I have installed R31.1 with JetPack4.1.1 and noticed some unexpected things, at least to my knowledge.
- Firewall
[ 10.437264] systemd[1]: Set hostname to <jetson-xxxxxxxxxxxxxx>.
[ 10.506246] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 10.509859] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
May someone shed some light about what this implies ?
- bmi160 and nvs
[ 11.655194] android_work: did not send uevent (0 0 (null))
[ 11.679718] bmi160 8-0069: nvs_vregs_init vdd err=-19
[ 11.681417] bmi160 8-0069: nvs_vregs_init vdd_IO err=-19
[ 11.737489] tegra-i2c 31e0000.i2c: no acknowledge from address 0x69
[ 11.740024] bmi160 8-0069: bmi_i2c_rd ERR: 0x00
[ 11.741495] bmi160 8-0069: bmi_init _id_i2c ERR
[ 11.742803] bmi160 8-0069: bmi_pm pm_en=0 ERR=-22
[ 11.744095] bmi160 8-0069: bmi_remove
[ 11.744098] bmi160 8-0069: bmi_probe done
I do see related (unused) modules:
lsmod
Module Size Used by
fuse 103334 3
bnep 16619 2
nvs_bmi160 22076 0
nvs 53924 1 nvs_bmi160
bluedroid_pm 14104 0
ip_tables 18922 0
x_tables 29079 1 ip_tables
The device tree indeed seems to mention a device on I2C bus 8 at address 69, looking at /proc/device-tree/i2c@31e0000, but no device answers at this address.
This has been dirty fixed by bzip2ing both kernel modules: /lib/modules/4.9.108-tegra/kernel/drivers/misc/nvs/nvs.ko and /lib/modules/4.9.108-tegra/kernel/drivers/iio/imu/nvs_bmi/nvs_bmi160.ko.
- However systemctl still gives:
systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● systemd-modules-load.service loaded failed failed Load Kernel Modules
Any idea why ? May a cleaner way to fix point 2 fix this ?
- I have also updated with apt and faced the Ubuntu missing toolbars after reboot, this has been fixed by clearing compiz cache as usual:
sudo rm -rf .cache/compizconfig-1/
(No answer expected here)
sha1sums are all ok in /etc/nv_tegra_release.
Thanks for sharing.
