Qwen3.8-27B at 34–38 tok/s on DGX Spark — open-source one-command setup (SGLang + NVFP4 + DSpark)
Thank you as well for the opencode config; I’d abandoned the 27B model earlier because I could only get usable throughput with dflash2 and dflash2 routinely led to hangs in opencode / model execution drops as contexts grew beyond about 64k.
I want to point hermes agent harness as the LLM and wonder if its also wise to the use the opencode port, to avoid similar long-context issues there?
Looks like new cuda stack improve nvfp4 performance
Ubunti 26.04 KMD Version: 610.57.04 CUDA UMD Version: 13.3
│    Model:  qwen3.8-27b        │
│    Score:  91 / 100        │
│    Rating: ★★★★★ Excellent        │
│    Benchmark: tool-eval-bench v2.6.1.dev45+gcf54b4bfe        │
│    Engine:       SGLang        │
│    Quantization: GGUF        │
│    ✅ 73 passed   ⚠️  14 partial   ❌ 1 failed        │
│    Points: 160/176        │
│    Quality:        91/100        │
│    Responsiveness: 50/100  (median turn: 3.0s)        │
│    Deployability:  79/100  (α=0.7)        │
│    Weakest: M Autonomous Planning (67%)        │
│    Completed in 1029.5s        │
│    📊 Token Usage:        │
│    Total: 617,451 tokens  │  Efficiency: 0.3 pts/1K tokens        │
│    ⚡ Throughput:        │
│    Single:  2,697 pp t/s  │  36.3 tg t/s  │  TTFT 3,886ms        │
│    c2:      2,477 pp t/s  │  65.6 tg t/s        │
│    c4:      1,927 pp t/s  │  58.4 tg t/s
pont@pont-GX10:~/git/dgx-spark-qwen38$ PORT=9090 ./bench.sh
Qwen3.8-27B NVFP4+DFlash2 benchmark (batch 1 decode)
reference box (DFlash2 v1.2+): ~50 greedy median (code 41-47 / reasoning 52-57 / math peak 50-60 / free prose ~23)
  code (greedy, deterministic): 51.0 / 51.3 tok/s
  reasoning (greedy, deterministic): 58.2 / 60.7 tok/s
  math peak (temp 0.6, like SGLang's eval setting): 69.3 / 67.8 tok/s
  free prose (greedy, worst-case, excluded from median): 23.2 / 23.3 tok/s
  greedy median: 54.8 tok/s
  (numbers vary with content: acceptance length drives everything;
   math/code accept ~3.3-5.6 tokens/step, free prose ~1.5-2.2 in any
   language, see BENCHMARKS.md)
is this sglang main?
This is the one I’m currently using. Due to previous issues with Qwen 3.8 Next Flash, I fall back to using Qwen 3.8 27B.
On a single concurrency, I was getting approximately 36-40 tok/s , this is agentic workflow, python coding + bash, automations. I was getting almost 80 tok/s batch or multiconcurrency. (Hermes, Unsloth (using DGX Spark for API, DeepSeek Harness). So that’s amazing for in terms of performance. I fell back to mainly using DSH because Unsloth Studio felt slower and Hermes (Telegram) doesn’t show me the full dialog.
Unfortunately, the “intelligence” of Qwen 3.8 27B was telling, it might be able to do a single HTML "duck walking in the park " animation but it was having problem with writing properly working scripts to perform orchestrations across different systems and devices.
I had to fall back to using DeepSeek v4 Flash (Local and Cloud), then DeepSeek v4 Pro and Ultimately OpenAI models, which finally closed the gaps and fixed the issues.
Apologies for the possibly trivial question, but I don’t understand how to use the dashboard on port 30090. I run qwen3.8-flash-next and v1.13. Could someone point me in the right direction?
The address is not something you have to guess, it is whatever the cockpit is bound to. Run this on the box:
ss -ltnp | grep 30090
What you see on the left of `:30090` is the address to type in your browser.
