We are currently trying to get an IMX390 camera to work on the Jetson Orin 64GB. The /dev/video0 device file is created. When we start the nvgstcapture-1.0 tool we get an error message.
desktop:~$ nvgstcapture-1.0 --automate --capture-auto
Encoder null, cannot set bitrate!
Encoder Profile = High
bitrate = 4000000
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
Using winsys: x11
Opening in BLOCKING MODE
** Message: 13:52:16.115: <main:4651> iterating capture loop ....
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 31.622776; Exposure Range min 59000, max 33333000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:694 NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:247 (propagating)
Starting automation...
In the Jetson release notes (https://developer.download.nvidia.com/embedded/L4T/r35_Release_v1.0/Jetson_Linux_Release_Notes_r35.1.pdf) we found an issue entry (Issue 3589917) for the imx390 camera. Unfortunately, the description did not solve the problem for us. We used the jetson-io tool to activate the imx390 camera.
Do we need to make changes to the device tree before we can use the imx390 camera
Hardware used
- Jetson AGX Orin (Jetpack 5.0.2)
- LI-JXAV-MIPI-ADPT-4CAM
- LI-GMSL2-IPX-DESER
- LI-IMX390-GMSL2-120H (only one camera at this moment)
dmesg-log
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (buildbrain@mobile-u64-5273-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Wed Aug 10 20:17:07 PDT 2022
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x82294ea98 SMBIOS=0xffff0000 SMBIOS 3.0=0x803850000 MEMATTR=0x8047ab018 ESRT=0x803b85f98 RNG=0x827945998 MEMRESERVE=0x8047acf18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000803b85f98 to 0x0000000803b85fd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000817800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000835ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000007ffffffff]
[ 0.000000] node 0: [mem 0x0000000800000000-0x00000008021bffff]
[ 0.000000] node 0: [mem 0x00000008021c0000-0x00000008035d2fff]
[ 0.000000] node 0: [mem 0x00000008035d3000-0x000000080376dfff]
[ 0.000000] node 0: [mem 0x000000080376e000-0x000000080383ffff]
[ 0.000000] node 0: [mem 0x0000000803840000-0x000000080385ffff]
[ 0.000000] node 0: [mem 0x0000000803860000-0x000000080457ffff]
[ 0.000000] node 0: [mem 0x0000000804580000-0x000000080470ffff]
[ 0.000000] node 0: [mem 0x0000000804710000-0x000000080477ffff]
[ 0.000000] node 0: [mem 0x0000000804780000-0x000000080479ffff]
[ 0.000000] node 0: [mem 0x00000008047a0000-0x00000008047bffff]
[ 0.000000] node 0: [mem 0x00000008047c0000-0x0000000804a2ffff]
[ 0.000000] node 0: [mem 0x0000000804a30000-0x0000000804a7ffff]
[ 0.000000] node 0: [mem 0x0000000804a80000-0x0000000804a8ffff]
[ 0.000000] node 0: [mem 0x0000000804a90000-0x0000000804adffff]
[ 0.000000] node 0: [mem 0x0000000804ae0000-0x0000000804f3ffff]
[ 0.000000] node 0: [mem 0x0000000804f40000-0x000000080557ffff]
[ 0.000000] node 0: [mem 0x0000000805580000-0x000000080561ffff]
[ 0.000000] node 0: [mem 0x0000000805620000-0x00000008056cffff]
[ 0.000000] node 0: [mem 0x00000008056d0000-0x000000080576ffff]
[ 0.000000] node 0: [mem 0x0000000805770000-0x00000008057fffff]
[ 0.000000] node 0: [mem 0x0000000805800000-0x000000080589ffff]
[ 0.000000] node 0: [mem 0x00000008058a0000-0x000000080616ffff]
[ 0.000000] node 0: [mem 0x0000000806170000-0x000000080634ffff]
[ 0.000000] node 0: [mem 0x0000000806350000-0x00000008278fffff]
[ 0.000000] node 0: [mem 0x0000000827900000-0x000000082794ffff]
[ 0.000000] node 0: [mem 0x0000000827950000-0x000000082b6affff]
[ 0.000000] node 0: [mem 0x000000082c400000-0x000000082c7fffff]
[ 0.000000] node 0: [mem 0x0000000834000000-0x0000000835ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000835ffffff]
[ 0.000000] On node 0 totalpages: 8051376
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 118144 pages used for memmap
[ 0.000000] Normal zone: 7527088 pages, LIFO batch:63
[ 0.000000] On node 0, zone Normal: 336 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[ 0.000000] pcpu-alloc: s90136 r8192 d32744 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 00 [0] 01 [0] 02 [0] 03 [0] 04 [0] 05 [0] 06 [0] 07
[ 0.000000] pcpu-alloc: [0] 08 [0] 09 [0] 10 [0] 11
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7925040
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effe0000-0x00000000fffe0000] (256MB)
[ 0.000000] Memory: 30994428K/32205504K available (18432K kernel code, 3172K rwdata, 7156K rodata, 3968K init, 1095K bss, 948932K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000742] Console: colour dummy device 80x25
[ 0.000921] printk: console [tty0] enabled
[ 0.000959] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000968] pid_max: default: 32768 minimum: 301
[ 0.001027] LSM: Security Framework initializing
[ 0.001049] Yama: becoming mindful.
[ 0.001065] SELinux: Initializing.
[ 0.001150] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001197] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.003015] rcu: Hierarchical SRCU implementation.
[ 0.003106] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003626] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.003635] DTB Build time: Aug 10 2022 20:31:40
[ 0.005064] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.005179] Remapping and enabling EFI services.
[ 0.006396] smp: Bringing up secondary CPUs ...
[ 0.035061] Detected PIPT I-cache on CPU1
[ 0.035092] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.035119] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.063726] Detected PIPT I-cache on CPU2
[ 0.063736] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.063750] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.092319] Detected PIPT I-cache on CPU3
[ 0.092327] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.092340] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.122955] Detected PIPT I-cache on CPU4
[ 0.122977] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.123002] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.151632] Detected PIPT I-cache on CPU5
[ 0.151643] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.151658] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.180253] Detected PIPT I-cache on CPU6
[ 0.180263] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.180277] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.208878] Detected PIPT I-cache on CPU7
[ 0.208888] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.208901] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.239527] Detected PIPT I-cache on CPU8
[ 0.239549] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.239575] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.268199] Detected PIPT I-cache on CPU9
[ 0.268209] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.268224] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.297438] Detected PIPT I-cache on CPU10
[ 0.297450] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.297463] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.326667] Detected PIPT I-cache on CPU11
[ 0.326678] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.326693] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.326748] smp: Brought up 1 node, 12 CPUs
[ 0.326811] SMP: Total of 12 processors activated.
[ 0.326816] CPU features: detected: Privileged Access Never
[ 0.326819] CPU features: detected: LSE atomic instructions
[ 0.326821] CPU features: detected: User Access Override
[ 0.326824] CPU features: detected: 32-bit EL0 Support
[ 0.326827] CPU features: detected: Common not Private translations
[ 0.326830] CPU features: detected: RAS Extension Support
[ 0.326833] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.326837] CPU features: detected: CRC32 instructions
[ 0.326840] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.360106] CPU: All CPU(s) started at EL2
[ 0.362390] devtmpfs: initialized
[ 0.377564] Registered cp15_barrier emulation handler
[ 0.377577] Registered setend emulation handler
[ 0.377583] KASLR enabled
[ 0.377686] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.377701] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.379285] pinctrl core: initialized pinctrl subsystem
[ 0.379775] SMBIOS 3.0.0 present.
