Qwen3-Omni-30B-A3B-Instruct on the DGX Spark with vLLM — recipe, with the evidence attached
We put together a small recipe for serving Qwen3-Omni-30B-A3B-Instruct
through vLLM on a DGX Spark, with audio, image and video inputs, and we
published the evidence behind it rather than just the conclusion. If
something in it is wrong for your machine, the receipts are there so you can
tell which part.
Repository: GitHub - Diego-Revolteo/qwen3-omni-dgx-spark: Serve Qwen3-Omni-30B-A3B-Instruct (audio, image, video, tools) through vLLM on an NVIDIA DGX Spark — recipe with the evidence attached · GitHub
What is actually verified
  • run.sh’s flags were compared flag by flag against a live
    docker inspect of the container that was serving the model. There are
    zero unexplained differences. The receipt is evidence/run-sh-parity.json
    and the inspect itself is in evidence/. The handful of differences that
    do exist are all deliberate and listed there: a generic $MODEL_DIR mount
    instead of a fixed snapshot path, container name, --rm, and passing the
    API key by variable name so the value never lands in ps.
  • Two of those differences are security-relevant, and they are the live
    container’s
    behaviour rather than the recipe’s: it published port 8000
    on a non-loopback host address, and it bind-mounted the Hugging Face
    cache read-write. run.sh binds 127.0.0.1 and supplies the cache
    through environment variables instead, so the recipe is the more contained
    of the two. See evidence/container-runtime-fields.json.
  • The Dockerfile was compared against that image’s real
    docker history --no-trunc: one custom RUN layer, adding librosa and
    soundfile, over base vllm/vllm-openai:v0.21.0. The layer performs the
    same steps as the recipe’s RUN and differs only in the quoting of the
    print arguments inside it. See evidence/image-history.json.
  • The hardware figures were read with plain commands, and each one names the
    command that produced it in evidence/hardware-receipt.json.
What is not verified, stated plainly
  • The image we read the recipe off was not built from this Dockerfile —
    it predates it. What matches is the single custom layer and the base, not
    a rebuild. Nobody has run docker build on this file and checked.
  • The librosa / soundfile versions are not measured. The original
    build layer printed them but did not record them, and reading them would
    need a container run. The Dockerfile leaves them unpinned rather than
    pinning a guess.
  • 64k context is configured, not demonstrated. The launcher defaults to
    --max-model-len 64000 and the live container’s configuration really
    contains 64000 — that is in the inspect. But the context actually exercised
    end-to-end with every modality and tool gate passing was 8192.
  • The model is not pinned to an upstream revision. We record the local
    snapshot identifier we used; we do not claim an upstream commit.
The one thing that bit us
--gpu-memory-utilization 0.70 passed every functional case — text, image,
audio, video, both tool cases, all HTTP 200 — and we still rejected it and
rolled back, because the kernel threw NV_ERR_NO_MEMORY during start-up.
The retry at 0.60 passed and stayed. So run.sh ships 0.60.
This is reported from the operator’s launch receipt and run progress
notes, not published in evidence/
. One honest correction to our own
story: we have since seen the same kernel message during other model
loads on this machine that went on to serve normally. So the message by
itself is not proof that 0.70 is bad; we kept 0.60 because it is the value
we measured end to end. Details in KNOWN-ISSUES item 8.
Worth flagging because “all my tests passed” and “I shipped it” are
different claims, and a scary log line is not a failed test either.
Numbers from the 0.60 run
Functionally qualified, single machine, not a vendor benchmark:
  • model footprint at load: 59.22 GiB; load time 381.0 s
  • available KV cache after load: 12.2 GiB
  • per-case wall clock (single sequence, --max-model-len 8192,
    --gpu-memory-utilization 0.60): text 18.23 s, image 2.03 s,
    audio 8.59 s, video_bounded 4.80 s, tool cases 1.03 s and 1.86 s
These came from one machine and one vLLM build. Your numbers will differ.
Things people usually trip on, all in KNOWN-ISSUES.md
  • the model ships its template as a JSON document; vLLM’s --chat-template
    wants the bare Jinja, so the recipe ships the extracted template
  • qwen3_xml returned tool calls as plain text; --tool-call-parser hermes
    worked
  • the audio pip layer is easy to lose when you move to a new base tag, and
    you find out on the first audio request
  • two vLLM containers on the same GPU do not coexist for the same
    weights
    — that is the case we hit; different weights on the same GPU are
    outside what we tested
A caveat on the authority-injection check
We have exactly one fixture where the model refused an authority-injection
prompt. That is one data point, not a safety property. We say so in
KNOWN-ISSUES.md rather than letting it read like a guarantee.
Corrections and pull requests welcome — especially on the four “not
verified” items listed above (rebuild reproduction, the librosa /
soundfile versions, the 64k context, and the upstream revision), which are
the parts we would most like to get wrong less often.
