Would you try this (just adapt to your camera resolution). Works fine for me:
#!/usr/bin/env python
import signal
import sys
import time
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GObject
# Signal handler for stopping pipeline before destruction, so that Argus keeps ok.
def signal_handler(sig, frame):
p.set_state(Gst.State.NULL)
sys.exit(0)
# Initialize gstreamer
GObject.threads_init()
Gst.init(None)
# Define pipeline
gst_str = "nvarguscamerasrc name=camera \
! video/x-raw(memory:NVMM),format=NV12,width=3264,height=2464,framerate=21/1,pixel-aspect-ratio=1/1 \
! queue max-size-buffers=1 leaky=2 name=q1 \
! tee name=t \
t. ! queue name=q3 \
! nvvidconv name=stalkerLoc flip-method=2 top=520 bottom=1659 left=1012 right=2451 \
! video/x-raw(memory:NVMM),width=1440,height=1140 \
! nvvidconv \
! video/x-raw(memory:NVMM),width=480,height=380,pixel-aspect-ratio=1/1 \
! nvoverlaysink name=displaySink overlay-x=0 overlay-y=360 overlay-w=480 overlay-h=380 \
t. ! queue name=q4 \
! valve name=stp \
! nvvidconv name=stpconv \
! video/x-raw,format=I420 \
! gdkpixbufoverlay name=reticalpic location=/usr/share/unity-control-center/icons/hicolor/48x48/devices/audio-speaker-left-side.svg offset-x=1682 offset-y=840 \
! nvvidconv \
! video/x-raw(memory:NVMM),format=I420,width=3264,height=2464,pixel-aspect-ratio=1/1 \
! queue ! nvjpegenc \
! image/jpeg,framerate=21/1 \
! multifilesink name=stalkerPicture location=./stalkerPic_%08d.jpg max-files=1 \
t. ! queue name=q5 \
! nvvidconv name=b \
! video/x-raw, width=1920, height=1080 \
! gdkpixbufoverlay name=reticalvid location=/usr/share/unity-control-center/icons/hicolor/48x48/devices/audio-speaker-left-side.svg offset-x=710 offset-y=390 \
! queue \
! nvvidconv \
! video/x-raw(memory:NVMM), width=1920, height=1080 \
! nvv4l2h264enc maxperf-enable=1 bitrate=8000000 \
! video/x-h264, stream-format=byte-stream \
! h264parse \
! valve name=stalkercreatevideo \
! splitmuxsink name=stalkerVideoSink async-handling=true location=/dev/null async=false"
# Create the pipeline
pipeline = Gst.parse_launch (gst_str)
# Register signal handler for proper termination if receiving SIGINT such as Ctrl-C
signal.signal(signal.SIGINT, signal_handler)
# Start the pipeline
pipeline.set_state(Gst.State.READY)
pipeline.set_state(Gst.State.PAUSED)
pipeline.set_state(Gst.State.PLAYING)
# Run for 5s
time.sleep(5)
# Done. Stop the pipeline before restarting.
pipeline.set_state(Gst.State.NULL)
#time.sleep(1)
# Because of a bug, need to reset properties of nvoverlaysink before restarting
# See: https://forums.developer.nvidia.com/t/nvoverlaysink-ignores-properties-when-pipeline-is-restarted/179379/8
overlay = pipeline.get_by_name("displaySink")
overlay.set_property("overlay-x", 0)
overlay.set_property("overlay-y", 0)
overlay.set_property("overlay-w", 0)
overlay.set_property("overlay-h", 0)
overlay.set_property("overlay-y", 360)
overlay.set_property("overlay-w", 480)
overlay.set_property("overlay-h", 380)
# Run for 5s
time.sleep(5)
# Done. Stop the pipeline before clean up on exit.
exit(0)
For EOS management, you may also try this:
import sys, os
import gi
gi.require_version('Gtk', '3.0')
from gi.repository import Gst, GObject, Gtk
def verbose_deep_notify_cb(object, orig, pspec, component):
A quick attempt to mimic gst-launch verbose mode.
if pspec.value_type == Gst.Caps.__gtype__:
caps = orig.get_current_caps()
if caps != None:
print("%s/%s/%s: caps = \"%s\"" % (object.get_name(), orig.parent.get_name(), orig.get_name(), caps.to_string()))
class GTK_Main:
def __init__(self):
window = Gtk.Window(Gtk.WindowType.TOPLEVEL)
window.set_title("CamRecorder")
window.set_default_size(100, 100)
window.connect("destroy", Gtk.main_quit, "WM destroy")
vbox = Gtk.VBox()
window.add(vbox)
hbox = Gtk.HBox()
vbox.pack_start(hbox, False, False, 0)
hbox.set_border_width(10)
hbox.pack_start(Gtk.Label(), False, False, 0)
self.button = Gtk.Button("Start")
self.button.connect("clicked", self.start_stop)
hbox.pack_start(self.button, False, False, 0)
self.button2 = Gtk.Button("Quit")
self.button2.connect("clicked", self.exit)
hbox.pack_start(self.button2, False, False, 0)
hbox.add(Gtk.Label())
window.show_all()
# Set up the gstreamer pipeline
! tee name=t \
! nvvidconv \
! valve name=stp \
! nvvidconv \
! queue \
! nvvidconv \
! h264parse \
self.player = Gst.parse_launch (gst_str)
self.player.connect('deep-notify', verbose_deep_notify_cb, self)
bus = self.player.get_bus()
bus.add_signal_watch()
bus.enable_sync_message_emission()
bus.connect("message", self.on_message)
def start_stop(self, w, data=None):
if self.button.get_label() == "Start":
overlay = self.player.get_by_name("displaySink")
print("Setting pipeline to READY ...")
self.player.set_state(Gst.State.READY)
print("Setting pipeline to PAUSED ...")
self.player.set_state(Gst.State.PAUSED)
print("Setting pipeline PLAYING...")
self.player.set_state(Gst.State.PLAYING)
self.button.set_label("Stop")
else:
print("Setting pipeline to NULL ...")
self.player.set_state(Gst.State.NULL)
self.button.set_label("Start")
def exit(self, w):
Gtk.main_quit()
def on_message(self, bus, message):
t = message.type
if t == Gst.MessageType.EOS:
print('Received message type EOS')
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
print "Error: %s" % err, debug
Gst.debug_set_active(True)
Gst.debug_set_default_threshold(0)
Gst.init(None)
GTK_Main()
Gtk.main()