[ 0.379781] DMI: /, BIOS 1.0-d7fb19b 08/10/2022
[ 0.380027] NET: Registered protocol family 16
[ 0.380827] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.381038] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.381235] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.381260] audit: initializing netlink subsys (disabled)
[ 0.381345] audit: type=2000 audit(0.380:1): state=initialized audit_enabled=0 res=1
[ 0.381489] thermal_sys: Registered thermal governor 'step_wise'
[ 0.381491] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.381498] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.383635] cpuidle: using governor menu
[ 0.383736] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.383850] ASID allocator initialised with 32768 entries
[ 0.383936] Serial: AMBA PL011 UART driver
[ 0.385466] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.385488] Tegra reboot handler registered.
[ 0.403381] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[ 0.403396] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[ 0.403405] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[ 0.403412] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[ 0.403419] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[ 0.403426] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[ 0.403433] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[ 0.403440] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[ 0.403447] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[ 0.403454] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[ 0.403460] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[ 0.403467] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[ 0.403474] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[ 0.403481] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[ 0.403488] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[ 0.403495] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[ 0.403502] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[ 0.403510] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.403532] mc-err: mcerr ops are set to t23x
[ 0.403797] tegra234-cbb 13a00000.cbb-fabric: secure_irq = 21
[ 0.403847] tegra234-cbb c600000.aon-fabric: secure_irq = 22
[ 0.403887] tegra234-cbb d600000.bpmp-fabric: secure_irq = 23
[ 0.403922] tegra234-cbb de00000.dce-fabric: secure_irq = 24
[ 0.403956] tegra234-cbb be00000.rce-fabric: secure_irq = 25
[ 0.403992] tegra234-cbb b600000.sce-fabric: secure_irq = 26
[ 0.404199] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 66, base_baud = 0) is a SBSA
[ 1.654566] printk: console [ttyAMA0] enabled
[ 1.662790] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.669501] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.676202] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.682901] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.691294] ACPI: Interpreter disabled.
[ 1.696287] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.701172] vbusA-cvb: supplied by vdd-5v-sys
[ 1.705640] vbusB-cvb: supplied by vdd-5v-sys
[ 1.710115] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.715011] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.720074] iommu: Default domain type: Translated
[ 1.724989] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.731235] SCSI subsystem initialized
[ 1.735037] usbcore: registered new interface driver usbfs
[ 1.740534] usbcore: registered new interface driver hub
[ 1.745858] usbcore: registered new device driver usb
[ 1.751084] mc: Linux media interface: v0.10
[ 1.755363] videodev: Linux video capture interface: v2.00
[ 1.760989] pps_core: LinuxPPS API ver. 1 registered
[ 1.765954] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.775089] PTP clock support registered
[ 1.779194] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.786358] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.793997] Registered efivars operations
[ 1.798450] FPGA manager framework
[ 1.801888] Advanced Linux Sound Architecture Driver Initialized.
[ 1.808224] Bluetooth: Core ver 2.22
[ 1.811806] NET: Registered protocol family 31
[ 1.816250] Bluetooth: HCI device and connection manager initialized
[ 1.822608] Bluetooth: HCI socket layer initialized
[ 1.827484] Bluetooth: L2CAP socket layer initialized
[ 1.832542] Bluetooth: SCO socket layer initialized
[ 1.837896] camchar: rtcpu character device driver loaded
[ 1.843511] clocksource: Switched to clocksource arch_sys_counter
[ 2.000851] VFS: Disk quotas dquot_6.6.0
[ 2.004816] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.011822] pnp: PnP ACPI: disabled
[ 2.017131] la/ptsa driver initialized.
[ 2.021015] NET: Registered protocol family 2
[ 2.025567] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.035255] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 2.043997] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.052286] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.060116] TCP: Hash tables configured (established 262144 bind 65536)
[ 2.066818] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.073747] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.081181] NET: Registered protocol family 1
[ 2.085790] RPC: Registered named UNIX socket transport module.
[ 2.091726] RPC: Registered udp transport module.
[ 2.096430] RPC: Registered tcp transport module.
[ 2.101134] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.107588] PCI: CLS 0 bytes, default 64
[ 2.111617] Trying to unpack rootfs image as initramfs...
[ 2.226092] Freeing initrd memory: 8196K
[ 2.232200] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.240124] kvm [1]: IPA Size Limit: 48 bits
[ 2.244553] kvm [1]: VHE mode initialized successfully
[ 2.250354] Initialise system trusted keyrings
[ 2.254894] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 2.263309] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.269387] NFS: Registering the id_resolver key type
[ 2.274451] Key type id_resolver registered
[ 2.278631] Key type id_legacy registered
[ 2.282669] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.289375] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.296779] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.312932] NET: Registered protocol family 38
[ 2.317378] Key type asymmetric registered
[ 2.321476] Asymmetric key parser 'x509' registered
[ 2.326371] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.333825] io scheduler mq-deadline registered
[ 2.338356] io scheduler kyber registered
[ 2.346160] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.351759] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.357346] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.362933] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.370840] tegra_dc_assign_hw_data: no matching compatible node
[ 2.376853] tegradccommon module_init failed
[ 2.381120] tegradc module_init failed
[ 2.385105] EINJ: ACPI disabled.
[ 2.389794] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.396683] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.401821] tegra-pmc: ### PMC reset level: L1
[ 2.406262] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.412454] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.425971] random: fast init done
[ 2.426107] printk: console [ttyTCU0] enabled
[ 4.062611] arm-smmu 12000000.iommu: probing hardware configuration...
[ 4.070615] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.075472] arm-smmu 12000000.iommu: stage 1 translation
[ 4.081034] arm-smmu 12000000.iommu: stage 2 translation
[ 4.086582] arm-smmu 12000000.iommu: nested translation
[ 4.092035] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.099451] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.108281] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.114983] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.121687] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.129240] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.135947] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.140765] arm-smmu 10000000.iommu: stage 1 translation
[ 4.146309] arm-smmu 10000000.iommu: stage 2 translation
[ 4.151847] arm-smmu 10000000.iommu: nested translation
[ 4.157302] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.164717] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.173389] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.180082] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.186780] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.193910] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.200533] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.205282] arm-smmu 8000000.iommu: stage 1 translation
[ 4.210737] arm-smmu 8000000.iommu: stage 2 translation
[ 4.216192] arm-smmu 8000000.iommu: nested translation
[ 4.221552] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.228897] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.237468] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.244097] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.250703] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.258069] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.268332] tegra_profiler: version: 1.147, samples/io: 49/28
[ 4.274306] tegra_profiler: auth: init
[ 4.278439] nvsciipc: loaded module
[ 4.282968] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 4.289142] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[ 4.295672] tegra23x-qspi 3270000.spi: Node prod: Child has not proper setting
[ 4.303093] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 4.310699] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 4.317224] tegra23x-qspi 3270000.spi: Failed to get reset control: -517
[ 4.324696] tun: Universal TUN/TAP device driver, 1.6
[ 4.330323] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.337758] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.343236] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.348336] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.354432] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.359962] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.365838] PPP generic driver version 2.4.2
[ 4.370274] PPP BSD Compression module registered
[ 4.375100] PPP Deflate Compression module registered
[ 4.380306] PPP MPPE Compression module registered
[ 4.385249] usbcore: registered new interface driver r8152
[ 4.390889] usbcore: registered new interface driver asix
[ 4.396434] usbcore: registered new interface driver ax88179_178a
[ 4.402705] usbcore: registered new interface driver cdc_ether
[ 4.408698] usbcore: registered new interface driver net1080
[ 4.414523] usbcore: registered new interface driver cdc_subset
[ 4.420598] usbcore: registered new interface driver zaurus
[ 4.426327] usbcore: registered new interface driver cdc_ncm
[ 4.432151] usbcore: registered new interface driver aqc111
[ 4.437985] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.444340] ohci-pci: OHCI PCI platform driver
[ 4.448936] ohci-platform: OHCI generic platform driver
[ 4.454559] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 4.460816] usbcore: registered new interface driver uas
[ 4.466290] usbcore: registered new interface driver usb-storage
[ 4.472608] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 4.478745] mousedev: PS/2 mouse device common for all mice
[ 4.484490] usbcore: registered new interface driver xpad
[ 4.491878] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.497342] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:31 UTC (31)
[ 4.505570] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.511985] i2c /dev entries driver
[ 4.515673] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 4.521496] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 4.527231] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 4.532912] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 4.538577] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 4.544256] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 4.549946] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 4.555623] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 4.564150] device-mapper: uevent: version 1.0.3
[ 4.568969] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.578705] sdhci: Secure Digital Host Controller Interface driver
[ 4.585051] sdhci: Copyright(c) Pierre Ossman
[ 4.589513] Synopsys Designware Multimedia Card Interface Driver
[ 4.595740] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.601714] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 4.602000] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.602087] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 4.621746] tegra-bpmp bpmp: firmware: 888a114dda6bea50b6c6-eac380526d6
[ 4.629663] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.635519] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 4.646655] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.652575] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
[ 6.137863] hid: raw HID events driver (C) Jiri Kosina
[ 6.143684] usbcore: registered new interface driver usbhid
[ 6.149428] usbhid: USB HID core driver
[ 6.154067] tegra-dce d800000.dce: Adding to iommu group 6
[ 6.160978] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 6.169977] tegra234-aon c000000.aon: Adding to iommu group 7
[ 6.176936] c000000.aon:hsp: probed
[ 6.180833] tegra234-aon c000000.aon: init done
[ 6.185783] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 6.191831] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 6.196136] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 6.200809] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [0]. Ignored...
