I’m developing a video streaming application, which needs to decode and encode many video streams concurrently, and I use live555
as the RTSP server. When client connects to the server, the TCP connection can be established, but there are no RTSP messages. The socket’s fd, accepted by live555 RTSP server, was greater than FD_SETSIZE (1024), so the select
function didn’t work.
Then I used command lsof -p pid
to list the opened files by my application, I found there were too many fds (about 2400) with name dmabuf
My device is: AGX Xavier
And Jetpack version is: R35 (release), REVISION: 1.0, GCID: 31250864, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 11 03:40:29 UTC 2022
I tested on R32
, all dmabuf’s fds were greater than 1024, so socket’s fd could be less than 1024.
The R32’s behavior is what I expect!
I wonder why the new version R35
doesn’t have the same behavior with R32
? Is it a R35’s bug?
R35 lsof result (Some repeated information was removed):
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
MyApp 3399 root 0u CHR 136,0 0t0 3 /dev/pts/0
MyApp 3399 root 1u CHR 136,0 0t0 3 /dev/pts/0
MyApp 3399 root 2u CHR 136,0 0t0 3 /dev/pts/0
MyApp 3399 root 3u CHR 10,54 0t0 386 /dev/nvmap
MyApp 3399 root 4u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 5u CHR 507,1 0t0 194 /dev/nvhost-vic
MyApp 3399 root 6u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 7u 0000 0,9 32768 53492 /dmabuf:
MyApp 3399 root 8u 0000 0,9 32768 53493 /dmabuf:
MyApp 3399 root 9u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 10u CHR 505,13 0t0 1113 /dev/nvgpu/igpu0/ctrl
MyApp 3399 root 11u CHR 505,16 0t0 1117 /dev/nvgpu/igpu0/prof
MyApp 3399 root 12u a_inode 0,12 0 9053 nvhost-gv11b-fd12
MyApp 3399 root 13u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 14u CHR 507,1 0t0 194 /dev/nvhost-vic
MyApp 3399 root 15u a_inode 0,12 0 9053 nvhost-syncpt
MyApp 3399 root 16u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 17u 0000 0,9 32768 53503 /dmabuf:
MyApp 3399 root 18u 0000 0,9 32768 53504 /dmabuf:
MyApp 3399 root 19u 0000 0,9 4096 53505 /dmabuf:
MyApp 3399 root 20u 0000 0,9 49152 53506 /dmabuf:
MyApp 3399 root 21u 0000 0,9 12288 53507 /dmabuf:
MyApp 3399 root 22u 0000 0,9 12288 53508 /dmabuf:
MyApp 3399 root 23u 0000 0,9 3702784 53509 /dmabuf:
MyApp 3399 root 24w REG 179,1 2848562 786482 /home/xxx.log
MyApp 3399 root 25w REG 179,1 0 786483 /home/xxx.log
MyApp 3399 root 26u a_inode 0,12 0 9053 [eventfd]
MyApp 3399 root 27u a_inode 0,12 0 9053 nvgpu-gv11b-tsg27
MyApp 3399 root 28u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd28
MyApp 3399 root 29u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd29
MyApp 3399 root 30u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd30
MyApp 3399 root 31u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd31
MyApp 3399 root 32u a_inode 0,12 0 9053 nvhost-event-poll-fd
MyApp 3399 root 33u a_inode 0,12 0 9053 nvgpu-gv11b-tsg33
MyApp 3399 root 34u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd34
MyApp 3399 root 35u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd35
MyApp 3399 root 36u a_inode 0,12 0 9053 nvhost-event-poll-fd
MyApp 3399 root 37u a_inode 0,12 0 9053 [eventfd]
MyApp 3399 root 38u a_inode 0,12 0 9053 nvgpu-event1-fd38
MyApp 3399 root 39u a_inode 0,12 0 9053 nvgpu-event4-fd39
MyApp 3399 root 40u a_inode 0,12 0 9053 nvgpu-event3-fd40
MyApp 3399 root 41u a_inode 0,12 0 9053 nvgpu-event0-fd41
MyApp 3399 root 42r FIFO 0,11 0t0 52681 pipe
MyApp 3399 root 43w FIFO 0,11 0t0 52681 pipe
MyApp 3399 root 44u a_inode 0,12 0 9053 [eventfd]
MyApp 3399 root 45u a_inode 0,12 0 9053 [eventpoll]
MyApp 3399 root 46u a_inode 0,12 0 9053 [timerfd]
MyApp 3399 root 47u a_inode 0,12 0 9053 [eventfd]
MyApp 3399 root 48u a_inode 0,12 0 9053 [eventpoll]
MyApp 3399 root 49u a_inode 0,12 0 9053 [timerfd]
MyApp 3399 root 50w REG 179,1 2184 786484 /home/xxx.log
