This is a follow-up to my earlier benchmark of 8 serving configurations for Qwen3.8-27B on a single DGX Spark.
In that study, I compared vLLM, TensorFold, MTP, and DFlash2 with thinking enabled, focusing on the time required to produce complete answers and their correctness.
Since then, I’ve extended the work into four additional studies. Instead of optimizing only decoding speed, I wanted to answer a broader question:
How can we get correct answers fastest from a local reasoning model?
I tested different thinking levels, parallel branches, a community fine-tune, Qwen3.8-Flash-Next, and ways to prevent long reasoning loops.
Setup
Hardware: One NVIDIA DGX Spark (GB10, 128 GB unified memory)
Engine: TensorFold 0.6.0
Models: Qwen3.8-27B NVFP4 + DFlash2, and Qwen3.8-Flash-Next NVFP4 with its built-in MTP
Tasks: 400 coding and reasoning problems (200 each)
Output limit: 65,536 tokens
Metric: Minutes per correct answer = total inference time, including failed attempts, divided by the number of correct answers
The same 400 tasks and graders were used across configurations.
Results
| Model | Strategy | Correct / 400 | Min / correct |
| 27B | Deep thinking | 372 | 3.97 |
| 27B | Low thinking | 363 | 0.86 |
| 27B | 4 parallel low-thinking branches | 373 | 0.93 |
| 27B | Deep + 32K thinking budget | 383 | 3.25 |
| Flash Next | Deep thinking | 364 | 4.00 |
| Flash Next | Low thinking | 384 | 1.72 |
| Flash Next | 4 parallel low-thinking branches | 391 | 2.24 |
| Flash Next | Deep + 32K thinking budget | 387 | 2.99 |
| Flash Next | Deep + sampling + 32K budget | 393 | 3.71 |
1. Longer thinking was not necessarily better
On these tasks, low thinking was substantially faster than default deep thinking, without a statistically detectable accuracy disadvantage for the 27B.
The 4-branch strategy was also competitive in time per correct answer. For tasks with extractable answers, branches used majority/plurality voting; for code-generation tasks, the first completed branch containing code was selected.
2. Deep thinking sometimes got stuck in reasoning loops
This was especially interesting because @reallyboring mentioned a similar long-reasoning problem in my original thread.
On the 400 tasks:
Flash Next hit the 65,536-token output limit 29 times during greedy deep thinking.
Qwen3.8-27B hit the limit 17 times.
Many of these responses repeated earlier reasoning or kept reconsidering the same cases without producing a final answer.
Simply increasing the output limit did not reliably solve the problem.
3. A 32K thinking budget helped
I tested several ways to address these failures, including sampling, a repetition detector, and limiting the thinking phase.
With greedy decoding and a 32,768-token thinking budget:
Flash Next: 364 → 387 correct; 4.00 → 2.99 minutes per correct answer.
27B: 372 → 383 correct; 3.97 → 3.25 minutes per correct answer.
Neither model hit the overall output limit under this configuration.
The engine closes the thinking section after 32,768 thinking tokens and lets the model continue with its final answer.
For these tasks, this worked better than allowing the model to think indefinitely.
Only the 32K budget was tested, so I wouldn’t claim it is universally optimal.
Reproduction and limitations
The repository includes the implementation, pinned dependencies and checkpoints, per-task results, statistical comparisons, and scripts to recompute the published tables.
The 400 tasks and graders are private, so the published scores cannot be independently reproduced on the exact same task set. The code can be run on other tasks, and public examples are provided.
Other important limitations:
One DGX Spark, one run per configuration and task.
The 400 tasks were relatively easy for these models, with most configurations achieving over 90% accuracy.
Some budget comparisons were follow-up analyses, not preregistered primary tests.
Results may differ with other models, inference engines, workloads, and hardware.
Repository
Full seven-part study:
Inference-time strategies:
Reasoning loops and thinking budgets:
I’m sharing these results in case they’re useful to others running reasoning models locally.
I’d be particularly interested in whether anyone has observed similar reasoning loops on GPQA, coding benchmarks, or long-context assistant workloads, and whether a fixed thinking budget helps.
Independent results, including cases where these findings don’t hold, would be very welcome.