[ 6.207262] tegra23x-psc e860000.psc: init done
[ 6.216073] dce: dce_admin_send_cmd_ver:413 version : [0x2] err : [0x0]
[ 6.221001] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 6.227738] dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [1] ...
[ 6.227748] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [1]. Ignored...
[ 6.234946] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.242710] dce: dce_admin_setup_clients_ipc:518 Get queue info failed for [2]
[ 6.242820] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 6.255125] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.259867] dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [3] ...
[ 6.259868] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [3]. Ignored...
[ 6.259879] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [3]. Ignored...
[ 6.267448] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.276569] dce: dce_start_boot_flow:100 DCE_BOOT_DONE
[ 6.285822] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.340418] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.352309] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.364926] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.377793] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.390140] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (117)
[ 6.396986] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.409415] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=7a10e4613e151d2bf1df37dd80d456800f5b94d0
[ 6.422942] t19x_cache tegra-cache: probed
[ 6.427372] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.442897] optee: probing for conduit method.
[ 6.447500] optee: revision 3.16 (65cc2218)
[ 6.448347] optee: dynamic shared memory is enabled
[ 6.457779] optee: initialized driver
[ 6.473698] nvpmodel: initialized successfully
[ 6.478376] tegra_hv: get_hvd: not initialized yet
[ 6.483324] user_ivc_mempool: hypervisor not present
[ 6.489333] usbcore: registered new interface driver snd-usb-audio
[ 6.496565] u32 classifier
[ 6.499350] input device check on
[ 6.503131] Actions configured
[ 6.506777] Initializing XFRM netlink socket
[ 6.511593] NET: Registered protocol family 10
[ 6.517164] Segment Routing with IPv6
[ 6.520990] NET: Registered protocol family 17
[ 6.525583] NET: Registered protocol family 15
[ 6.530195] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.544151] Bluetooth: RFCOMM socket layer initialized
[ 6.549552] Bluetooth: RFCOMM ver 1.11
[ 6.553445] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.559562] Bluetooth: HIDP socket layer initialized
[ 6.565440] 9pnet: Installing 9P2000 support
[ 6.569906] Key type dns_resolver registered
[ 6.575183] registered taskstats version 1
[ 6.579437] Loading compiled-in X.509 certificates
[ 6.589292] Loaded X.509 cert 'Build time autogenerated kernel key: 90ac610178c49616e6b7af33d5f8183bf0ea1ee9'
[ 6.599887] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[ 6.611700] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.618819] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[ 6.630193] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.636973] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[ 6.648132] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.654643] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 6.675754] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 13
[ 6.685574] host1x 13e40000.host1x: Adding to iommu group 14
[ 7.701728] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 7.719587] host1x 13e40000.host1x: initialized
[ 7.724590] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 15
[ 7.732707] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 7.744680] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 16
[ 7.752741] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 7.764697] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 17
[ 7.772754] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 7.784723] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 18
[ 7.792800] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 7.804751] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 19
[ 7.812815] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 7.824777] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 20
[ 7.832831] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 7.844794] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 21
[ 7.852841] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 7.864796] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 22
[ 7.872851] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 7.884826] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 23
[ 7.892930] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 7.904891] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 24
[ 7.912958] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 7.924912] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 25
[ 7.932986] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 7.944921] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 26
[ 7.952979] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 7.964916] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 27
[ 7.972952] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 7.984922] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 28
[ 7.992980] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 8.004954] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 29
[ 8.013026] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 8.024961] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 30
[ 8.033005] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 8.044990] falcon 15340000.vic: Adding to iommu group 31
[ 8.058927] falcon 15340000.vic: initialized
[ 8.063583] falcon 15380000.nvjpg: Adding to iommu group 32
[ 8.074746] falcon 15380000.nvjpg: initialized
[ 8.079439] falcon 15540000.nvjpg1: Adding to iommu group 33
[ 8.087664] random: crng init done
[ 8.093153] falcon 15540000.nvjpg1: initialized
[ 8.097930] falcon 154c0000.nvenc: Adding to iommu group 34
[ 8.111810] falcon 154c0000.nvenc: initialized
[ 8.116500] falcon 15a50000.ofa: Adding to iommu group 35
[ 8.126898] falcon 15a50000.ofa: initialized
[ 8.131415] nvdec 15480000.nvdec: Adding to iommu group 36
[ 8.146996] nvdec 15480000.nvdec: initialized
[ 8.151601] tsec 15500000.tsec: Adding to iommu group 37
[ 8.165719] tsec 15500000.tsec: initialized
[ 8.172454] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 8.188424] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 8.203529] gpio-394 (camera-control-output-low): hogged as output/low
[ 8.210301] gpio-397 (camera-control-output-low): hogged as output/low
[ 8.217088] gpio-487 (camera-control-output-low): hogged as output/low
[ 8.223864] gpio-486 (camera-control-output-low): hogged as output/low
[ 8.231543] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 8.238692] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 8.245688] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 8.252130] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 8.258657] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 8.264906] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 8.272906] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 8.281484] tegra194-isp5 14800000.isp: Adding to iommu group 38
[ 8.290311] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 8.299971] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 8.306449] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 8.315713] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e40000.host1x:nvcsi@15a00000- bound
[ 8.325106] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 39
[ 8.333199] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 40
[ 8.341235] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 8.351167] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 8.357992] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 8.367949] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 8.374768] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 8.384690] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 8.391531] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 41
[ 8.400263] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 8.411702] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 42
[ 8.420389] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 8.431834] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 43
[ 8.440559] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 8.451984] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 44
[ 8.460721] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 8.472078] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 45
[ 8.480764] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 8.492125] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 46
[ 8.500841] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 8.512213] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 47
[ 8.520915] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 8.532272] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 48
[ 8.540961] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 8.552373] pva 16000000.pva0: Adding to iommu group 49
[ 8.583250] pva 16000000.pva0: initialized
[ 8.594029] nvdla 15880000.nvdla0: Adding to iommu group 50
[ 8.608908] nvdla 15880000.nvdla0: initialized
[ 8.615018] nvdla 158c0000.nvdla1: Adding to iommu group 51
[ 8.629241] nvdla 158c0000.nvdla1: initialized
[ 8.635365] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 8.642341] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 8.649814] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 8.656480] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 8.663225] serial-tegra 3100000.serial: Adding to iommu group 3
[ 8.669960] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[ 8.679655] serial-tegra 3130000.serial: Adding to iommu group 3
[ 8.686210] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 8.695840] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[ 8.702405] tegra23x-qspi 3270000.spi: Node prod: Child has not proper setting
[ 8.709888] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 8.717541] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 8.748784] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 8.758592] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.764215] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.772853] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 8.782495] tegra-xusb 3610000.xhci: irq 235, io mem 0x03610000
[ 8.788889] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.797412] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.804874] usb usb1: Product: xHCI Host Controller
[ 8.809914] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.816218] usb usb1: SerialNumber: 3610000.xhci
[ 8.821568] hub 1-0:1.0: USB hub found
[ 8.825472] hub 1-0:1.0: 4 ports detected
[ 8.829847] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.835425] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 8.843253] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.850788] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.859326] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.866776] usb usb2: Product: xHCI Host Controller
[ 8.871798] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.878102] usb usb2: SerialNumber: 3610000.xhci
[ 8.883276] hub 2-0:1.0: USB hub found
[ 8.887168] hub 2-0:1.0: 4 ports detected
[ 8.903176] pca954x 2-0070: supply vcc-pullup not found, using dummy regulator
[ 8.910803] pca954x 2-0070: pca954x_probe: forcing device bus number, start 30.
