Included below is a complete, replicable recipe for serving Qwen3.8-27B (NVFP4) with SGLang + DFlash2
block-diffusion speculative decoding on NVIDIA DGX Spark (GB10) — including a set of
patches that make the /v1/responses endpoint genuinely OpenAI-API-compatible, plus an
optional dual-Spark tensor-parallel (TP=2) configuration over RoCE for ~1.6x more speed.
Everything below was measured and validated on real hardware on 2026-08-19.
Note on IP addresses: every IP in this guide (
10.100.8.153,10.100.8.1, etc.)
is from my personal two-Spark setup — yours will differ. Find your own fabric
addresses withip -br addr showon each node (look for the interfaces on your
ConnectX-7 link, e.g.enp1s0f1np1) and your RoCE device names withibv_devices,
then substitute them wherever the scripts below use mine.
What you get
| Workload (single stream) | 1x Spark | 2x Spark (TP=2) |
| Code generation | 52–61 tok/s | 87 tok/s |
| Prose / essays | 26 tok/s | 41 tok/s |
| Thinking chat | 34–49 tok/s | 49 tok/s |
| Code, thinking off (“none”) | 52 tok/s | ~80 tok/s |
| TTFT, short prompt | ~0.16 s | similar |
| TTFT, repeated 16K prefix | 0.44 s | 0.74 s |
| Context window | 262,144 | 262,144 |
Quality validated identically on both configurations: HumanEval pass@1 159/164
(97.0%) — full suite, every solution executed against its reference tests, greedy,
measured on the TP=2 cluster — plus 10/10 math word problems, structured tool calling,
and tool-eval-bench 92.3 ± 0.6 / 100 (★★★★★, 3 trials). DFlash2 is lossless
speculative decoding — greedy output matches the target model.
Prefill runs at roughly 10K tok/s (a cold 64K-token prompt reaches first token in ~6.4 s);
any repeated prefix (system prompt, conversation history) returns at a flat ~0.3–0.7 s
thanks to SGLang’s radix cache.
Credits
- MiaAI-Lab/Qwen3.8-27B-SGLang-DGX-Spark — the base deployment repo this guide builds on
- z-lab/dflash + inco.ai DFlash2 — the block-diffusion drafter
- RadixArk/Qwen3.8-27B-NVFP4 and z-lab/Qwen3.8-27B-DFlash2 — weights
- SGLang — serving engine (DFlash2 merged upstream 2026-08-19, commit
c14312a66) - NVIDIA forum threads: Qwen 3.8-27B + DFlash2
Part 1 — Single Spark
1.0 Prerequisites
- DGX Spark (GB10, 128 GB unified memory), DGX OS with Docker + NVIDIA Container Toolkit
(stock DGX Spark image has both). - ~100 GB free disk: 57 GB image + ~25 GB weights + caches.
- Optional:
HF_TOKENin~/.bashrcfor faster Hugging Face downloads (the start
script picks it up automatically).
1.1 Clone the base repo
cd ~
git clone https://github.com/MiaAI-Lab/Qwen3.8-27B-SGLang-DGX-Spark.git
cd Qwen3.8-27B-SGLang-DGX-Spark
cp .env.sample .env
The .env defaults are sane: NVFP4 weights, native 262K context, YaRN off, 16
concurrent requests. Leave YARN=0 and CONTEXT_LENGTH=262144 — DFlash2 is not
compatible with YaRN context extension on this build.
1.2 Patch start.sh (port/name overrides + persistent log)
Upstream hardcodes port 8888 and the served model name, and its log file stops
recording once boot completes. Save this as startsh.patch in the repo root and apply:
diff --git a/start.sh b/start.sh
--- a/start.sh
+++ b/start.sh
@@ -222,14 +222,14 @@ fi
MAMBA_SLOTS_PER_REQ=$(( 4 - MAMBA_SKIP_DECODE_LOCK ))
MAMBA_CACHE_SIZE=$(( MAX_CONCURRENT_REQUESTS * MAMBA_SLOTS_PER_REQ ))
-SERVED_MODEL_NAME="qwen3.8-27b-sglang"
+SERVED_MODEL_NAME="${SERVED_MODEL_NAME:-qwen3.8-27b-sglang}"
# Image override (shell env wins): lets start-dspark.sh run a patched
# derivative image (e.g. qwen38-tier-a:local) and roll back to stock by
# simply not setting IMAGE. Not documented in README/CHANGELOG on purpose.
IMAGE="${IMAGE:-lmsysorg/sglang:qwen38-27b}"
CONTAINER_NAME="qwen3.8-27b-sglang"
HOST="0.0.0.0"
-PORT="8888"
+PORT="${PORT:-8888}"
PID_FILE=".sglang.pid"
LOG_FILE=".sglang.log"
WORK_DIR="$(pwd)"
@@ -373,4 +373,10 @@ echo "Anthropic-compatible: http://${HOST}:${PORT}/v1/messages (no /v1 suffix in
echo "Served model name: ${SERVED_MODEL_NAME}"
echo "Thinking: ON by default (disable per request: chat_template_kwargs {\"enable_thinking\": false})"
+# Keep appending the live server log to ${LOG_FILE} after this script exits
+# (the EXIT trap kills the boot-time follower; this detached one lives until
+# the container stops).
