# R-Core for AGI I am not building conventional AI, and I am not building another LLM
I am not building conventional AI, and I am not building another LLM.
My goal is to create a system that, in the way it works, is closer to AGI.
While working on this, I came to the conclusion that the problem starts much deeper — at the level of the computing architecture itself.
The biological brain does not work like a flat diagram:
module → module → module → result
A neuron is simultaneously part of a huge network. Its state is influenced by many other neurons, synaptic connections of different strengths, excitatory and inhibitory signals, local circuits, feedback loops, and time.
The previous state of the network affects how that same network will respond at the next moment.
So this is not one sequential “line” of computation.
It is closer to many interconnected lines existing in a multidimensional space, simultaneously interacting with and influencing one another.
That is why I decided not to start with another AI model.
I started with the computing core itself.
That is how R-Core appeared — a nonlinear computing core with persistent internal state and interaction between its nodes.
Today I already have R-Core Gen7, and on the later generations I am continuing to build my AI/AGI architecture without an LLM or a transformer being the foundation of the intelligence.
But Gen7 remains private for now.
What I am giving you is Gen1.
It is the first, older, and much simpler generation of the core.
A patent application has already been filed for the R-Core architecture.
Code and materials:
GitHub - etoyruben-wq/R-CORE- · GitHub
Study it. Run it. Break it. Scale it. Change the topology. Try your own approaches.
But one warning:
the usual “module on top of module on top of module” approach may not be very effective here.
First, you need to become familiar with the core itself and understand its own computational model.
I am not looking for comments that simply say “interesting.”
Found a weakness? Show the test.
Found an interesting property? Show the test.
Made the core work better? Show the result.
And for those who genuinely understand R-Core, I have a bonus.
I have developed another separate technology for reducing memory requirements and transmitting data efficiently.
A patent application has also been filed for that technology.
According to its mathematical model, for example, 8K video can be transmitted over a channel of approximately 1.5 Mbps. The calculated value from the formulas is actually lower, but I am deliberately using the rounded figure of 1.5 Mbps here.
I am not making that technology public yet.
The first people to get access to it will be those who genuinely become familiar with Gen1, run the core, perform their own tests, and show real results.
And the conditions will be the same for everyone.
The same R-Core Gen1, the same information, and the same starting point will be given to the engineering communities of AMD, NVIDIA, and Intel.
Same materials.
Same core.
Same rules.
After that, I will take it to other relevant technical and AI communities as well.
I do not care which logo is above the forum.
I care about who actually understands the core and does something with it.
And one more thing about me:
I am not a programmer.
I simply look at the direction in which the AI industry is moving, and I see some things that, in my opinion, are heading in the wrong direction.
So I had to interfere a little. 😁
Hopefully I can finish what I am doing with computing cores and AI as soon as possible.
Because I already have a few questions for physics as well.
The sooner I finish here, the sooner I can go and put my two cents into physics too. 😁
For now, though, here is R-Core Gen1.
Break it.