[ 8.918354] pca954x 2-0070: device detect skipped.
[ 8.923939] imx390 30-001b: probing v4l2 sensor.
[ 8.928883] imx390 30-001b: tegracam sensor driver:imx390_v2.0.6
[ 8.935177] imx390 30-001b: board setup failed
[ 8.939913] imx390 30-001c: probing v4l2 sensor.
[ 8.944779] imx390 30-001c: tegracam sensor driver:imx390_v2.0.6
[ 8.950983] imx390 30-001c: board setup failed
[ 8.955677] max9296 30-0048: [MAX9296]: probing GMSL Deserializer
[ 8.962054] max9296 30-0048: max9296_probe: success
[ 8.967262] max9295 30-0062: [MAX9295]: probing GMSL Serializer
[ 8.973434] max9295 30-0062: max9295_probe: success
[ 8.978633] max9295 30-0040: [MAX9295]: probing GMSL Serializer
[ 8.984832] max9295 30-0040: max9295_probe: success
[ 8.990037] max9295 30-0060: [MAX9295]: probing GMSL Serializer
[ 8.996182] max9295 30-0060: max9295_probe: success
[ 9.001344] i2c i2c-2: Added multiplexed i2c bus 30
[ 9.006725] i2c i2c-2: Added multiplexed i2c bus 31
[ 9.012137] i2c i2c-2: Added multiplexed i2c bus 32
[ 9.017517] i2c i2c-2: Added multiplexed i2c bus 33
[ 9.022581] pca954x 2-0070: registered 4 multiplexed busses for I2C switch pca9546
[ 9.053924] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 9.067509] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 9.081621] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 9.091517] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 9.094442] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 9.106788] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 9.109048] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 9.120270] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 9.127456] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 9.128248] irq: IRQ302: trimming hierarchy from :interrupt-controller@f400000-1
[ 9.128863] mmc0: CQHCI version 5.10
[ 9.136170] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 9.143857] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[ 9.147481] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 9.183504] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 9.251655] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 9.260082] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 9.267438] usb 1-3: Product: Bluetooth Radio
[ 9.271917] usb 1-3: Manufacturer: Realtek
[ 9.276132] usb 1-3: SerialNumber: 00e04c000001
[ 9.279508] tegra194-pcie 14100000.pcie: Link up
[ 9.282028] mmc0: Command Queue Engine enabled
[ 9.287336] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 9.290139] mmc0: periodic cache flush enabled
[ 9.290145] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 9.296970] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 9.301873] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 9.308100] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 9.308103] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 9.313934] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
[ 9.318411] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 9.318461] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 9.338211] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 9.339283] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 9.376062] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 9.376325] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 9.382427] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 9.396026] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 9.404448] pci 0001:01:00.0: supports D1 D2
[ 9.408857] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 9.419867] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 9.425156] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 9.427323] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 9.435748] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.442103] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 9.449458] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 9.457441] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 9.462101] usb 2-3: Manufacturer: Generic
[ 9.468404] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 9.477994] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 9.483200] hub 2-3:1.0: USB hub found
[ 9.484296] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 9.490337] hub 2-3:1.0: 4 ports detected
[ 9.495545] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 9.508433] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 9.517392] pcieport 0001:00:00.0: Adding to iommu group 10
[ 9.523366] pcieport 0001:00:00.0: PME: Signaling with IRQ 51
[ 9.529549] pcieport 0001:00:00.0: AER: enabled with IRQ 51
[ 9.536100] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 9.543507] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 9.543792] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 9.557597] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 9.566323] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 9.575022] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 9.719791] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 9.728223] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.735573] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 9.740324] usb 1-4: Manufacturer: Generic
[ 9.746389] hub 1-4:1.0: USB hub found
[ 9.751648] hub 1-4:1.0: 4 ports detected
[ 10.467507] usb 1-4.3: new full-speed USB device number 4 using tegra-xusb
[ 10.587636] usb 1-4.3: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 10.596233] usb 1-4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.603766] usb 1-4.3: Product: USB Receiver
[ 10.608162] usb 1-4.3: Manufacturer: Logitech
[ 10.619446] input: Logitech USB Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.0/0003:046D:C534.0001/input/input0
[ 10.692129] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.3/input0
[ 10.693074] tegra194-pcie 14160000.pcie: Phy link never came up
[ 10.709458] input: Logitech USB Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0002/input/input1
[ 10.711009] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 10.724328] input: Logitech USB Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0002/input/input2
[ 10.730565] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 10.730569] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 10.760121] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 10.770944] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 10.778867] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 10.785203] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 10.798098] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 10.803498] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 10.803902] input: Logitech USB Receiver System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0002/input/input3
[ 10.812442] pcieport 0004:00:00.0: Adding to iommu group 11
[ 10.826309] hid-generic 0003:046D:C534.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.3/input1
[ 10.831731] pcieport 0004:00:00.0: PME: Signaling with IRQ 53
[ 10.850924] pcieport 0004:00:00.0: AER: enabled with IRQ 53
[ 10.856885] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 10.862972] pci 0004:00:00.0: Removing from iommu group 11
[ 10.868630] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 10.876041] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 10.882519] tegra194-pcie 141a0000.pcie: Failed to get slot regulators: -517
[ 10.882605] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 10.887648] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 10.892587] vdd-dp: supplied by vdd-3v3-sys
[ 10.897034] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 10.901989] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 10.909050] tegra194-isp5 14800000.isp: initialized
[ 10.918062] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 10.924514] (NULL device *): fops function table already registered
[ 10.932804] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 10.939252] imx390 30-001b: probing v4l2 sensor.
[ 10.944078] imx390 30-001b: tegracam sensor driver:imx390_v2.0.6
[ 11.084805] max9295 30-0062: max9295_write_reg:i2c write failed, 0x0 = 80
[ 11.344077] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx390 30-001b bound
[ 11.353232] imx390 30-001b: Detected IMX390 sensor
[ 11.358243] imx390 30-001c: probing v4l2 sensor.