+nohup docker logs -f --tail 0 "${CONTAINER_NAME}" >> "${LOG_FILE}" 2>&1 &
+disown
echo "SGLang is ready and responding; shell is now free."
git apply startsh.patch
Then (optionally) pin your port and model name in .env, e.g.:
cat >> .env <<'EOF'
PORT=8078
SERVED_MODEL_NAME=qwen38-27b
EOF
1.3 The OpenAI-compatibility patch
This is the core contribution of this guide. SGLang’s /v1/responses endpoint (as of
the qwen38-27b cookbook image + DFlash2 merge) breaks against real OpenAI-SDK
clients in seven ways (plus an eighth fix for benchmark tooling). This patch fixes all of them:
| # | Problem | Fix |
| 1 | reasoning.effort: "none" accepted, then crashes mid-stream (strict openai event types reject it) |
Full OpenAI tier mapping: none→thinking OFF, minimal→low, high/max→xhigh |
| 2 | effort: minimal / high / max → 400 (Qwen template only knows low/medium/xhigh) |
Same mapping |
| 3 | Echoed xhigh crashes strict SDK event types |
Echo sanitized: xhigh→high, none→omitted |
| 4 | SDK-echoed assistant history → 400 (ValidatorIterator, logprobs: None) — breaks every multi-turn conversation and tool round-trip |
Request input validated as plain dicts, killing pydantic’s lazy-Iterable validation class of failures |
| 5 | text.format (json_schema / json_object structured output) silently ignored |
Wired into constrained decoding (json_schema sampling param) |
| 6 | Usage returned in chat-completions shape — clients read input_tokens_details.cached_tokens, see nothing, report “cache hit 0%” forever |
Usage emitted in proper Responses-API shape (legacy keys kept) |
| 7 | effort: "none" semantics: clients mean “thinking off” |
enable_thinking=false + model-card non-thinking sampling (temp 0.7 / top_p 0.8) when client sets neither |
| 8 | Streaming + return_token_ids → 400 (breaks llama-benchy ≥0.4.0 token counting) |
Flag dropped gracefully on streaming instead of rejecting |
With the patch, the following all pass against the official OpenAI Python SDK:
every effort tier (none/minimal/low/medium/high/xhigh/max) streaming and
non-streaming, multi-turn history echo (typed SDK objects incl. reasoning items),
function-tool round-trips, previous_response_id chaining, instructions + sampling
params, json_schema structured output, system-role messages, and cache-hit reporting.
Save the following as patch/openai-responses-compat.patch (verbatim — it applies
cleanly onto the files shipped in the lmsysorg/sglang:qwen38-27b image):
--- a/python/sglang/srt/entrypoints/openai/serving_responses.py
+++ b/python/sglang/srt/entrypoints/openai/serving_responses.py
@@ -190,6 +190,26 @@
if not self.tokenizer_manager:
return self.create_error_response("Model not loaded")
+ # Map the OpenAI reasoning-effort tiers onto what the Qwen3.8 chat
+ # template supports (low / medium / xhigh — anything else raises a
+ # jinja error mid-request). Clients legitimately send any OpenAI tier
+ # ("none" ... "max"); unknown values land on "low". The echo back to
+ # the client is re-sanitized in ResponsesResponse.from_request, since
+ # the strict openai event types don't allow "xhigh".
+ if request.reasoning is not None and request.reasoning.effort is not None:
+ request.reasoning.effort = {
+ # "none" is preserved: _make_request turns it into
+ # enable_thinking=False (thinking fully off) plus the model
+ # card's non-thinking sampling defaults.
+ "none": "none",
+ "minimal": "low",
+ "low": "low",
+ "medium": "medium",
+ "high": "xhigh",
+ "max": "xhigh",
+ "xhigh": "xhigh",
+ }.get(str(request.reasoning.effort).lower(), "low")
# FIXME: If the engine is dead, raise an error
# This is required for the streaming case
@@ -478,11 +498,50 @@
messages = self._construct_input_messages(request, prev_response)
+ # Wire the Responses API ``text.format`` structured-output config
+ # through to chat's ``response_format`` (it was silently ignored
+ # before, so json_schema requests came back as prose).
+ response_format = None
+ text_cfg = getattr(request, "text", None)
+ if isinstance(text_cfg, dict):
+ fmt = text_cfg.get("format") or {}
+ ftype = fmt.get("type") if isinstance(fmt, dict) else None
+ if ftype == "json_schema" and fmt.get("schema") is not None:
+ response_format = {
+ "type": "json_schema",
+ "json_schema": {
+ "name": fmt.get("name") or "response",
+ "description": fmt.get("description"),
+ "schema": fmt.get("schema"),
+ "strict": fmt.get("strict"),
+ elif ftype == "json_object":
+ response_format = {"type": "json_object"}
+ # effort "none" = thinking fully off (clients use it as their "off"
+ # tier). The chat template has no "none" effort, so it maps to
+ # enable_thinking=False; sampling then follows the model card's
+ # non-thinking recommendation (temp 0.7 / top_p 0.8) unless the
+ # client set its own values. Lower temperature also lifts DFlash2
+ # draft acceptance, so this is the fast lane for code tasks.
