We now serve Qwen3.8-27b (NVIDIA NVFP4 checkpoint) on one DGX Spark, next to Nemotron 3.5 Bolt, with the eugr/spark-vllm nightly image (vLLM 0.32.0rc1, FlashInfer 0.7.2). We measured it under Ollama and vLLM, with and without speculative decoding.
There are already good threads on DFlash2 with SGLang for this model. This one adds vLLM numbers, a direct MTP vs DFlash2 comparison under concurrent load, and an Ollama detail that skews many comparisons.
A few findings:
Ollama turns MTP on by default for qwen3.8:27b. The server log shows “creating MTP draft context” with draft_num_predict 4. Ollama with MTP: 16.2 tok/s. Ollama without (native API, draft_num_predict: 0): 8.1 tok/s. If you compared Ollama against vLLM without a draft model, you compared different things. We did too, at first.
Like for like, vLLM is faster: no draft 12.3 vs 8.1 tok/s, MTP 28.6 vs 16.2. Without a draft model vLLM uses about 79 % of the 273 GB/s bandwidth, Ollama about 47 %.
DFlash2 (z-lab, 8 draft tokens) is the fastest for one request: 38.0 tok/s, 3.17 tokens per verification step. MTP (3 tokens) wins as soon as several requests run: 84.2 vs 66.4 tok/s at 4 concurrent, 133.0 vs 118.8 at 8. DFlash2’s eight proposals per request cost compute the batch then lacks. Pick by your real load.
Ollama ran with n_seq_max = 1 by default, so 4 concurrent requests just queue (16.4 tok/s aggregate). Setting OLLAMA_NUM_PARALLEL=4 still loaded with n_seq_max = 1 for us, presumably because of MTP. Happy to be corrected on that one.
--gpu-memory-utilization does not cover the MTP layer. At 0.47 with MTP, available memory dropped from 17.6 to 10.2 GiB while the KV cache was allocated, and our watchdog killed it. DFlash2 at the same 0.47 left 22 GiB. We run MTP at 0.42.
Two vLLM instances on one Spark must not start at the same time. Each counted the other’s growing memory as its own overhead: Bolt computed -52 GiB of KV space and both aborted. Our systemd units now wait (ExecStartPre) until the other service is either down or fully loaded.
Long context eats the draft gain: with DFlash2, decode drops from 38 tok/s on short prompts to about 20 at 32k tokens of real text. Prefill about 2,600 tok/s at 8k, about 1,400 at 100k.
Without a thinking budget, 8 of 10 of our prompts never got to an answer at max_tokens 2048. With thinking_token_budget 768, all did.
FlashInfer #3566 (cuDNN FP8 GEMM failing on GB10, which crashed our Qwen3.6 service) is fixed from FlashInfer 0.7.0 via PR #4165, as long as cuDNN is older than 9.23.1. Older images like timothystewart6/vllm-gb10 0.28 still need the cuBLAS patch.
Full write-up with the start command, memory breakdown from the vLLM log, the wait script, long-context tables and what went wrong: Qwen3.8-27B on one DGX Spark: 38 tok/s with vLLM | ALLSmartLLM
Questions and comparison numbers welcome, especially if someone got Ollama running with several parallel slots and MTP.