[ 11.363050] debugfs: Directory 'imx390_a' with parent '/' already present!
[ 11.370139] imx390 30-001c: tegracam sensor driver:imx390_v2.0.6
[ 11.377462] max9295 30-0062: max9295_write_reg:i2c write failed, 0x0 = c0
[ 11.385618] max9295 30-0060: max9295_write_reg:i2c write failed, 0x10 = 22
[ 11.392827] max9295 30-0060: max9295_setup_control: ERROR: ser device not found
[ 11.400356] imx390 30-001c: gmsl serializer setup failed
[ 11.511644] imx390 30-001c: imx390_probe gmsl serdes setup failed
[ 11.517960] imx390: probe of 30-001c failed with error -121
[ 11.524339] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 11.524372] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 11.540022] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 302
[ 11.645039] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 11.652232] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 11.660926] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 11.669616] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 12.582726] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 12.785082] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 12.791243] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 12.798065] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 12.803712] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 12.813818] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 12.824659] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 12.832581] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 12.838911] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 12.851921] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 12.857319] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.866270] pcieport 0005:00:00.0: Adding to iommu group 12
[ 12.872228] pcieport 0005:00:00.0: PME: Signaling with IRQ 55
[ 12.878506] pcieport 0005:00:00.0: AER: enabled with IRQ 55
[ 12.884466] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 12.890564] pci 0005:00:00.0: Removing from iommu group 12
[ 12.896219] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 12.904036] nvethernet 6810000.ethernet: Adding to iommu group 52
[ 12.910655] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 12.918824] nvethernet 6810000.ethernet: failed to read MDIO address
[ 12.925381] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 12.932286] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 13.324508] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:83:f4:e8
[ 13.332190] -->macsec_probe()
[ 13.332204] -->macsec_get_platform_res()
[ 13.332229] <--macsec_get_platform_res()
[ 13.332231] -->macsec_enable_car()
[ 13.332442] <--macsec_enable_car()
[ 13.332458] <--macsec_probe()
[ 13.332460] nvethernet 6810000.ethernet: Macsec not enabled
[ 13.338200] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 13.347490] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 13.356214] irq: IRQ304: trimming hierarchy from :pmc@c360000
[ 13.362186] irq: IRQ305: trimming hierarchy from :interrupt-controller@f400000-1
[ 13.369878] irq: IRQ306: trimming hierarchy from :pmc@c360000
[ 13.375862] input: gpio-keys as /devices/platform/gpio-keys/input/input6
[ 13.383833] tegra-se-nvhost 15810000.se: Adding to iommu group 53
[ 13.390486] tegra-se-nvhost 15810000.se: initialized
[ 13.405867] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 13.412275] tegra-se-nvhost 15820000.se: Adding to iommu group 54
[ 13.418857] tegra-se-nvhost 15820000.se: initialized
[ 13.426159] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 13.432552] tegra-se-nvhost 15840000.se: Adding to iommu group 55
[ 13.439099] tegra-se-nvhost 15840000.se: initialized
[ 13.448000] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 13.454845] tegra_actmon d230000.actmon: in actmon_register()...
[ 13.461201] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 13.467779] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 13.476214] hvc_sysfs: hypervisor is not present
[ 13.612581] ALSA device list:
[ 13.615649] No soundcards found.
[ 13.619714] Freeing unused kernel memory: 3968K
[ 13.624421] Run /init as init process
[ 13.628188] with arguments:
[ 13.628189] /init
[ 13.628189] with environment:
[ 13.628190] HOME=/
[ 13.628191] TERM=linux
[ 13.628192] mminit_loglevel=4
[ 13.639381] Root device found: mmcblk0p1
[ 13.643914] Found dev node: /dev/mmcblk0p1
[ 13.675303] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 13.684451] Rootfs mounted over mmcblk0p1
[ 13.706526] Switching from initrd to actual rootfs
[ 13.717126] usb 1-4.3: USB disconnect, device number 4
[ 13.827780] systemd[1]: System time before build time, advancing clock.
[ 13.874156] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 13.897851] systemd[1]: Detected architecture arm64.
[ 13.959830] systemd[1]: Set hostname to <owita-desktop>.
[ 14.147378] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 14.160434] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 14.170137] systemd[1]: Created slice system-modprobe.slice.
[ 14.176498] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 14.183327] systemd[1]: Created slice User and Session Slice.
[ 14.189363] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 14.197438] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 14.207244] systemd[1]: Reached target User and Group Name Lookups.
[ 14.213880] systemd[1]: Reached target Slices.
[ 14.218528] systemd[1]: Reached target Swap.
[ 14.223229] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 14.230155] systemd[1]: Listening on Syslog Socket.
[ 14.235319] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 14.242328] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 14.249325] systemd[1]: Listening on Journal Audit Socket.
[ 14.255106] systemd[1]: Listening on Journal Socket (/dev/log).
[ 14.261355] systemd[1]: Listening on Journal Socket.
[ 14.266627] systemd[1]: Listening on udev Control Socket.
[ 14.272333] systemd[1]: Listening on udev Kernel Socket.
[ 14.278969] systemd[1]: Mounting Huge Pages File System...
[ 14.285717] systemd[1]: Mounting POSIX Message Queue File System...
[ 14.293238] systemd[1]: Mounting RPC Pipe File System...
[ 14.299842] systemd[1]: Mounting Kernel Debug File System...
[ 14.306780] systemd[1]: Mounting Kernel Trace File System...
[ 14.314051] systemd[1]: Starting Journal Service...
[ 14.327917] systemd[1]: Starting Set the console keyboard layout...
[ 14.335532] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 14.344451] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 14.353968] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 14.362143] systemd[1]: Started Nameserver information manager.
[ 14.368765] systemd[1]: Reached target Network (Pre).
[ 14.375438] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 14.384825] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 14.389257] systemd[1]: Starting Load Kernel Modules...
[ 14.400722] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 14.407899] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 14.408615] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 14.408848] systemd[1]: Starting udev Coldplug all Devices...
[ 14.426263] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x000000082f000000,16777216
[ 14.428033] systemd[1]: Started Journal Service.
[ 14.435890] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 14.435896] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
[ 14.435897] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 14.435900] nvmap_page_pool_init: Total RAM pages: 7817184
[ 14.435901] nvmap_page_pool_init: nvmap page pool size: 977148 pages (3816 MB)
[ 14.435959] nvmap_background_zero_thread: PP zeroing thread starting.
[ 14.436035] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[ 14.439006] misc nvmap: created heap fsi base 0x000000082f000000 size (16384KiB)
[ 14.505545] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 14.539896] systemd-journald[309]: Received client request to flush runtime journal.
[ 14.853223] using random self ethernet address
[ 14.858189] using random host ethernet address
[ 14.902527] nvidia: loading out-of-tree module taints kernel.
[ 14.913812] nv_platform 13800000.display: Adding to iommu group 56
[ 14.917206] platform 13800000.display:nvdisplay-niso: Adding to iommu group 57
[ 14.918031] spi-tegra114 3210000.spi: Adding to iommu group 3
[ 14.918651] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.1.0 Release Build (buildbrain@mobile-u64-5273-d7000) Wed Aug 10 20:32:39 PDT 2022
[ 14.923684] spi-tegra114 3230000.spi: Adding to iommu group 3
[ 14.941729] irq: IRQ307: trimming hierarchy from :pmc@c360000
[ 14.941740] nct1008_nct72 4-004c: starting parse dt
[ 14.941791] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 14.941793] nct1008_nct72 4-004c: success parsing dt
[ 14.941888] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 14.948923] cpu-throttle-alert cooling device registered.