+ reasoning_effort = request.reasoning.effort if request.reasoning else None
+ chat_template_kwargs = None
+ if reasoning_effort == "none":
+ reasoning_effort = None
+ chat_template_kwargs = {"enable_thinking": False}
+ if request.temperature is None:
+ request.temperature = 0.7
+ if request.top_p is None:
+ request.top_p = 0.8
chat_tools = self._response_tools_to_chat_tools(request)
chat_request = ChatCompletionRequest(
model=request.model,
messages=messages,
stream=request.stream,
+ response_format=response_format,
+ chat_template_kwargs=chat_template_kwargs,
tools=chat_tools or None,
tool_choice=request.tool_choice if chat_tools else "none",
parallel_tool_calls=(
@@ -491,7 +550,7 @@
else True
stop=request.stop,
- reasoning_effort=(request.reasoning.effort if request.reasoning else None),
+ reasoning_effort=reasoning_effort,
media_error = self._validate_media_content(chat_request)
@@ -898,6 +957,18 @@
if message.get("role") == "developer":
message = {**message, "role": "system"}
+ # ``ResponseOutputMessageParam.content`` is typed ``Iterable``, which
+ # pydantic validates lazily -- assistant history echoed back by a
+ # client arrives here with content as a ValidatorIterator, skipping
+ # the list branch below and leaking raw ``output_text`` parts into
+ # ChatCompletionRequest. Materialize any non-str/list content first.
+ _content = message.get("content")
+ if _content is not None and not isinstance(_content, (str, list)):
+ try:
+ message = {**message, "content": list(_content)}
+ except TypeError:
+ pass
msg_type = message.get("type")
if msg_type == "function_call":
# Coerce ``arguments`` to a valid JSON-object string so the chat
--- a/python/sglang/srt/entrypoints/openai/protocol.py
+++ b/python/sglang/srt/entrypoints/openai/protocol.py
@@ -1496,7 +1496,13 @@
] = None
# Accept dict-shaped items as the loose arm; downstream normalization
# handles replayed shapes that don't satisfy every openai TypedDict.
- input: Union[str, List[ResponseInputOutputItem], List[Dict[str, Any]]]
+ # NOTE: the typed openai arm was removed on purpose. Its TypedDicts carry
+ # ``Iterable`` fields (message content, logprobs, annotations) that
+ # pydantic validates LAZILY, so a shallowly-valid item wins the union and
+ # then explodes as a ValidatorIterator deep inside the serving layer
+ # (e.g. SDK-echoed assistant history with ``logprobs: None``) instead of
+ # falling back to the dict arm. All downstream handling is dict-based.
+ input: Union[str, List[Dict[str, Any]]]
instructions: Optional[str] = None
max_output_tokens: Optional[int] = None
max_tool_calls: Optional[int] = None
@@ -1509,6 +1515,9 @@
store: Optional[bool] = True
stream: Optional[bool] = False
temperature: Optional[float] = None
+ # Structured-output config, e.g. {"format": {"type": "json_schema", ...}}.
+ # Wired through to chat response_format in serving_responses._make_request.
+ text: Optional[Dict[str, Any]] = None
tool_choice: Literal["auto", "required", "none"] = "auto"
tools: List[ResponseTool] = Field(default_factory=list)
top_logprobs: Optional[int] = 0
@@ -1645,6 +1654,17 @@
if key not in params or params[key] is None:
params[key] = value
+ # Structured output via the Responses API ``text.format`` config —
+ # the actual generation constraint lives in sampling params, not in
+ # the chat-request object built for template rendering.
+ if isinstance(self.text, dict):
+ fmt = self.text.get("format") or {}
+ params["json_schema"] = convert_json_schema_to_str(fmt["schema"])
+ params["json_schema"] = '{"type": "object"}'
has_existing_constraints = (
params.get("regex")
or params.get("ebnf")
@@ -1689,7 +1709,9 @@
Union[ResponseOutputItem, ResponseReasoningItem, ResponseFunctionToolCall]
status: Literal["queued", "in_progress", "completed", "failed", "cancelled"]
- usage: Optional[UsageInfo] = None
+ # Dict shape follows the OpenAI Responses API usage schema (see
+ # from_request); UsageInfo accepted for any legacy internal callers.
+ usage: Optional[Union[Dict[str, Any], UsageInfo]] = None
parallel_tool_calls: bool = True
tool_choice: str = "auto"
@@ -1763,13 +1785,45 @@
text_format = {"format": {"type": "text"}} if _is_text_only(output) else None
+ # Convert chat-style UsageInfo to the OpenAI Responses API usage shape
+ # (input_tokens / input_tokens_details.cached_tokens / output_tokens /
+ # output_tokens_details.reasoning_tokens). Clients read those fields
+ # for cache-hit and token accounting; the legacy chat keys are kept
+ # alongside for back-compat.
+ usage_payload = None
+ if usage is not None:
+ u = usage.model_dump() if hasattr(usage, "model_dump") else dict(usage)
+ details = u.get("prompt_tokens_details") or {}
+ usage_payload = {
+ "input_tokens": u.get("prompt_tokens", 0),
+ "input_tokens_details": {
+ "cached_tokens": details.get("cached_tokens", 0) or 0
+ "output_tokens": u.get("completion_tokens", 0),
+ "output_tokens_details": {
+ "reasoning_tokens": u.get("reasoning_tokens", 0) or 0
+ "total_tokens": u.get("total_tokens", 0),
+ "prompt_tokens": u.get("prompt_tokens", 0),
+ "completion_tokens": u.get("completion_tokens", 0),
+ # The strict openai types used for stream events only accept
+ # minimal/low/medium/high in the echoed reasoning.effort; sanitize
+ # our extended tiers ("xhigh"/"max"/"none") at the boundary.
