I have a matrix (float*) of size width*height.
I’d like to sort each column independently.
So I’d like to use quicksort, but a modified version.
I use a 1D grid where each thread correspons to one column.
Each thread use the modified quicksort.
The quicksort algorithm use recursive function.
I paste the code bellow.
The problem is that I cannot compile this code.
Thanks for your help =)
Vince
__device__ int partition(float* a, int w, int l, int r) {
float pivot, t;
int i, j;
pivot = a[l*w];
i = l; j = r+1;
while(1)
do ++i; while( a[i*w] <= pivot && i <= r );
do --j; while( a[j*w] > pivot );
if( i >= j ) break;
t = a[i*w]; a[i*w] = a[j*w]; a[j*w] = t;
t = a[l*w]; a[l*w] = a[j*w]; a[j*w] = t;
return j;
__device__ void quickSort(float* a, int w, int l, int r)
int j;
if( l < r )
// divide and conquer
j = partition( a, w, l, r);
quickSort( a, w, l, j-1);
quickSort( a, w, j+1, r);
// Sort the column of matric tab.
__global__ void cuParallelQuickSort(float *tab, int width, int height, int pitch){
unsigned int xIndex = blockIdx.x * BLOCK_DIM + threadIdx.x;
if (xIndex<width){
quickSort(&tab[xIndex], width, 0, height-1);