[ 14.949280] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 14.949281] gpu-throttle-alert cooling device registered.
[ 14.950357] cv0-throttle-alert cooling device registered.
[ 14.953202] cv1-throttle-alert cooling device registered.
[ 14.954083] cv2-throttle-alert cooling device registered.
[ 14.954418] soc0-throttle-alert cooling device registered.
[ 14.954752] soc1-throttle-alert cooling device registered.
[ 14.955143] soc2-throttle-alert cooling device registered.
[ 14.957368] hot-surface-alert cooling device registered.
[ 14.966760] qspi_mtd spi6.0: MX25U51279G (65536 Kbytes)
[ 14.966767] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 14.977864] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 14.978679] nct1008_nct72 4-004c: EXT shutdown limit 107
[ 15.015316] nct1008_nct72 4-004c: initial LOC temp: 43000
[ 15.015851] nct1008_nct72 4-004c: initial EXT temp: 45750
[ 15.016869] nct1008_nct72 4-004c: hi_b:-4, lo_b:0
[ 15.017613] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 15.051625] nvadsp 2993000.adsp: Adding to iommu group 58
[ 15.051782] nvadsp 2993000.adsp: in probe()...
[ 15.052333] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 15.055900] 1 fixed-partitions partitions found on MTD device spi6.0
[ 15.062746] Creating 1 MTD partitions on "spi6.0":
[ 15.068148] 0x000000000000-0x000004000000 : "Whole_flash0"
[ 15.127083] tegra-asoc: sound: Adding to iommu group 58
[ 15.154193] irq: IRQ309: trimming hierarchy from :pmc@c360000
[ 15.154283] tegra-hda 3510000.hda: Adding to iommu group 59
[ 15.184248] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 15.191998] ucsi_ccg 1-0008: Port-0: no role switch found
[ 15.192305] gpio gpiochip0: (tegra234-gpio): gpiochip_lock_as_irq: tried to flag a GPIO set as output for IRQ
[ 15.192550] tegra210-adsp aconnect@2a41000:adsp_audio: Adding to iommu group 58
[ 15.202641] tegra210_adsp_audio_probe: platform probe started
[ 15.202971] tegra210-adsp tegra210-adsp: Default param-type to BYTE for mp3-dec1
[ 15.203192] gpio gpiochip0: (tegra234-gpio): unable to lock HW IRQ 126 for IRQ
[ 15.203221] tegra210-adsp tegra210-adsp: Default param-type to BYTE for spkprot
[ 15.210649] genirq: Failed to request resources for 1-0008 (irq 309) on irqchip gpio
[ 15.210681] ucsi_ccg 1-0008: request_threaded_irq failed - -5
[ 15.212532] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=3 as /devices/platform/3510000.hda/sound/card0/input7
[ 15.212726] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=7 as /devices/platform/3510000.hda/sound/card0/input8
[ 15.212794] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=8 as /devices/platform/3510000.hda/sound/card0/input9
[ 15.212834] input: NVIDIA Jetson AGX Orin HDA HDMI/DP,pcm=9 as /devices/platform/3510000.hda/sound/card0/input10
[ 15.218874] tegra210-adsp tegra210-adsp: Default param-type to BYTE for src
[ 15.224969] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aac-dec1
[ 15.225215] tegra210-adsp tegra210-adsp: Default param-type to BYTE for aec
[ 15.225454] tegra210-adsp tegra210-adsp: Default param-type to BYTE for wire
[ 15.225457] tegra210-adsp tegra210-adsp: adma channel page address dt entry not found
[ 15.225458] tegra210-adsp tegra210-adsp: using adma channel page 0
[ 15.225506] nvadsp 2993000.adsp: ADSP OS firmware already loaded
[ 15.225524] ucsi_ccg: probe of 1-0008 failed with error -5
[ 15.246864] usbcore: registered new interface driver btusb
[ 15.260219] loop: module loaded
[ 15.270978] rtl88x2ce 0001:01:00.0: Adding to iommu group 10
[ 15.271292] rtl88x2ce 0001:01:00.0: enabling device (0000 -> 0003)
[ 15.272827] rtk_btusb: Realtek Bluetooth USB driver ver 3.1
[ 15.272831] rtk_btcoex: rtk_btcoex_init: version: 1.2
[ 15.272832] rtk_btcoex: create workqueue
[ 15.272906] rtk_btcoex: alloc buffers 1792, 2432 for ev and l2
[ 15.272944] rtk_btusb: btusb_probe intf->cur_altsetting->desc.bInterfaceNumber 0
[ 15.272945] rtk_btusb: btusb_probe can_wakeup 1, may wakeup 0
[ 15.272947] rtk_btusb: patch_add
[ 15.272948] rtk_btusb: auto suspend is disabled
[ 15.272950] rtk_btusb: pid = 0x3549
[ 15.272952] rtk_btusb: patch_add: Reset gEVersion to 0xff
[ 15.272957] rtk_btusb: set_bit(HCI_QUIRK_RESET_ON_CLOSE, &hdev->quirks);
[ 15.273065] rtk_btusb: btusb_probe: done
[ 15.273092] usbcore: registered new interface driver rtk_btusb
[ 15.273109] rtk_btusb: btusb_open start
[ 15.273112] rtk_btusb: btusb_open hdev->promisc ==0
[ 15.273114] rtk_btusb: download_patch start
[ 15.273116] rtk_btusb: chip type value: 0x73
[ 15.273118] rtk_btusb: HCI reset.
[ 15.284754] rtk_btusb: read_ver_rsp->lmp_subver = 0x8822
[ 15.284758] rtk_btusb: read_ver_rsp->hci_rev = 0xc
[ 15.284760] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 15.284762] rtk_btusb: load_firmware start
[ 15.284763] rtk_btusb: lmp_version = 0x8822
[ 15.284765] rtk_btusb: config filename rtl8822cu_config
[ 15.292298] rtk_btusb: no bdaddr file /opt/bdaddr
[ 15.292305] rtk_btusb: 55 ab 23 87 00 00
[ 15.292312] rtk_btusb: Config file length 6, new length 6
[ 15.292314] rtk_btusb: fw name is rtl8822cu_fw
[ 15.294366] cryptd: max_cpu_qlen set to 1000
[ 15.296195] rtk_btusb: This is not 8723a, use new patch style!
[ 15.296200] rtk_btusb: rtk_get_eversion: gEVersion 255
[ 15.297749] rtk_btusb: eversion->status = 0x0, eversion->version = 0x3
[ 15.297751] rtk_btusb: load_firmware: New gEVersion 3
[ 15.297753] rtk_btusb: rtk_get_fw_project_id: opcode 0, len 1, data 13
[ 15.297755] rtk_btusb: lmp_version is 8822, project_id is 8822, match!
[ 15.297755] rtk_btusb: fw_version = 0x9a8cbc9
[ 15.297756] rtk_btusb: number_of_total_patch = 3
[ 15.297757] rtk_btusb: chipID 4
[ 15.297758] rtk_btusb: patch_length 0x8590
[ 15.297759] rtk_btusb: start_offset 0x00005d00
[ 15.297759] rtk_btusb: Svn version: 1940234490
[ 15.297760] rtk_btusb: Coexistence: BTCOEX_20210106-2020
[ 15.297761] rtk_btusb: buf_len = 0x8596
[ 15.297768] rtk_btusb: fw: exists, config file: exists
[ 15.297769] rtk_btusb: load_firmware done
[ 15.297777] rtk_btusb: download_data start
[ 15.467759] rtk_btusb: download_data done
[ 15.467763] rtk_btusb: HCI reset.