- **`100.x.y.z:30090`** (a tailnet address) → open `http://100.x.y.z:30090` from any device on your tailnet. This is the default when the box has Tailscale.
- **`0.0.0.0:30090`** → it listens on every interface, so use the box’s own IP. `hostname -I` prints them, take the LAN one (usually `192.168.x.x`).
- **`127.0.0.1:30090`** → the box itself only, which is the fallback when there is no tailnet. Either open it in a browser running on the box, or re-bind and then use the LAN IP:
cd ~/dgx-spark-qwen38
DASH_BIND=0.0.0.0 dashboard/install-dashboard.sh
- **nothing printed** → the cockpit is not installed. It only ships automatically since v1.12, so a box first installed before that and updated later will not have it:
cd ~/dgx-spark-qwen38 && dashboard/install-dashboard.sh
The login is a single field, no username: paste the API key from `~/.config/qwen38/api-key`.
It is plain HTTP, so keep it on a LAN or a tailnet you trust. Nothing differs for `qwen3.8-flash-next`, the cockpit reads whichever unit is actually running.
127.0.0.1 instead of 0.0.0.0 - my worst enemy :) DASH_BIND=0.0.0.0 dashboard/install-dashboard.sh did the trick, thanks. BTW, really nice dashboard.
Update, October 2026: this first post describes the August setup, and the project has moved on. It now serves nine measured lanes (Qwen3.8-27B at 71.4 tok/s greedy median with a 1M context, Nemotron 3.5 Bolt, Flash-Next 176B, images, video with sound), OpenAI and Anthropic APIs and a local cockpit, on 128 GB and 64 GB boxes. Guides and every number with its method: https://hasso5703.github.io/
[DGX Spark / GB10 Unified Memory] Persistent OOM hard-reboots during large prefill bursts — NV_ERR_NO_MEMORY from _memdescAllocInternal — seeking guidance on memory budgeting
System: NVIDIA DGX Spark (GB10 Grace Blackwell SoC)
Memory: 120 GiB unified (CPU + GPU share physical RAM — no discrete VRAM)
Architecture: ARM64 (aarch64)
Kernel: 6.17.0-1031-nvidia
SGLang version: Container lmsysorg/sglang (v1.2.2 equivalent, with DFlash2 speculative support)
Model: Qwen3-8-27B in NVFP4 quantization + DFlash speculative decoding
Problem
We are experiencing persistent hard reboots (not graceful crashes) on our DGX Spark when SGLang processes a large prefill batch. Over the past 25 days we have recorded 20 reboots (journalctl --list-boots count), with the frequency accelerating: 5 reboots in the last 2 days (Nov 2–3, 2026).
The machine never soft-panics or logs a clean Python traceback — the kernel logs NVRM NV_ERR_NO_MEMORY errors and then the system performs a hard reset.
Exact Crash Evidence (last OOM, Nov 03 ~11:32 local)
From journalctl -b -1 --no-pager -k | grep -i 'oom\|nvrm\|memory\|error':
Nov 03 11:32:42 spark-name kernel: NVRM: Xid (PCI:0001:00:00): 13, pid='<unknown>', name=<unknown>, Graphics Exception: ESR 0x50a118=0x215f (ILLEGAL_INSTR_ENCODING)
Nov 03 11:32:43 spark-name kernel: NVRM: os_schedule: NV_ERR_NO_MEMORY from _memdescAllocInternal (mem_desc.c:1359)
[... 9 consecutive NV_ERR_NO_MEMORY lines within 17 seconds ...]
Nov 03 11:32:59 spark-3a4d kernel: [hard reset]
From SGLang Python logs immediately before the crash:
[2026-11-03 11:32:40] Scheduler prefill batch. #new-token: 7136, ...
[2026-11-03 11:32:40] #running-req: 2, #token: 32482, token usage: 0.54, ...