+ echo_effort = request.reasoning.effort if request.reasoning else None
+ if echo_effort is not None:
+ echo_effort = {"xhigh": "high", "max": "high", "none": None}.get(
+ echo_effort, echo_effort
return cls(
id=request.request_id,
created_at=created_time,
model=model_name,
output=output,
status=status,
- usage=usage,
+ usage=usage_payload,
request.parallel_tool_calls
if request.parallel_tool_calls is not None
@@ -1784,7 +1838,7 @@
max_output_tokens=request.max_output_tokens,
previous_response_id=request.previous_response_id, # TODO(v): ensure this is propagated if retrieved from store
reasoning={
- "effort": request.reasoning.effort if request.reasoning else None,
+ "effort": echo_effort,
"summary": None, # unused
store=request.store,
--- a/python/sglang/srt/entrypoints/openai/serving_chat.py
+++ b/python/sglang/srt/entrypoints/openai/serving_chat.py
@@ -925,11 +925,12 @@
"Please set stream=false when using return_prompt_token_ids=true."
if request.return_token_ids:
- raise ValueError(
- "return_token_ids is not supported with streaming on "
- "/v1/chat/completions. Please set stream=false when using "
- "return_token_ids=true."
+ # Degrade gracefully instead of rejecting: benchmark clients
+ # (e.g. llama-benchy >= 0.4.0) send return_token_ids on
+ # streaming requests to count real tokens under speculative
+ # decoding; dropping the flag lets them fall back to counting
+ # via usage / a local tokenizer rather than failing the run.
+ request.return_token_ids = False
if request.return_meta_info:
raise ValueError(
"return_meta_info is not supported with streaming. "
1.4 Apply the patch into the DFlash2 overlay
The repo builds its DFlash2 image by overlaying a handful of files onto the pinned
cookbook image (patch/build-dflash2-image.sh --minimal, sha256-verified). We add our
two patched files to that same mechanism. From the repo root:
# 1. Extract the pristine files from the base image (pulls ~57 GB on first run)
cid=$(docker create lmsysorg/sglang:qwen38-27b true)
mkdir -p /tmp/compat/python/sglang/srt/entrypoints/openai
for f in serving_responses.py protocol.py serving_chat.py; do
docker cp "$cid:/sgl-workspace/sglang/python/sglang/srt/entrypoints/openai/$f" \
/tmp/compat/python/sglang/srt/entrypoints/openai/
done
docker rm "$cid"
# 2. Apply the compat patch
cd /tmp/compat && patch -p1 < ~/Qwen3.8-27B-SGLang-DGX-Spark/patch/openai-responses-compat.patch
cd ~/Qwen3.8-27B-SGLang-DGX-Spark
# 3. Install the patched files into the overlay
mkdir -p patch/overlay-dflash2/sglang/srt/entrypoints/openai
cp /tmp/compat/python/sglang/srt/entrypoints/openai/*.py \
patch/overlay-dflash2/sglang/srt/entrypoints/openai/
# 4. Register them in the overlay manifest
cd patch/overlay-dflash2
sha256sum sglang/srt/entrypoints/openai/serving_responses.py \
sglang/srt/entrypoints/openai/protocol.py \
sglang/srt/entrypoints/openai/serving_chat.py >> MANIFEST.sha256
sha256sum -c MANIFEST.sha256 # every line must say OK
cd ../..
# 5. Add them to the build script's file list
sed -i '/srt\/speculative\/dflash_worker_v2.py/a\ srt/entrypoints/openai/serving_responses.py\n srt/entrypoints/openai/protocol.py\n srt/entrypoints/openai/serving_chat.py' \
1.5 Build the image
./patch/build-dflash2-image.sh --minimal
# -> built lmsysorg/sglang:qwen38-27b-dflash2-minoverlay
This is a pure local overlay onto the pinned image — no network needed beyond the base
image pull, and every overlaid file is checksum-verified.
1.6 Start
DF_EXTRA="--sleep-on-idle" IMAGE=lmsysorg/sglang:qwen38-27b-dflash2-minoverlay ./start-dflash.sh
DF_EXTRA="--sleep-on-idle" fixes a significant idle power draw: without it the SGLang
scheduler busy-spins at ~97% CPU whenever the server is idle
(MiaAI repo issue #4).
First boot downloads the weights into ./.cache/huggingface (RadixArk NVFP4 ~16.5 GB +
DFlash2 draft ~2.6 GB, pinned revisions) and compiles kernels; allow ~10–20 minutes.
Warm restarts take ~2–3 minutes. The script exits when the server answers.
1.7 Verify
PORT=8078 # whatever you set in .env (default 8888)
curl -s http://127.0.0.1:$PORT/v1/models | python3 -m json.tool
# Chat completions, thinking off:
curl -s http://127.0.0.1:$PORT/v1/chat/completions -H 'Content-Type: application/json' -d '{
"model": "qwen38-27b",
"messages": [{"role": "user", "content": "Say OK."}],
"max_tokens": 20,
"chat_template_kwargs": {"enable_thinking": false}}' | python3 -m json.tool
# Responses API with effort "none" (thinking off — this crashed before the patch):
curl -s http://127.0.0.1:$PORT/v1/responses -H 'Content-Type: application/json' -d '{
"input": "Say OK.",
"max_output_tokens": 50,
"reasoning": {"effort": "none"}}' | python3 -m json.tool
The second /v1/responses call to an identical prompt should show
usage.input_tokens_details.cached_tokens > 0 — that’s your prefix cache working and
being reported correctly.
Logs: tail -f .sglang.log (persists across the boot script exiting, thanks to the
step-1.2 patch) or docker logs -f qwen3.8-27b-sglang.
Stop: ./stop.sh
Part 2 — Dual Spark (TP=2 over RoCE)
Shards the model across both Sparks with tensor parallelism. Decode on GB10 is
memory-bandwidth-bound, so halving each node’s weight reads gives ~1.5–1.6x on every
workload. Same endpoint, same model name — clients don’t change.
