R 31.1 Package application problems
We recently purchased 10 more xaiver boards.
So, like I did before, I downloaded and applied the 31.1 version of the package.
However, there is no action after the log in the boot process.
Can you apply the 31.1 version of the package to the latest xavier board?
[ 0.000000] **********************************************************
[ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 0.000000] ** **
[ 0.000000] ** trace_printk() being used. Allocating extra memory. **
[ 0.000000] ** **
[ 0.000000] ** This means that this is a DEBUG kernel and it is **
[ 0.000000] ** unsafe for production use. **
[ 0.000000] ** **
[ 0.000000] ** If you see this message and you are not debugging **
[ 0.000000] ** the kernel, report this immediately to your vendor! **
[ 0.000000] ** **
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000006] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009312] Console: colour dummy device 80x25
[ 0.012605] console [tty0] enabled
[ 0.016309] bootconsole [tegra_comb_uart0] disabled
<hit enter to activate fiq debugger]
That is the very first Xavier release of L4T. Is there a reason you want this older release? Any release more recent than this (in which you are able to use that release) will probably be helpful to you in the long run.
Are you using the dev kit carrier board? If not, then you need to add the correct board support package on top of this for the third party carrier board.