[2026-11-03 11:32:40] full token usage: 0.54
The scheduler had 2 concurrent requests with a combined prefill of 7,136 new tokens at a token usage of 0.54 (54%) of the KV pool, then immediately crashed.
SGLang Configuration
Current /etc/systemd/system/qwen38-sglang.service (ExecStart excerpt):
docker run --rm --network host \
  --runtime nvidia \
  --gpus all \
  --shm-size 32g \
  --name qwen38-sglang \
  -v /home/aerodgx/sglang/models:/models \
  qwen38-dflash2:v1.2.2 \
  python -m sglang.launch_server \
    --model-path /models/Qwen3-8-27B-NVFP4 \
    --served-model-name qwen3.8-27b \
    --host 0.0.0.0 \
    --port 30000 \
    --mem-fraction-static 0.45 \
    --memory 115g \
    --memory-swap 115g \
    --max-mamba-cache-size 24 \
    --max-running-requests 4 \
    --chunked-prefill-size 8192 \
    --speculative-algorithm DFLASH \
    --speculative-draft-model-path /models/Qwen3-8-DFLASH \
    --speculative-num-steps 5 \
    --speculative-dflash-topk 4 \
    --speculative-num-draft-tokens 20
Key parameters:
  • --mem-fraction-static 0.45 → ~54 GiB reserved for static KV pool
  • --chunked-prefill-size 8192
  • --max-prefill-tokens → not explicitly set (default: 16384)
  • --max-running-requests 4
  • Docker --memory 115g (soft Docker cap)
Questions
1. Does mem_fraction_static only cover the static KV pool?
We understand that mem_fraction_static reserves memory for the pre‑allocated KV cache. But on a GB10 unified memory system, do dynamic activation tensors during prefill (Q, K, V projections, attention scores, MLP intermediates) still draw from the same unified physical RAM outside that static fraction?
If yes, that explains the crash: at token_usage=0.54, the static pool is only 54% full (plenty of KV room), but the prefill activation burst for 7,136 tokens simultaneously exceeded whatever remained in the unified memory pool.
2. Is there a way to cap the peak activation memory during prefill?
Options we have considered:
  • --chunked-prefill-size 4096 (down from 8192) — halves the per‑chunk activation footprint
  • --max-prefill-tokens 4096 (new flag, down from default 16384) — limits total tokens in one prefill pass
  • --mem-fraction-static 0.42 (down from 0.45) — frees ~3.6 GiB of physical memory for dynamic allocations
Are these the right levers? Are there other flags (e.g., --max-prefill-tokens, --disable‑chunked‑prefill, --max‑total‑tokens) that more directly cap the activation memory peak?
3. DFlash speculative + unified memory — known issues?
The DFlash speculative decoding (--speculative-algorithm DFLASH) loads a draft model that also occupies unified memory. On a 120 GiB GB10:
  • Is the draft model memory counted inside mem_fraction_static?
  • Or does it compete for the remaining ~66 GiB (the “host” portion)?
  • Are there known OOM issues when draft model activations and main model activations overlap during a speculative prefill?
4. kdump doesn’t capture these crashes — expected?
We have kdump enabled (kdump‑tools systemd service, crashkernel=1G-:1024M in kernel cmdline, pstoreconfigured). However, pstore remains empty after every crash. The hard reset appears to happen at the hardware/NVRM driver level before the kernel can initiate kdump. Is this a known limitation for NVRM OOM on GB10 unified memory?
Context: DGX Spark Unified Memory Architecture
The GB10 SoC shares one physical 120 GiB LPDDR5x pool between CPU and GPU. There is no PCIe bus, no VRAM/system‑RAM boundary, and no pinned GPU memory transfer. This means:
  • The GPU “sees” the entire 120 GiB as addressable, but the CPU OS also uses it.
  • mem_fraction_static=0.45 → ~54 GiB pre‑allocated for KV cache.
  • Remaining ~66 GiB is split between: OS (~2 GiB), containers (comfyUI ~1.5 GiB, hermes‑spark ~0.5 GiB, n8n ~0.5 GiB, Ollama CPU‑only ~1 GiB), and SGLang scheduler Python process (~5 GiB RSS).