As far as we know this (DFlash2 + cross-node TP + hybrid-GDN model + NVFP4 on GB10)
was first booted 2026-08-19 using this exact recipe. It came up on the first try and
passed the full quality gate, but treat it as experimental.
2.0 Prerequisites
- Two DGX Sparks connected back-to-back on their ConnectX-7 QSFP ports (no switch
needed), one IP per node on the same subnet. This guide uses my addresses —
substitute your own (see the note at the top;ip -br addr showon each node):SPARK1 = 10.100.8.153(rank 0, serves HTTP)SPARK2 = 10.100.8.1(rank 1, headless)
- MTU 9000 on the fabric interfaces of both nodes (
sudo ip link set dev enp1s0f1np1 mtu 9000— make it persistent via netplan). NCCL will appear to hang at
warmup with default MTU. - Passwordless SSH from spark1 to spark2.
- Part 1 completed on spark1 (patched image built, weights downloaded, verified).
Each PCIe link on the CX-7 shows up as two RoCE devices; using both twins
(rocep1s0f1,roceP2p1s0f1) is what gets full NCCL bandwidth.
2.1 Copy the image and weights to spark2
From spark1 (adjust IPs/paths):
SPARK2=10.100.8.1
# Image (~57 GB, a few minutes over the fabric)
docker save lmsysorg/sglang:qwen38-27b-dflash2-minoverlay | ssh $SPARK2 docker load
# Weights (~25 GB)
ssh $SPARK2 "mkdir -p ~/qwen38-dflash2/.cache"
rsync -a ~/Qwen3.8-27B-SGLang-DGX-Spark/.cache/huggingface \
$SPARK2:~/qwen38-dflash2/.cache/
2.2 The launch script
Save as start-dflash2-tp2.sh on spark1 (adjust the variables at the top):
#!/bin/bash
# Qwen3.8-27B NVFP4 + DFlash2 sharded across two DGX Sparks (TP=2 over RoCE).
# Serves on THIS node (rank 0) — same port/model name as the solo recipe.
set -euo pipefail
NODE1=10.100.8.1 # spark2 (rank 1, no HTTP)
DIST=10.100.8.153:50051 # rank-0 rendezvous (spark1's fabric IP)
NAME=qwen38-tp2
PORT=8078 # match your solo .env
LOCAL_CACHE=$HOME/Qwen3.8-27B-SGLang-DGX-Spark/.cache
REMOTE_CACHE=/home/$USER/qwen38-dflash2/.cache
ARGS="--model-path RadixArk/Qwen3.8-27B-NVFP4 \
--served-model-name qwen38-27b --trust-remote-code \
--tp 2 --nnodes 2 --dist-init-addr ${DIST} \
--attention-backend flashinfer --chunked-prefill-size 8192 \
--disable-prefill-cuda-graph --kv-cache-dtype fp8_e4m3 \
--mamba-ssm-dtype bfloat16 --mamba-full-memory-ratio 4.21 \
--mamba-radix-cache-strategy extra_buffer \
--max-mamba-cache-size 64 --max-running-requests 16 \
--context-length 262144 \
--speculative-algorithm DFLASH \
--speculative-draft-model-path z-lab/Qwen3.8-27B-DFlash2 \
--speculative-draft-model-revision 50307d4c4cde6860d4eee73e2547cd786fe8e8a4 \
--speculative-num-draft-tokens 8 \
--reasoning-parser qwen3 --tool-call-parser qwen3_coder \
--sampling-defaults model --enable-metrics --enable-cache-report \
--stream-interval 1 --sleep-on-idle \
--mem-fraction-static 0.90 --host 0.0.0.0 --port ${PORT}"
# --stream-interval 1: one token per SSE event — DFlash2 otherwise batches
# ~2-4 accepted tokens per event, breaking clients that count stream chunks.
# --sleep-on-idle: without it the scheduler busy-spins ~97% CPU when idle
# (MiaAI repo issue #4) — significant idle power draw on a 24/7 box.
ENVS="-e NCCL_IB_HCA=rocep1s0f1,roceP2p1s0f1 \
-e NCCL_SOCKET_IFNAME=enp1s0f1np1 -e GLOO_SOCKET_IFNAME=enp1s0f1np1 \
-e NCCL_CUMEM_ENABLE=0 -e NCCL_NVLS_ENABLE=0 \
-e HF_HOME=/root/.cache/huggingface -e TRITON_CACHE_DIR=/root/.triton"
DOCKER_FLAGS="--network host --ipc host --privileged --gpus all --shm-size 32g"
echo "Stopping solo server if present..."
docker stop qwen3.8-27b-sglang >/dev/null 2>&1 || true
echo "Starting rank 1 on ${NODE1}..."
ssh -o BatchMode=yes "${NODE1}" "docker rm -f ${NAME} >/dev/null 2>&1 || true; \
mkdir -p ${REMOTE_CACHE}/triton; \
docker run -d --name ${NAME} ${DOCKER_FLAGS} ${ENVS} \
-v ${REMOTE_CACHE}/huggingface:/root/.cache/huggingface \
-v ${REMOTE_CACHE}/triton:/root/.triton \
${IMAGE} python3 -m sglang.launch_server ${ARGS} --node-rank 1" >/dev/null
echo "Starting rank 0 locally..."
