I see that nv3dsink pretends to support Y42B format from both system and NVMM memory:
gst-inspect-1.0 nv3dsink
Pad Templates:
SINK template: 'sink'
Availability: Always
Capabilities:
video/x-raw
format: { (string)RGBA, (string)BGRA, (string)ARGB, (string)ABGR, (string)RGBx, (string)BGRx, (string)xRGB, (string)xBGR, (string)AYUV, (string)Y444, (string)I420, (string)YV12, (string)NV12, (string)NV21, (string)Y42B, (string)Y41B, (string)RGB, (string)BGR, (string)RGB16 }
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
video/x-raw(memory:NVMM)
However, it works from system memory:
gst-launch-1.0 videotestsrc ! video/x-raw,format=Y42B ! nv3dsink
but doesn’t work from NVMM memory:
gst-launch-1.0 videotestsrc ! video/x-raw,format=Y42B ! nvvidconv ! 'video/x-raw(memory:NVMM),format=Y42B' ! nv3dsink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0:
streaming stopped, reason not-negotiated (-4)
Execution ended after 0:00:00.001645571
Setting pipeline to NULL ...
Freeing pipeline ...
Though, nv3dsink works from NVMM memory using NV12 format:
gst-launch-1.0 videotestsrc ! video/x-raw,format=Y42B ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nv3dsink
So is Y42B from NVMM memory expected to work, or is it just a nv3dsink caps reporting error ?
