did nvidia change the system so the kernel is never updated/changed for sudo apt upgrade?
If I upgrade to ubuntu 20.04 will it change my kernel?
@LinuxDev any input please
Thanks,
Terry
Thanks,
Terry
There are kernel features required for a Jetson to boot. I do not know of specific changes, but you can assume the kernel itself will only be upgraded if there is a version available which works with a Jetson. I do not know if a 20.04 update would change the kernel since this isn’t officially supported, but you can bet that if an unsupported kernel is used, then boot is likely to fail. At the least there would be features which fail.