-v ${LOCAL_CACHE}/huggingface:/root/.cache/huggingface \
-v ${LOCAL_CACHE}/triton:/root/.triton \
${IMAGE} python3 -m sglang.launch_server ${ARGS} --node-rank 0 >/dev/null
echo "Waiting for readiness (boot takes a few minutes)..."
i=0
until curl -fsS -m 2 "http://127.0.0.1:${PORT}/v1/models" >/dev/null 2>&1; do
if ! docker ps --format '{{.Names}}' | grep -qx "${NAME}"; then
echo "rank 0 exited — last log lines:"; docker logs --tail 40 "${NAME}" 2>&1 | tail -40; exit 1
fi
(( i % 6 == 0 )) && echo " still starting... (docker logs -f ${NAME})"
i=$((i+1)); sleep 5
done
echo "TP=2 cluster READY on http://127.0.0.1:${PORT}/v1 (model qwen38-27b)"
LOG=$HOME/.sglang-tp2.log
nohup docker logs -f --tail 0 ${NAME} >> "${LOG}" 2>&1 &
disown
echo "Persistent log: ${LOG}"
And stop-dflash2-tp2.sh:
#!/bin/bash
docker stop qwen38-tp2 >/dev/null 2>&1 && echo "stopped rank 0" || echo "rank 0 not running"
ssh -o BatchMode=yes 10.100.8.1 "docker stop qwen38-tp2 >/dev/null 2>&1" \
&& echo "stopped rank 1" || echo "rank 1 not running"
chmod +x start-dflash2-tp2.sh stop-dflash2-tp2.sh
2.3 Run and switch between modes
# Solo -> TP=2
./stop.sh && ./start-dflash2-tp2.sh
# TP=2 -> solo
./stop-dflash2-tp2.sh && IMAGE=lmsysorg/sglang:qwen38-27b-dflash2-minoverlay ./start-dflash.sh
Both serve the identical endpoint and model name; only the script you run changes.
Weights and compiled-kernel caches are shared, so switching takes ~2–5 minutes. The
radix cache resets on any restart — the first turn afterwards prefills cold.
Logs: docker logs -f qwen38-tp2 (rank 0 gets all request lines);
ssh <spark2> docker logs -f qwen38-tp2 for rank 1.
Client integration notes
- Endpoint:
http://<spark1>:<PORT>/v1— OpenAI-compatible chat completions and
Responses API. An Anthropic-style/v1/messagesis also exposed. - Reasoning effort: send any OpenAI tier.
none= thinking off (fast lane, ~2x
fewer tokens and faster decode);low/mediumfor agent work;xhigh= native
maximum (the model’s default if you send nothing — watch out, it thinks a LOT). - Thinking off on chat completions:
"chat_template_kwargs": {"enable_thinking": false}. - Measuring tok/s: DFlash2 emits ~8 stream events/s with several tokens per event.
Always compute rates fromusage(stream_options: {"include_usage": true}on chat),
never by counting SSE chunks. - Cache hits: reported in
usage.input_tokens_details.cached_tokens(Responses)
andusage.prompt_tokens_details.cached_tokens(chat). Hits are counted in 64-token
pages; turn 1 of any fresh session is always 0. - Sampling: speculative acceptance (and therefore speed) improves at lower
temperature. For codegen, temperature ≤0.3 measurably helps;effort: "none"
already defaults to the model card’s non-thinking params.
Troubleshooting
| Symptom | Cause / fix |
| Hard reboot during DFlash2 startup (“Capture target verify CUDA graph”) | Keep --mem-fraction-static 0.90 for NVFP4 (0.95 has caused GB10 hard reboots); the overlay’s in-place quantized-head selector must be in the image |
AttributeError ... max_position_embeddings at boot |
YaRN/context >262144 leaking into the draft config — keep YARN=0, CONTEXT_LENGTH=262144 |
| 400 “Unexpected reasoning effort …” | You’re on an unpatched image — the compat patch maps all OpenAI tiers |
| TP=2 hangs at NCCL warmup, GPUs pinned ~96% util at ~14 W | Fabric MTU not 9000 on both nodes, or wrong NCCL_IB_HCA device names (ibv_devices lists them) |
| Client says “cache hit 0%” forever | Unpatched usage shape; also remember restarts wipe the cache and turn 1 is always 0 |
| First long prompt after boot is slow (~13 s vs ~8 s at 16K) | Triton kernel warmup; .cache/triton persists across restarts, so it’s once per cold cache |
| High power draw / hot CPU while server is idle | SGLang scheduler busy-spins ~97% CPU without --sleep-on-idle — add the flag (see MiaAI issue #4) |
| Benchmark tools report ~4x too-low tok/s | Client counts SSE chunks, not tokens — DFlash2 packs ~2-4 tokens/event. Use llama-benchy ≥0.4.0 with --tokenizer, or serve with --stream-interval 1 |
| tok/s looks impossibly low in a client | It’s counting stream events, not tokens — see client notes |
Known limitations
/v1/responsesinput items of exotic types (item_reference, MCP tool calls,
web_search_callechoes) return a clear 400 — they need server-side tool execution
this build doesn’t ship. Function tools work fully.- DFlash2/DSpark are incompatible with YaRN context extension (>262K) on this build;
the MTP mode in the base repo supports 1M if you need it (slower). - TP=2 adds ~0.3 s to cached-turn TTFT (per-layer allreduce) — irrelevant in practice.
- Restarts drop the radix cache (in-memory only).
Validated 2026-08-19 on two DGX Sparks (GB10, 128 GB), DGX OS, Docker 29.x,
lmsysorg/sglang:qwen38-27b base image, SGLang DFlash2 commit c14312a66,
RadixArk/Qwen3.8-27B-NVFP4 + z-lab/Qwen3.8-27B-DFlash2@50307d4.