  • At the moment of the crash: ~72 GiB used / 120 GiB, 12 GiB free in host‑visible RAM.
  • The 7,136‑token prefill burst at token_usage=0.54 appears to need more than 12 GiB of dynamic activation space momentarily, blowing through that headroom.
Proposed Fix (pending community feedback)
Before applying, we want to confirm our theory is correct:
# In qwen38-sglang.service ExecStart:
--chunked-prefill-size 4096 \
--max-prefill-tokens 4096 \
--mem-fraction-static 0.42 \
--memory 108g --memory-swap 108g \
Expected effect: prefill bursts are chunked to 4,096 tokens at a time, peak activation ~50% lower, with 3–4 additional GiB freed for dynamic allocations.
What We’ve Already Tried
  • Deleted all large Ollama models (removed nemotron 120B, llama 70B, qwen 32B/14B, gemma2 9B) — reduced idle host memory footprint by ~8 GiB.
  • Reduced Docker --memory from 120g → 115g.
  • Reduced --max-running-requests to 4.
  • Configured kdump — does not capture the crash (see Q4 above).
None of these prevented the OOM reboots. The pattern points specifically to the prefill burst activation memory, not steady‑state KV cache usage.
System Info
$ uname -a
Linux spark-name 6.17.0-1031-nvidia #31-Ubuntu SMP PREEMPT_DYNAMIC aarch64 GNU/Linux
$ free -h (at time of crash boot):
               total        used        free      shared  buff/cache   available
Mem:           120Gi        72Gi        12Gi       1.0Gi        36Gi        47Gi
Swap:           63Gi          0B        63Gi
# NVIDIA GB10 SoC — 120 GiB unified memory, no discrete VRAM counter in nvidia-smi
Any guidance on the correct parameters to cap prefill activation memory on unified memory ARM SoCs would be greatly appreciated. Thank you.
Hi Fabian, thanks for the detailed report, it makes this easy to read. Three things stand out.
You are on v1.2.2, from August 20. qwen38-dflash2:v1.2.2 is the DFlash2 image that version of this project built on the box. The project is at v1.42.1 today, 1,144 commits later. That version had no cockpit (it ships with every install since v1.12) and nothing that says a newer release is out (the cockpit has done that since v1.15.2), so there was no way for you to know. Your unit also differs from the one v1.2.2 installed: that one ran --memory 100g, --mem-fraction-static 0.50, 8 draft tokens and up to 8 running requests, and it never set --speculative-dflash-topk.
The first error in your kernel log is not a memory error. It is Xid 13 ... Graphics Exception ... ILLEGAL_INSTR_ENCODING at 11:32:42. The NV_ERR_NO_MEMORY lines only start at 11:32:43. NVIDIA’s Xid catalog describes Xid 13 as a graphics engine exception logged for application faults, typically an out-of-bounds access, sometimes an illegal instruction. So these logs alone do not show that a prefill burst ran out of memory, and smaller prefill chunks may not touch the cause.
What I would do first: update. Run the one command of the README on the box, as your user, without sudo in front:
curl -fsSL https://get.alzeo.ai | bash
It updates ~/dgx-spark-qwen38 and installs the current release. Its unit replaces yours, so the flags you changed are not kept. On GB10 that release brings:
  • the 27B on a pinned upstream SGLang image, at a fraction measured for its headroom after CUDA graph capture. docs/gb10-memory.md explains why SGLang does not see 25 to 40 GB of transient allocations on this box
  • a host MemAvailable floor in the cockpit that aborts generations before the box reaches the memory edge, and a counter of the kernel’s NVRM allocation refusals
  • the cockpit itself, which says when a newer release is out and shows the unified memory the engine uses apart from everything else on the box (ComfyUI, Ollama and n8n included)
If it still reboots on the current release, please open an issue at Issues · hasso5703/alzeo · GitHub with the output of journalctl -k -b -1 | grep -E 'NVRM|Xid' and what was running at the time, and we will dig into it there.
