Do you know where can I find the patch file:
0001-ARM64-adding-OV5693-V4L2-on-E3326-jetson_cv.patch
And how can I apply the patches on top of the kernel?
Thank you.
Thank you.
It is quoted here, from which you could copy and paste:
https://devtalk.nvidia.com/default/topic/920739/jetson-tx1/l4t-r23-2-for-jetson-tx1-released/post/4824232/#4824232
Thank you. Now I am trying to build the kernel but it gives me the following error:
HOSTLD scripts/dtc/dtc
CC scripts/mod/empty.o
as: unrecognized option '-EL'
make[3]: *** [scripts/mod/empty.o] Error 1
make[2]: *** [scripts/mod] Error 2
make[1]: *** [scripts] Error 2
make: *** [sub-make] Error 2
Also I could not configure the kernel, because each time I try to configure the kernel it creates .config file in the root directory of the kernel source, then I try to build kernel and it prompts me to call make mrproper. When I call mrproper, it deletes .config file. Whenever I create .config, I am prompted to call make mrproper so there is a vicious circle.
I have run into the “-EL” issue on a version 6.1 Linaro tool chain, but not with the earlier 4.8 through 5.3 chains. The “-EL” is for the assembler, and tells the assembler this is little endian ARM (but all of the Linaro toolchains are “-EL” anyway…"-EL" is like telling the chain to use the default it is using anyway, but if it doesn’t recognize the option it aborts). Which compiler/toolchain version were you using?
So far as being told to make mrproper, and having config create end up causing the compiler to want mrproper again, I am wondering if you are compiling the kernel in the source tree, or if you are naming a separate kernel compile build directory? I suspect the latter, as this can happen when part of clean/configure/build misses the “O=…location…” step. If this is the case, remember to go the kernel source, “make mrproper” and also “make O=location mrproper”. Then all future commands, including configuration commands, should have the “O=” parameter. The actual location specified in “O=” should be cleanly deleted and the directory recreated for cases like this.