Awesome! I’ve been wanting to try Qwen3.8-27B with DFlash2 on my single Spark ever since I saw the news and the benchmark figures. Very impressive. I’ll definitely find some time to reproduce it.
Amazing, thanks! Were you able to test the concurrency performance?
Right on time as I finished my tests.
Validated 2026-08-20 on 2x DGX Spark (GB10, 128 GB), DGX OS, llama-benchy 0.4.0,
Here’s is the short version below
| Concurrency | tg128 aggregate | per stream | TTFT (pp2048) |
| c1 | 45 tok/s | 45 tok/s | 0.77 s |
| c2 | 79 tok/s | 41 tok/s | 1.18 s |
| c5 | 120 tok/s | 29 tok/s | 3.4 s |
| c10 | 134 tok/s (peak 214) | 21 tok/s | 6.1 s |
Takeaways:
- Aggregate decode scales to ~3× single-stream (45 → 134 tok/s at c10) while each stream degrades gracefully (45 → ~21 tok/s). This is expected with speculative decoding: DFlash2’s per-stream advantage is biggest at low concurrency, and batching gradually trades it for aggregate throughput.
- Prefill capacity is shared: total prefill stays roughly flat at ~2.7–3.4K tok/s regardless of concurrency, so TTFT grows about linearly with the number of simultaneous cold prompts (0.77 s at c1 → ~6 s at c10).
- The weak spot is deep context + high concurrency: at 32K resident tokens and c10, per-stream decode falls to ~2–3 tok/s. For a multi-user setup I’d keep concurrent long-context requests ≤ 5.
That’s super impressive!
Are those llama-benchy results using 2 nodes? I tried running the guide and i could only get around 30-31 on normal and peak at single node c1 pp2048 tg128
@jomark — yes, those llama-benchy numbers (45 tg128 single-stream, 134 aggregate @c10) are the 2-node TP=2 config from Part 2 of the guide. My bad for not labeling that more clearly in the concurrency reply above.
Your 30-31 tok/s single-node is exactly right — in fact slightly better than expected:
| Config | llama-benchy tg128 (c1, pp2048) |
| 1x Spark — jbourny (DFlash2 thread) | 27.3 |
| 1x Spark — you | 30-31 |
| 2x Spark TP=2 — me | 45.0 ± 4.8 |
TP=2 scales ~1.6x on GB10 (decode is memory-bandwidth-bound; sharding halves each node’s weight reads), and 30 × 1.6 ≈ 48, so your number and mine are the same setup seen from both sides. Congrats on a clean repro.
Two notes that explain the rest of the numbers in the guide:
- llama-benchy’s tg is a floor, not a ceiling, for DFlash2. Its text corpus gets low draft acceptance (~3 of 8 draft tokens); real code prompts accept ~5 of 8. That’s why the guide’s real-workload figures (single Spark: code 52-61, prose 26, thinking 34-49 tok/s) sit above the benchy tg128 — same server, different acceptance rates. All of those are real token counts (
usage.completion_tokens), not stream-event counts. - Since you got ~30 and not ~9, you’re clearly on llama-benchy ≥0.4.0 with
--tokenizer(or--stream-interval 1) — older versions count SSE events and under-report DFlash2 ~4x. Worth stating in any numbers you post, since a lot of earlier spec-decode results in these forums predate that fix.
If you want the 45, Part 2 (TP=2) is the recipe — it booted first try here and the quality gate (HumanEval 97.0%, tool-eval-bench 92.3) is identical across both configs.
I’ve been working with lmsysorg/sglang:dev-qwen38-27b-dflash2. It seems to support dflash2, but I see that the openai patches haven’t been applied. I’m noticing hangs during extended ‘build’ calls within opencode.
Should I abandon that image and follow everything here?
FWIW, I’m running a single gb10 instance.
@kosta thank you for sharing working setup! I asked qwen3.8 (setup without Dflash2, but on vllm) in pi to read your post, prepare files, and let me seamlessly transition from it to new “it” with Dlfash2. and it did. I have been running it for last 30 min and omg, Dflash2, is sooo fast as I watch how 3 pi sessions each cracking coding tasks with speed I can’t even catch up reading (without Dflash2 in previous setup, I could sit and watch how they are thinking through verbosely through and could read it due to slow token gen). Your shared setup makes Qwen3.8 soooo much enjoyable to use!
@stever519 OpenAI patches are not a must have/apply if you do not intend using stuff like standard harnesses like Codex/Claude Code. Hope that makes sense.
@nick398 Thanks for your feedback. I found this setup very useful indeed and I’m quick happy with its performance in coding tasks for sure. Enjoy until we get a better setup :)
Definitely a great guide, I’ve been using it for the past few days and so far had been working well. I just used gpt to modify a few parameters which I am clueless in SGlang and so far its been great.
on a side note, radix updated their qwen3.8-27b image a day ago and somehow that increased decode by about 2-4tks
I have been trying the 3.8 27b on a single spark for almost a week now.
With the help of claude code I have run multiple instance and variations with a synthetic benchmark after trying straight up real workflow just didn;t work due to context overflow.
here is claude codes summary artifact it contains details on how it was tested and the different verisons. Claude Artifact
TLDR:
- 8 concurrent agents is perfectly usable — 27.3 tok/s aggregate at 100K context, 21.9 at 150K. Slower per agent (~9 tok/s), but for agentic flows where agents spend most of their time waiting on tools, it works.
