This is in the README from deepstream_sdk_v4.0.2_jetson.tbz2. But trying to load cuda will fail with disk space problems.
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p1 14G 9.4G 3.7G 73% /
none 1.9G 0 1.9G 0% /dev
How can I get deepstream to work on the tx2-4g
Additional components required on the target
To successfully use the DeepStream SDK, the following additional
components must be installed and set up on the target system:
- CUDA (10.0)
- TensorRT (6.0+)
- OpenCV (3.3.1)
- VisionWorks (1.6)
Install these packages using JetPack SDK Manager.
Terry