Hi again dear Basbunarhasan!, I just ran the update and started the new cockpit along with my two personal agents (OpenClaw and Hermes) running concurrently, alongside a DeepSeek instance for coding assistance, plus ComfyUI active for my personal video and image editing projects.
Configuration was quite tough previously because everything kept breaking due to VRAM exhaustion and bus saturation, making me wonder if I was asking too much of the DGX Spark. But with this new stable build, I’ll hope everything flows much better.
The interface is modern, clean, and provides fantastic real-time visibility. I also noticed there are options for massive models well over 100B parameters in the lanes view. Have you tested if those heavy models run functionally and stably on the DGX Spark (GB10) with acceptable performance? Thanks again for the stellar support and this amazing release!
Hi Fabian, glad the update went through and that the cockpit helps.
Yes, each text lane is tested on a GB10, the ones over 100B included: Qwen3.8-Flash-Next 176B (the flash lane, and NVIDIA’s FP4-Local build of it), Nemotron 3.5 Super VL (120B) and Ornith 1.5 122B. Before v1.42.1, the release you just installed, the 8 clients we test (Claude Code, opencode, Hermes, pi, the OpenAI and Anthropic SDKs, fetch under Node and Bun, LiteLLM) ran on each of the 7 text lanes, each lane loaded as the cockpit loads it. 54 of the 56 runs passed at once, and the two others were pi on the two Flash lanes, where the model sometimes answers without calling its tool. For one request alone we measured 47.4 tok/s on FP4-Local and 43.8 on the flash lane on real agent text, 70 on Super VL on code and 42 on Ornith. Every number and its method is in the docs folder of the repo.
One thing matters more than the choice of lane, though: the box runs one lane at a time, and each lane over 100B takes nearly all of its memory on its own. In service they leave about 9 to 19 GiB free, 16.6 to 19 GiB for FP4-Local. A DeepSeek instance and ComfyUI running beside it will not fit, and that is the road back to the memory edge where a GB10 resets. The cockpit’s floor stops the lane’s own generations before that edge, but it cannot stop what other programs allocate.
So rather than running other engines beside the lane, let the lanes take turns. In the cockpit’s Lanes view, Load switches the box: a text lane for coding and for your agents, Qwen-Image 2.1 when you want an image (it answers in about 70 seconds), MiniMax-H3 for a video with sound (about 12 minutes), then a text lane again. Point Hermes, OpenClaw, your coding assistant and anything else that speaks the OpenAI or Anthropic API at the box’s port 30001 with its key (http://<box>:30001/v1 for OpenAI clients). Every text lane answers there, whichever is loaded, and while the image or video lane serves, a text request gets a 503 that says so. Hermes is one of the 8 clients we test.
If you want one big lane to start with, I would take FP4-Local: it is the one our own box serves, it has twice the flash lane’s KV cache in about half its disk, and it boots in about five and a half minutes, against 12 to 15 for the flash lane, once its first boot has tuned its kernels (17 to 19 minutes).
If anything misbehaves, an issue on GitHub with what the cockpit shows and the output of journalctl -k -b -1 | grep -E 'NVRM|Xid' is the best way to reach us.
Hi again! First of all, thank you once more for the special attention and stellar support—I would have achieved these improvements and saved so much frustration much sooner if it hadn’t slipped my mind to ask for your advice earlier.
Right now, I’m testing everyday tasks with my Hermes and OpenClaw agents while simultaneously running a text-to-video workflow in ComfyUI. With the standard configuration, the SGLang container sits at around 73.1 GB, and with ComfyUI running alongside it, total unified memory hovers around 110 GB. Power consumption stays efficiently between 45W and 70W, with temperatures locked in a safe 75°C–80°C range with everything running at once. I fully understand and will stick to the strategy of alternating turns between my AI agent projects and heavy video workflows.