[ 15.478775] rtk_btusb: read_ver_rsp->lmp_subver = 0xcbc9
[ 15.478779] rtk_btusb: read_ver_rsp->hci_rev = 0x9a8
[ 15.478780] rtk_btusb: patch_entry->lmp_sub = 0x8822
[ 15.478785] rtk_btusb: Rtk patch end 0
[ 15.478788] rtk_btusb: btusb_open set HCI_RUNNING
[ 15.478804] rtk_btcoex: Open BTCOEX
[ 15.478805] rtk_btusb: btusb_open end
[ 15.480781] rtk_btcoex: BTCOEX hci_rev 0x09a8
[ 15.480785] rtk_btcoex: BTCOEX lmp_subver 0xcbc9
[ 15.500760] rtk_btusb: btusb_notify: hci0 evt 3
[ 15.517550] tegra210-adsp tegra210-adsp: Loaded app wire
[ 15.517556] tegra210-adsp tegra210-adsp: Loaded app apm
[ 15.517558] tegra210-adsp tegra210-adsp: Loaded app adma
[ 15.517561] tegra210-adsp tegra210-adsp: Loaded app adma_tx
[ 15.517564] nvadsp_set_adma_dump_reg: callback for adma reg dump is sent to 00000000ce2ec2a3
[ 15.536509] tegra210-adsp tegra210-adsp: Tegra210 ADSP driver successfully registered
[ 15.582720] Mass Storage Function, version: 2009/09/11
[ 15.582727] LUN: removable file: (no medium)
[ 15.585000] using random self ethernet address
[ 15.589594] using random host ethernet address
[ 15.612659] rndis0: HOST MAC 3a:5f:fc:df:46:3c
[ 15.612664] rndis0: MAC 3a:5f:fc:df:46:3d
[ 15.612987] usb0: HOST MAC 3a:5f:fc:df:46:3e
[ 15.612990] usb0: MAC 3a:5f:fc:df:46:3f
[ 15.619887] tegra-xudc 3550000.xudc: EP 0 (type: ctrl, dir: out) enabled
[ 15.622296] l4tbr0: port 1(rndis0) entered blocking state
[ 15.622307] l4tbr0: port 1(rndis0) entered disabled state
[ 15.622682] device rndis0 entered promiscuous mode
[ 15.628185] l4tbr0: port 2(usb0) entered blocking state
[ 15.628196] l4tbr0: port 2(usb0) entered disabled state
[ 15.628328] device usb0 entered promiscuous mode
[ 16.482845] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.482860] Bluetooth: BNEP socket layer initialized
[ 16.935141] hwmon hwmon4: temp1_input not attached to any thermal zone
[ 17.315236] pstore: Using crash dump compression: deflate
[ 17.315282] printk: console [ramoops-1] enabled
[ 17.315284] pstore: Registered ramoops as persistent store backend
[ 17.315286] ramoops: using 0x200000@0x82c200000, ecc: 0
[ 17.570669] CPU8: shutdown
[ 17.573670] psci: CPU8 killed (polled 0 ms)
[ 17.649511] Aquantia AQR113C 6810000.ethernet:00: No AQR phy_mode setting in DT
[ 17.727714] CPU9: shutdown
[ 17.730673] psci: CPU9 killed (polled 0 ms)
[ 17.838145] CPU10: shutdown
[ 17.841332] psci: CPU10 killed (polled 0 ms)
[ 17.934362] IRQ 122: no longer affine to CPU11
[ 17.940383] CPU11: shutdown
[ 17.943304] psci: CPU11 killed (polled 0 ms)
[ 17.950475] nvgpu: 17000000.ga10b tpc_pg_mask_store:1067 [INFO] no value change, same mask already set
[ 18.023112] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 19.487494] zram: Added device: zram0
[ 19.489173] zram: Added device: zram1
[ 19.489566] zram: Added device: zram2
[ 19.489805] zram: Added device: zram3
[ 19.489997] zram: Added device: zram4
[ 19.490121] zram: Added device: zram5
[ 19.490720] zram: Added device: zram6
[ 19.490901] zram: Added device: zram7
[ 19.558644] zram0: detected capacity change from 0 to 2001199104
[ 19.692269] Adding 1954292k swap on /dev/zram0. Priority:5 extents:1 across:1954292k SS
[ 19.696984] zram1: detected capacity change from 0 to 2001199104
[ 19.735569] Adding 1954292k swap on /dev/zram1. Priority:5 extents:1 across:1954292k SS
[ 19.738324] zram2: detected capacity change from 0 to 2001199104
[ 19.775633] Adding 1954292k swap on /dev/zram2. Priority:5 extents:1 across:1954292k SS
[ 19.778708] zram3: detected capacity change from 0 to 2001199104
[ 19.811706] Adding 1954292k swap on /dev/zram3. Priority:5 extents:1 across:1954292k SS
[ 19.814537] zram4: detected capacity change from 0 to 2001199104
[ 19.855604] Adding 1954292k swap on /dev/zram4. Priority:5 extents:1 across:1954292k SS
[ 19.858534] zram5: detected capacity change from 0 to 2001199104
[ 19.907557] Adding 1954292k swap on /dev/zram5. Priority:5 extents:1 across:1954292k SS
[ 19.910560] zram6: detected capacity change from 0 to 2001199104
[ 19.943554] Adding 1954292k swap on /dev/zram6. Priority:5 extents:1 across:1954292k SS
[ 19.946264] zram7: detected capacity change from 0 to 2001199104
[ 19.983583] Adding 1954292k swap on /dev/zram7. Priority:5 extents:1 across:1954292k SS
[ 20.434530] Bridge firewalling registered
[ 21.739554] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 21.740228] nvethernet 6810000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 30.172419] fuse: init (API version 7.32)
[ 30.501140] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for aarch64 35.1.0 Release Build (buildbrain@mobile-u64-5273-d7000) Wed Aug 10 20:32:41 PDT 2022
[ 30.501225] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[ 30.501229] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
[ 30.501240] CPU: 2 PID: 2054 Comm: modprobe Tainted: G O 5.10.104-tegra #1
[ 30.501242] Hardware name: /, BIOS 1.0-d7fb19b 08/10/2022
[ 30.501245] Call trace:
[ 30.501261] dump_backtrace+0x0/0x1d0
[ 30.501264] show_stack+0x30/0x40
[ 30.501274] dump_stack+0xd8/0x138
[ 30.501345] os_dump_stack+0x18/0x20 [nvidia]
[ 30.501394] tlsEntryGet+0x130/0x138 [nvidia]
[ 30.501440] gpumgrGetSomeGpu+0x7c/0x90 [nvidia]
[ 30.501484] threadPriorityStateFree+0xa8/0x2a8 [nvidia]
[ 30.501528] rmclientConstruct_IMPL+0x170/0x240 [nvidia]
[ 30.501572] __nvoc_ctor_RmClient+0x5c/0x88 [nvidia]
[ 30.501616] __nvoc_objCreate_RmClient+0x78/0x110 [nvidia]
[ 30.501660] resservClientFactory+0x28/0x90 [nvidia]
[ 30.501704] serverAllocClient+0x19c/0x318 [nvidia]
[ 30.501748] serverAllocResource+0x140/0x2e0 [nvidia]
[ 30.501792] rmapiAllocWithSecInfo+0x180/0x2e0 [nvidia]
[ 30.501836] rmapiAllocWithSecInfoTls+0x74/0xa8 [nvidia]
[ 30.501880] rmapiControlWithSecInfoTls+0x4a8/0x520 [nvidia]
[ 30.501942] nvkms_call_rm+0x60/0x98 [nvidia_modeset]
[ 30.501982] nvRmApiAlloc+0x30/0x40 [nvidia_modeset]
[ 30.501986] do_one_initcall+0x50/0x2f0
[ 30.501992] do_init_module+0x50/0x200
[ 30.501994] load_module+0x2000/0x22f0
[ 30.501996] __do_sys_finit_module+0xb4/0x100
[ 30.501998] __arm64_sys_finit_module+0x2c/0x40
[ 30.502002] el0_svc_common.constprop.0+0x80/0x1d0
[ 30.502005] do_el0_svc+0x38/0xb0
[ 30.502010] el0_svc+0x1c/0x30
[ 30.502013] el0_sync_handler+0xa8/0xb0
[ 30.502014] el0_sync+0x16c/0x180
[ 30.502021] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[ 30.502024] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:296
[ 30.728244] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080013f result 0x56:
[ 30.729156] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080017e result 0x56:
[ 30.733140] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x2080014a result 0x56:
[ 30.782129] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x730190 result 0x56:
[ 31.146505] NVRM nvAssertFailedNoLog: Assertion failed: minRequiredIsoBandwidthKBPS <= clientBwValues[DISPLAY_ICC_BW_CLIENT_EXT].minRequiredIsoBandwidthKBPS @ kern_disp_0402.c:111