MyApp 3399 root 51u a_inode 0,12 0 9053 [eventfd]
MyApp 3399 root 52u a_inode 0,12 0 9053 [eventpoll]
MyApp 3399 root 53u a_inode 0,12 0 9053 [timerfd]
MyApp 3399 root 54u IPv4 55737 0t0 TCP *:amandaidx (LISTEN)
MyApp 3399 root 55u IPv4 55739 0t0 TCP *:1554 (LISTEN)
MyApp 3399 root 56w REG 179,1 12054528 786495 /home/xxx.log
MyApp 3399 root 57u a_inode 0,12 0 9053 [eventfd]
MyApp 3399 root 58u a_inode 0,12 0 9053 [eventpoll]
MyApp 3399 root 59u a_inode 0,12 0 9053 [timerfd]
MyApp 3399 root 60u IPv4 55742 0t0 TCP *:28081 (LISTEN)
MyApp 3399 root 61u CHR 505,13 0t0 1113 /dev/nvgpu/igpu0/ctrl
MyApp 3399 root 62u a_inode 0,12 0 9053 nvhost-gv11b-fd62
MyApp 3399 root 63u a_inode 0,12 0 9053 nvhost-gv11b-fd63
MyApp 3399 root 64u unix 0xffff540740c8d800 0t0 55753 type=STREAM
MyApp 3399 root 65u a_inode 0,12 0 9053 nvgpu-gv11b-tsg65
MyApp 3399 root 66u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd66
MyApp 3399 root 67u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 68uw REG 179,1 968 1739359 /root/.cache/nvidia/GLCache/62d87071b347f8ee90f0c8b196f56c13/bac77cb44ab724ce/a9f27d39260b4978.toc
MyApp 3399 root 69uw REG 179,1 96107 1739360 /root/.cache/nvidia/GLCache/62d87071b347f8ee90f0c8b196f56c13/bac77cb44ab724ce/a9f27d39260b4978.bin
MyApp 3399 root 70u a_inode 0,12 0 9053 nvgpu-gv11b-tsg70
MyApp 3399 root 71u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd71
MyApp 3399 root 72u a_inode 0,12 0 9053 nvgpu-gv11b-tsg72
MyApp 3399 root 73u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd73
MyApp 3399 root 74u a_inode 0,12 0 9053 nvgpu-gv11b-tsg74
MyApp 3399 root 75u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd75
MyApp 3399 root 76u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd76
MyApp 3399 root 77u a_inode 0,12 0 9053 nvgpu-gv11b-tsg77
MyApp 3399 root 78u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd78
MyApp 3399 root 79u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd79
MyApp 3399 root 80u a_inode 0,12 0 9053 nvgpu-gv11b-tsg80
MyApp 3399 root 81u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd81
MyApp 3399 root 82u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd82
MyApp 3399 root 83u a_inode 0,12 0 9053 nvgpu-gv11b-tsg83
MyApp 3399 root 84u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd84
MyApp 3399 root 85u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd85
MyApp 3399 root 86u a_inode 0,12 0 9053 nvgpu-gv11b-tsg86
MyApp 3399 root 87u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd87
MyApp 3399 root 88u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd88
MyApp 3399 root 89u a_inode 0,12 0 9053 nvgpu-gv11b-tsg89
MyApp 3399 root 90u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd90
MyApp 3399 root 91u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd91
MyApp 3399 root 92u a_inode 0,12 0 9053 nvgpu-gv11b-tsg92
MyApp 3399 root 93u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd93
MyApp 3399 root 94u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd94
MyApp 3399 root 95u a_inode 0,12 0 9053 nvgpu-gv11b-tsg95
MyApp 3399 root 96u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd96
MyApp 3399 root 97u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd97
MyApp 3399 root 98u a_inode 0,12 0 9053 nvgpu-gv11b-tsg98
MyApp 3399 root 99u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd99
MyApp 3399 root 100u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd100
MyApp 3399 root 101u a_inode 0,12 0 9053 nvgpu-gv11b-tsg101
MyApp 3399 root 102u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd102
MyApp 3399 root 103u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd103
MyApp 3399 root 104u a_inode 0,12 0 9053 nvgpu-gv11b-tsg104
MyApp 3399 root 105u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd105
MyApp 3399 root 106u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd106
MyApp 3399 root 107u a_inode 0,12 0 9053 nvgpu-gv11b-tsg107