Also, looking ahead, I’m betting that the arrival of Qwen 4 27B will make it even more efficient on this architecture—it should turn out to be an incredible MoE!
By the way, should I still stick strictly to a 0.45 memory fraction and a limit of 4 concurrent requests, or are the standard defaults completely solid for this mixed workload? I’ll keep you posted on how my infrastructure evolves with this update. Thanks again!
Glad it runs better, and thanks for the numbers.
Go with the defaults. The install writes the 27B lane with a memory fraction of 0.76 and 8 requests at a time, measured on a box where the lane has the memory to itself, with the headroom SGLang needs after it captures its CUDA graphs. Your 0.45 and 4 were a way to leave room for other programs, and the update replaced your unit with ours anyway. Two agents rarely fill 8 slots, and the slots do not reserve memory the way the fraction does.
The number to watch is the 110 GB you see with ComfyUI beside the lane. That is the zone where your box reset before: SGLang’s own allocations come and go above what it shows, and the cockpit’s floor can stop the lane’s generations but not what ComfyUI allocates. So taking turns, as you said, is the right call: stop the video workflow before long agent sessions, or switch the box to the video lane from the cockpit when you want a video.
On Qwen 4: we will measure it on the box as soon as its weights are out.
Very thanks buddy, you’ve been an absolutely amazing support! I’ll definitely keep you posted on how all my projects go over the next few days.
Just out of curiosity, what kind of projects or workflows have you already built or scaled using this DGX performance? I have so many ideas for what I want to achieve, but maybe I haven’t fully realized the complete scope of what this machine is capable of yet! Thanks again!
Thanks, glad to help, and do keep us posted.
On our boxes, the 27B and FP4-Local lanes run coding agents through the proxy, opencode, Hermes, pi and Claude Code among them, on contexts of hundreds of thousands of tokens. The image lane makes pictures with Qwen-Image 2.1, the video lane makes clips with sound with MiniMax-H3, the speech lane transcribes 30 languages and speaks seven, and System One answers typed decisions with calibrated probabilities instead of text, for workflows that need a yes or no they can act on. The next release lets two Sparks share one model, a conversation staying on the box that holds it.
If one of your ideas needs something the box does not do yet, open an issue on GitHub and we will look at it.
That is an incredible breakdown, thank you so much! Seeing how you leverage massive contexts for coding agents alongside System One for binary decision-making is super inspiring. Also, the upcoming multi-Spark model sharing feature sounds amazing for scaling!
I’ll keep testing my daily agent workflows and ComfyUI rendering pipelines under this new architecture, and I won’t hesitate to drop an issue on GitHub if a new feature request comes up.
Thanks again for the top-notch support and the amazing work on this project. Catch you later!
Has anybody tried the new DSpine drafter for the Qwen3.8-27B? Here some initial findings:
Thread benchmark: bench-matrix.sh (hasso5703/dgx-spark-qwen38, battery v1)
Prompt DSpine, BF16 head DFlash2, FP4 head (cookbook) DFlash2, BF16 head #68 DFlash2 (repo default) #22 DSpark
math (EN) skipped 52.3 skipped 49.3 45.7
code (EN) 51.4 31.4 27.1 29.1 33.8
code (DE) 39.1 45.7 37.9 33.5 28.6
technical (FR) 31.8 31.9 31.3 31.6 24.0
reasoning (FR) 49.2 45.9 41.7 47.9 36.2
prose (EN) 18.0 23.1 20.2 22.7 19.0
prose (FR) 16.3 20.7 18.9 20.5 15.0
prose (DE) 15.4 17.6 15.5 18.6 13.7
Thanks for the write-up, it saved us time. We ran DSpine on November 9 on our reference box (ASUS Ascent GX10, GB10, 128 GB) next to the lane Alzeo serves. Short version: with the draft attention on Triton instead of fa4 the collapse you saw is gone, but sampled output is still not clean, so your advice to force temperature 0 stands.
