I get this message, how do I fix it, it is causing other apps to “Wait”
Terry
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
Lumenera 8M camera.
The app was not starting all the time so I made changes and now the app sometimes does not terminate.
It says something about Destroy all libargus objects before destroying the camera provider to avoid these warning,
Setting set_state(NULL) hangs so how am I suppose to cleanup correctly?
Jun 9 13:34:30 BaseSystem_0_6 nvargus-daemon[2946]: === VideoSystem[2988]: CameraProvider destroyed (0x7f7478dce0)=== VideoSystem[2988]: WARNING: Cleaning up 1 outstanding requests…=== VideoSystem[2988]: WARNING: Cleaning up 1 outstanding stream settings…=== VideoSystem[2988]: WARNING: Cleaning up 1 outstanding queues…=== VideoSystem[2988]: WARNING: Cleaning up 1 outstanding sessions…SCF: Error BadParameter: NV-DEBUG: Skip shutterEvent when Timestamp(249030341556) (in src/services/capture/DeviceCaptureRequest.cpp, function notifyCsiFrameStart(), line 99)
Jun 9 13:34:30 BaseSystem_0_6 nvargus-daemon[2946]: SCF: Error BadParameter: NV-DEBUG: Skip shutterEvent when Timestamp(249030374882) (in src/services/capture/DeviceCaptureRequest.cpp, function notifyCsiFrameStart(), line 99)
Jun 9 13:34:30 BaseSystem_0_6 nvargus-daemon[2946]: SCF: Error BadParameter: NV-DEBUG: Skip shutterEvent when Timestamp(249030408208) (in src/services/capture/DeviceCaptureRequest.cpp, function notifyCsiFrameStart(), line 99)
Jun 9 13:34:31 BaseSystem_0_6 nvargus-daemon[2946]: === VideoSystem[2988]: WARNING: Cleaning up 1 outstanding streams…(Argus) Error InvalidState: Unknown stream deleted. (in src/api/CaptureSessionImpl.cpp, function outputStreamDeleted(), line 783)
Jun 9 13:34:35 BaseSystem_0_6 nvargus-daemon[2946]: === VideoSystem[2988]: NOTE: Destroy all libargus objects before destroying the CameraProvider to avoid these warnings.
Jun 9 13:34:35 BaseSystem_0_6 systemd[1]: nvargus-daemon.service: Main process exited, code=killed, status=11/SEGV
Jun 9 13:34:35 BaseSystem_0_6 systemd[1]: nvargus-daemon.service: Failed with result ‘signal’.
Jun 9 13:34:35 BaseSystem_0_6 systemd[1]: nvargus-daemon.service: Service hold-off time over, scheduling restart.
Jun 9 13:34:35 BaseSystem_0_6 systemd[1]: nvargus-daemon.service: Scheduled restart job, restart counter is at 18.
