21.7905 ] Assuming zero filled SBK key
[ 21.7915 ]
[ 21.7936 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 21.7989 ]
[ 21.8005 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[ 21.8021 ]
[ 21.8035 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[ 21.8051 ] adding BCH for blob_mts_c10_prod_cr.bin
[ 21.9167 ]
[ 21.9182 ] tegrasign_v2 --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml
[ 21.9193 ] Assuming zero filled SBK key
[ 21.9245 ]
[ 21.9263 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 21.9817 ]
[ 21.9832 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[ 21.9846 ]
[ 21.9859 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --appendsigheader blob_bpmp_t194.bin zerosbk
[ 21.9869 ] adding BCH for blob_bpmp_t194.bin
[ 22.0147 ]
[ 22.0169 ] tegrasign_v2 --key None --list blob_bpmp_t194_sigheader.bin_list.xml
[ 22.0178 ] Assuming zero filled SBK key
[ 22.0192 ]
[ 22.0211 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[ 22.0366 ]
[ 22.0382 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a02.dtb
[ 22.0395 ]
[ 22.0409 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --appendsigheader blob_tegra194-a02-bpmp-p2888-a02.dtb zerosbk
[ 22.0420 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a02.dtb
[ 22.0603 ]
[ 22.0621 ] tegrasign_v2 --key None --list blob_tegra194-a02-bpmp-p2888-a02_sigheader.dtb_list.xml
[ 22.0633 ] Assuming zero filled SBK key
[ 22.0652 ]
[ 22.0668 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a02_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a02_sigheader.dtb.hash zerosbk
[ 22.0771 ]
[ 22.0785 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[ 22.0797 ]
[ 22.0810 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --appendsigheader blob_spe_t194.bin zerosbk
[ 22.0820 ] adding BCH for blob_spe_t194.bin
[ 22.0855 ]
[ 22.0876 ] tegrasign_v2 --key None --list blob_spe_t194_sigheader.bin_list.xml
[ 22.0888 ] Assuming zero filled SBK key
[ 22.0895 ]
[ 22.0914 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[ 22.0949 ]
[ 22.0964 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[ 22.0976 ]
[ 22.0989 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --appendsigheader blob_tos-trusty_t194.img zerosbk
[ 22.1002 ] adding BCH for blob_tos-trusty_t194.img
[ 22.1124 ]
[ 22.1142 ] tegrasign_v2 --key None --list blob_tos-trusty_t194_sigheader.img_list.xml
[ 22.1152 ] Assuming zero filled SBK key
[ 22.1160 ]
[ 22.1178 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[ 22.1261 ]
[ 22.1275 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[ 22.1288 ]
[ 22.1301 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --appendsigheader blob_eks.img zerosbk
[ 22.1312 ] adding BCH for blob_eks.img
[ 22.1316 ]
[ 22.1330 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 22.1345 ] Assuming zero filled SBK key
[ 22.1348 ]
[ 22.1367 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 22.1381 ]
[ 22.1394 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[ 22.1406 ]
[ 22.1420 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 22.1433 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[ 22.1551 ]
[ 22.1574 ] tegrasign_v2 --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml
[ 22.1588 ] Assuming zero filled SBK key
[ 22.1597 ]
[ 22.1619 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 22.1711 ]
[ 22.1730 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 22.1740 ] number of images in blob are 11
[ 22.1745 ] blobsize is 6080040
[ 22.1748 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 236320
[ 22.1773 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 129808
[ 22.1780 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 23968
[ 22.1788 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 144144
[ 22.1797 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3372048
[ 22.1805 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 853856
[ 22.1812 ] Added binary blob_tegra194-a02-bpmp-p2888-a02_sigheader.dtb.encrypt of size 609952
[ 22.1819 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[ 22.1823 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 324608
[ 22.1828 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[ 22.1834 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 285056
[ 22.1872 ]
[ 22.1873 ] Sending bootloader and pre-requisite binaries
[ 22.1885 ] tegrarcm_v2 --download blob blob.bin
[ 22.1896 ] Applet is not running on device. Continue with Bootloader
[ 22.1942 ]
[ 22.1955 ] tegrarcm_v2 --boot recovery
[ 22.1963 ] Applet is not running on device. Continue with Bootloader
[ 22.2009 ]
[ 23.2033 ] tegrarcm_v2 --isapplet
[ 23.2088 ]
[ 23.2102 ] tegrarcm_v2 --ismb2
[ 23.2158 ]
[ 23.2172 ] tegradevflash_v2 --iscpubl
[ 23.2186 ] Bootloader version 01.00.0000
[ 23.2233 ] Bootloader version 01.00.0000
[ 23.2272 ]
[ 23.2273 ] Writing partition
[ 23.2288 ] tegradevflash_v2 --erase /sdmmc_user/3/
[ 23.2299 ] Bootloader version 01.00.0000
[ 23.2346 ] [Done]
[ 24.1929 ]
Hi WanyeWWW
We tried now with the DevKit and JetPack 4.2.1 without success, we still get the error:
[ 35.5172 ] Sending bct_mb1
[ 35.5197 ] […] 100%
[ 35.5271 ] 000000001d1d0f18: E> LOADER: Failed to verify SHA2 of binary mb1bct.
[ 35.5459 ]
[ 35.5460 ]
Error: Return value 24
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Can you flash your board with jetpack4.2.1 first and then run the command? Do not use a fresh release to directly do this format.
Hi WayneWWW
We already did that, as otherwise files were missing in the bootloader folder to run the command.
Could you paste the full flash log from both your host and the uart?
And just want to say something to this bug.
Actually, I cannot guarantee what is the “factory status” for each module. I believe some devices have empty emmc but some devices have garbage content on it.
We also have some users who don’t need to reflash the board on his first un-box device to make device boot up.
As for the command to erase the emmc, as I said, please do not just copy my command, you need to figure out what parameters that can work on your board. You can also check your full flash log and see if you have below keywords
"–cmd “erase /sdmmc_boot/3/; erase /sdmmc_user/3/”
If you see this in the log, copy that tegraflash.py command and use it for your board.
