R32.3.1 Need way to update nvidia jetson tx2 with out using recovery mode
If it was documented correctly all the emmc partitions should be writable from the actual nvidia platform.
How to create data files that go into the different partitions, and then “dd” could be used to program the partitions.
Terry
R32.3.1 is the first release which will feature OTA update via apt. Unfortunately, this release needs to be flashed with the usual JetPack/SDK Manager/L4T tools. When a new release comes out (beyond R32.3.1) you should be able to just update over the net with apt if you are already running R32.3.1.