- 4 agents is the throughput sweet spot — 31.6 tok/s aggregate at 100K, and time-to-first-token no worse than a single agent right up to 200K context.
- Your context ceiling per agent is just
KV pool ÷ agents, and on the config below the pool is 623,672 tokens. So 2 agents → ~310K, 4 → ~156K, 6 → ~104K, 8 → ~78K. - But that ceiling is soft. Agents don’t all sit at maximum context simultaneously. We ran 8 agents at 150K — 1.9× oversubscribed — and it held: 83 good turns, 3 errors.
- Context depth costs more than concurrency does. Going 100K → 234K roughly halves throughput at every agent count. Capping context buys more than dropping agents.
- Quantization didn’t move quality. NVFP4, FP8 and Q8_0 all scored 98% on the same 49-item battery. NVFP4 was ~3× faster than a Q8_0 GGUF and ~30% faster than FP8.
- vLLM was half the speed of SGLang on identical weights and the same speculative decoder — 7.9 vs 17.2 tok/s at 3 agents.
- The 34–38 tok/s in this thread reproduces — we measured 31.6 mean / 36.5 best on the stock recipe. Our other figures look lower because they are a different measurement; see the next section before comparing anything.
and my final recipie i am settling for:
# docker-compose.yml — the profile we settled on
services:
qwen38-diskkv:
image: qwen38-dflash2:v1.2
ports:
- "18003:8000"
ipc: host
shm_size: "16gb"
volumes:
- /mnt/ai-models/huggingface:/root/.cache/huggingface
- /srv/qwen38-kv:/kv-cache # disk KV tier, NVMe
- ~/.config/qwen38:/out:ro # chat template lives here
- ~/.config/qwen38/sglang-cache:/cache
environment:
NVIDIA_VISIBLE_DEVICES: all
NVIDIA_DRIVER_CAPABILITIES: compute,utility
TORCHINDUCTOR_CACHE_DIR: /cache/inductor
# NOTE: these want "64G", NOT "64GB". An unparseable value is
# silently REJECTED, which DISABLES the bound entirely.
SGLANG_HICACHE_FILE_BACKEND_STORAGE_DIR: /kv-cache
SGLANG_HICACHE_FILE_BACKEND_MAX_SIZE: "64G"
SGLANG_HICACHE_FILE_BACKEND_MIN_FREE_SPACE: "50G"
SGLANG_HICACHE_FILE_BACKEND_EVICTION_RATIO: "0.9"
deploy:
resources:
reservations:
devices:
- driver: nvidia
count: all
capabilities: [gpu]
command:
- /bin/sh
- -c
exec python3 -m sglang.launch_server \
--revision 52d1adc5f38aa5ebf099c29ed7025ba34cfbb854 \
--tp-size 1 --served-model-name qwen3.8-27b \
--mem-fraction-static 0.60 \
--context-length 250000 \
--enable-hierarchical-cache --hicache-size 8 \
--hicache-storage-backend file \
--disable-prefill-cuda-graph --cuda-graph-max-bs 8 \
--disable-flashinfer-autotune \
--speculative-draft-model-quantization unquant \
--mamba-ssm-dtype bfloat16 \
--max-mamba-cache-size 144 \
--max-running-requests 6 \
--schedule-policy lpm --radix-eviction-policy lfu \
--enable-torch-compile --torch-compile-max-bs 4 \
--num-continuous-decode-steps 2 \
--chat-template /out/chat-template-sglang.jinja \
--host 0.0.0.0 --port 8000
How is prefill speed at tp 1 and 2 at maybe 32k tokens?
These are my vLLM numbers and configs (as found at The 30B Showdown: A Local AI Models Comparison (Gemma vs. Glimmer vs. Qwen) - OlegMikheev.com )
I’d say that this Qwen 3.8 27B is the first truly usable LLM on DGX Spark, but still feels pretty slow.
I tried my best to get the most out of it, but if there’s anything that can improve the numbers further - would greatly appreciate.
vllm-qwen38:
image: vllm/vllm-openai:nightly
container_name: VLLM-Qwen3.8-27B-NVFP4
shm_size: 16g
ports:
- "8000:8000"
volumes:
- /home/omikheev/models:/models
- /home/omikheev/.cache/vllm-qwen38:/root/.cache
environment:
- CUTE_DSL_ARCH=sm_121a
- FLASHINFER_CUDA_ARCH_LIST=12.1a
- TORCH_CUDA_ARCH_LIST=12.1a
- VLLM_USE_FLASHINFER_SAMPLER=1
- VLLM_MARLIN_USE_ATOMIC_ADD=1
- TRITON_CACHE_DIR=/root/.cache/triton
- VLLM_FLASHINFER_AUTOTUNE_CACHE_DIR=/root/.cache/flashinfer
deploy:
resources:
reservations:
devices:
- driver: nvidia
count: all
capabilities: [gpu]
entrypoint: ""
command: >
bash -c "taskset -c 0-9 vllm serve /models/Qwen3.8-27B-NVFP4
--host 0.0.0.0
--port 8000
--gpu-memory-utilization 0.80
--language-model-only
--load-format fastsafetensors
--max-model-len 262144
--max-num-seqs 4
--block-size 64
--max-num-batched-tokens 16384
--trust-remote-code
--enable-prefix-caching
--enable-chunked-prefill
--enable-auto-tool-choice
--speculative-config '{\"method\":\"dflash\", \"model\": \"/models/Qwen3.8-27B-DFlash2\", \"num_speculative_tokens\":7}'"