Setup. SGLang 0.5.22, target RadixArk/Qwen3.8-27B-NVFP4-BF16-LMHead on FlashInfer, tencent/Qwen3.8-27B-DSpine-b16 with its draft attention on Triton, memory fraction 0.76, 8 running requests, no SPS profile, Tencent/DSpine at 321b0fc. Our patches: Triton allowed for the draft, the FA backend check kept for fa3 and fa4 only, and neither the ragged graph nor the device-only check of verification/sps.py when batch8_tokens is 128 (with a FlashInfer target the start stops on “FlashInfer does not support ragged verify in cuda graph” otherwise). atakann’s PR goes the same way with Triton on both sides (Tencent/DSpine#4).
Sampling. Four prompts (code, math, prose, JSON), 400 tokens, thinking on, two passes each, one request at a time. Median tok/s, acceptance length in brackets:
DSpine b16 our production lane, two boots
greedy 37.0 (3.82) 41.3 (3.85) and 46.7 (3.96)
T=1.0, top_k 20, top_p 0.95 31.9 (3.58) 34.7 (3.70) and 42.2 (3.92)
T=0.6, top_k 20, top_p 0.95 33.5 (3.72) 41.2 (3.66) and 42.9 (3.84)
no sampling settings sent 29.9 (3.51) 34.6 (3.55) and 41.3 (3.86)
So no acceptance of 1 and no “!!!” here. But reading the answers, 23 of the 24 sampled ones carry stray “!” characters: 37 in the 8 answers at T=1.0, 29 at T=0.6, 33 with no settings sent, none in the 8 greedy answers, and none in the 32 answers of the production lane on the same prompts. That is about 100 in 9,600 sampled tokens. Each one stands where one or a few tokens should be (sorted_intervals[1!] for [1:], "The Cartographer's Debt!": "Elena Vasquez" where a comma and the “author” key belong) and the text goes on as if the right tokens were there. “!” is token id 0 in this tokenizer, so it looks like a slot left at zero and not like a sampled token, the same signature as your “!!!” in a milder form. We have not found where it comes from. On GB10 the H100 path is skipped as you say (sampling/target.py returns early unless it finds 132 SMs at sm_90), so this is the generic rejection path. Our throughput check did not flag any of it: only reading the text did.
Speed. On this box DSpine does not beat what we serve, which is RadixArk/Qwen3.8-27B-NVFP4 with its FP4 head and an NVFP4 DFlash2 drafter at 16 draft tokens. Our bench (short prompts, greedy median, three runs each): 57.5, 60.6 and 60.4 tok/s for DSpine against 68.8, 66.8 and 67.3. Per prompt, our greedy numbers on the probe above land on the ones in your table, with other prompts: code 51.0 (yours 51.4), prose 17.7 (yours 18.0). The production lane gave 47.2 and 60.4 on code over its two boots, 23.1 and 22.3 on prose, and 35.1 and 34.0 on JSON where DSpine gave 27.4. The KV pool at the same memory fraction came out at 678,798 tokens against 907,852. Greedy answers were as repeatable as with DFlash2: two cold runs gave the same 48 tokens on 14 documents of 16, against 15 of 16.
Heat, since AliBaba_97 asked in the other thread. Sustained, one request at a time, 46 to 49 W on the GPU, median of the hottest SoC zone on the same three probes: 91.4 °C for DSpine against 84.4 for the production lane on the bench, 91.9 against 85.8 on the sampling probe, 92.8 against 90.8 on the prefix-cache probe. The production runs came 10 to 90 minutes earlier the same evening, so part of the gap may be heat already in the box. It then powered off at 96.4 °C, after four hours of campaigns one after the other. On a Spark, watch the ACPI zones and not nvidia-smi, which reads lower (88 °C on the GPU at that moment).
Not measured, as the run ended there: real coding agents through the proxy, 8 concurrent requests, long generations, and any prompt past the 262K window the BF16-head checkpoint ships with.