[ 31.146519] CPU: 1 PID: 536 Comm: kworker/u24:3 Tainted: G O 5.10.104-tegra #1
[ 31.146522] Hardware name: /, BIOS 1.0-d7fb19b 08/10/2022
[ 31.146534] Workqueue: dce-async-ipc-wq dce_client_async_event_work
[ 31.146539] Call trace:
[ 31.146547] dump_backtrace+0x0/0x1d0
[ 31.146550] show_stack+0x30/0x40
[ 31.146555] dump_stack+0xd8/0x138
[ 31.146628] os_dump_stack+0x18/0x20 [nvidia]
[ 31.146689] tlsEntryGet+0x130/0x138 [nvidia]
[ 31.146733] kdispArbAndAllocDisplayBandwidth_v04_02+0x274/0x288 [nvidia]
[ 31.146777] kdispInvokeDisplayModesetCallback_KERNEL+0xa8/0xf0 [nvidia]
[ 31.146822] dceclientHandleAsyncRpcCallback+0x17c/0x2f0 [nvidia]
[ 31.146865] initVGXSpecificRegistry+0x1dc/0x300 [nvidia]
[ 31.146868] dce_client_async_event_work+0x6c/0x180
[ 31.146872] process_one_work+0x1c4/0x4a0
[ 31.146874] worker_thread+0x54/0x430
[ 31.146876] kthread+0x148/0x170
[ 31.146878] ret_from_fork+0x10/0x24
[ 31.147758] dce: dce_ipc_read_message:678 Error getting next free buf to read
[ 31.147762] dce: dce_client_process_event_ipc:319 Error in reading DCE msg for ch_type [3]
[ 32.443539] usb 1-4.3: new full-speed USB device number 5 using tegra-xusb
[ 32.562254] usb 1-4.3: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 32.562261] usb 1-4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 32.562263] usb 1-4.3: Product: USB Receiver
[ 32.562265] usb 1-4.3: Manufacturer: Logitech
[ 32.568421] input: Logitech USB Receiver as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.0/0003:046D:C534.0003/input/input11
[ 32.627726] hid-generic 0003:046D:C534.0003: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.3/input0
[ 32.632101] input: Logitech USB Receiver Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0004/input/input12
[ 32.632233] input: Logitech USB Receiver Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0004/input/input13
[ 32.691672] input: Logitech USB Receiver System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0004/input/input14
[ 32.691815] hid-generic 0003:046D:C534.0004: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.3/input1
[ 32.819740] logitech-djreceiver 0003:046D:C534.0003: hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-4.3/input0
[ 32.828004] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
[ 33.060699] logitech-djreceiver 0003:046D:C534.0004: hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-4.3/input1
[ 33.120879] logitech-djreceiver 0003:046D:C534.0004: device of type eQUAD nano Lite (0x0a) connected on slot 1
[ 33.121359] input: Logitech Wireless Keyboard PID:4023 Keyboard as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input17
[ 33.121518] input: Logitech Wireless Keyboard PID:4023 Consumer Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input18
[ 33.121615] input: Logitech Wireless Keyboard PID:4023 System Control as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input19
[ 33.121757] hid-generic 0003:046D:4023.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-3610000.xhci-4.3/input1:1
[ 33.122879] logitech-djreceiver 0003:046D:C534.0004: device of type eQUAD nano Lite (0x0a) connected on slot 2
[ 33.123167] input: Logitech Wireless Mouse PID:4091 Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0004/0003:046D:4091.0006/input/input24
[ 33.123312] hid-generic 0003:046D:4091.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4091] on usb-3610000.xhci-4.3/input1:2
[ 33.443310] input: Logitech Wireless Keyboard PID:4023 as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0004/0003:046D:4023.0005/input/input28
[ 33.444136] logitech-hidpp-device 0003:046D:4023.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Wireless Keyboard PID:4023] on usb-3610000.xhci-4.3/input1:1
[ 33.523046] input: Logitech Wireless Mouse as /devices/platform/3610000.xhci/usb1/1-4/1-4.3/1-4.3:1.1/0003:046D:C534.0004/0003:046D:4091.0006/input/input29
[ 33.523289] logitech-hidpp-device 0003:046D:4091.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-3610000.xhci-4.3/input1:2
[ 36.192918] logitech-hidpp-device 0003:046D:4091.0006: HID++ 4.5 device connected.
[ 44.551865] vdd-12v-sys: disabling
[ 44.551884] vdd-3v3-ftdi: disabling
[ 45.788765] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 62.660943] logitech-hidpp-device 0003:046D:4023.0005: HID++ 2.0 device connected.
[ 65.724754] falcon 154c0000.nvenc: Direct firmware load for nvhost_nvenc080.fw failed with error -2
[ 65.734246] falcon 154c0000.nvenc: Falling back to sysfs fallback for: nvhost_nvenc080.fw
[ 65.744630] falcon 154c0000.nvenc: looking for firmware in subdirectory
[ 65.941808] bwmgr API not supported
[ 65.952811] regmap_util_write_table_8:regmap_util_write_table:-121
[ 65.956438] imx390 30-001b: Error writing mode
[ 65.967559] bwmgr API not supported
[ 65.969798] bwmgr API not supported
[ 65.973979] regmap_util_write_table_8:regmap_util_write_table:-121
[ 65.977665] imx390 30-001b: Error writing mode
[ 66.023934] bwmgr API not supported
[ 66.024530] regmap_util_write_table_8:regmap_util_write_table:-121
[ 66.028183] imx390 30-001b: Error writing mode
[ 66.041371] bwmgr API not supported
[ 66.041874] regmap_util_write_table_8:regmap_util_write_table:-121
[ 66.045489] imx390 30-001b: Error writing mode
[ 78.797041] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 121.804851] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 174.799599] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 237.838846] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 300.782130] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 363.798237] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 426.837487] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 489.837387] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 535.189263] usb 1-4.3: USB disconnect, device number 5
[ 552.792719] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 615.783964] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 678.827183] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 692.018084] NVRM nvAssertFailedNoLog: Assertion failed: minRequiredIsoBandwidthKBPS <= clientBwValues[DISPLAY_ICC_BW_CLIENT_EXT].minRequiredIsoBandwidthKBPS @ kern_disp_0402.c:111
[ 741.826993] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 804.778568] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 867.806153] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 930.772857] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 993.777067] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1056.772672] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1119.787386] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1182.819263] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1245.790005] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1308.817509] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1371.784479] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[ 1434.776232] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