MyApp 3399 root 108u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd108
MyApp 3399 root 109u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd109
MyApp 3399 root 110u a_inode 0,12 0 9053 nvgpu-gv11b-tsg110
MyApp 3399 root 111u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd111
MyApp 3399 root 112u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd112
MyApp 3399 root 113u a_inode 0,12 0 9053 nvgpu-gv11b-tsg113
MyApp 3399 root 114u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd114
MyApp 3399 root 115u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd115
MyApp 3399 root 116u a_inode 0,12 0 9053 nvgpu-gv11b-tsg116
MyApp 3399 root 117u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd117
MyApp 3399 root 118u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd118
MyApp 3399 root 119u a_inode 0,12 0 9053 nvgpu-gv11b-tsg119
MyApp 3399 root 120u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd120
MyApp 3399 root 121u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd121
MyApp 3399 root 122u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd122
MyApp 3399 root 123u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd123
MyApp 3399 root 124u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd124
MyApp 3399 root 125u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd125
MyApp 3399 root 126u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd126
MyApp 3399 root 127u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd127
MyApp 3399 root 128u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd128
MyApp 3399 root 129u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd129
MyApp 3399 root 130u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd130
MyApp 3399 root 131u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd131
MyApp 3399 root 132u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd132
MyApp 3399 root 133u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd133
MyApp 3399 root 134u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd134
MyApp 3399 root 135u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd135
MyApp 3399 root 136u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd136
MyApp 3399 root 137u a_inode 0,12 0 9053 nvhost-17000000.gv11b-fd137
MyApp 3399 root 138u CHR 507,9 0t0 196 /dev/nvhost-msenc
MyApp 3399 root 139w REG 179,1 45220333 786480 /home/xxx.log
MyApp 3399 root 140u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 141u CHR 507,9 0t0 196 /dev/nvhost-msenc
MyApp 3399 root 142u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 143u CHR 507,13 0t0 197 /dev/nvhost-nvenc1
MyApp 3399 root 144u 0000 0,9 12845056 52683 /dmabuf:
MyApp 3399 root 145u 0000 0,9 12845056 52684 /dmabuf:
MyApp 3399 root 146u 0000 0,9 12845056 52685 /dmabuf:
MyApp 3399 root 147u 0000 0,9 12845056 52686 /dmabuf:
MyApp 3399 root 148u 0000 0,9 12845056 52687 /dmabuf:
MyApp 3399 root 149u 0000 0,9 12845056 52688 /dmabuf:
MyApp 3399 root 150u 0000 0,9 12845056 52689 /dmabuf:
MyApp 3399 root 151u 0000 0,9 12845056 52690 /dmabuf:
MyApp 3399 root 152u 0000 0,9 12845056 52691 /dmabuf:
MyApp 3399 root 153u 0000 0,9 12845056 52692 /dmabuf:
MyApp 3399 root 154u 0000 0,9 12443648 52693 /dmabuf:
MyApp 3399 root 155u 0000 0,9 12443648 52694 /dmabuf:
MyApp 3399 root 156u 0000 0,9 12443648 52695 /dmabuf:
MyApp 3399 root 157u 0000 0,9 12443648 52696 /dmabuf:
MyApp 3399 root 158u 0000 0,9 12443648 52697 /dmabuf:
MyApp 3399 root 159u 0000 0,9 12443648 52698 /dmabuf:
MyApp 3399 root 160u 0000 0,9 12443648 52699 /dmabuf:
MyApp 3399 root 161u 0000 0,9 12443648 52700 /dmabuf:
MyApp 3399 root 162u 0000 0,9 12443648 52701 /dmabuf:
MyApp 3399 root 163u 0000 0,9 12443648 52702 /dmabuf:
MyApp 3399 root 164u 0000 0,9 12443648 52703 /dmabuf:
MyApp 3399 root 165u 0000 0,9 12443648 52704 /dmabuf:
MyApp 3399 root 166u 0000 0,9 12443648 52705 /dmabuf:
MyApp 3399 root 167u 0000 0,9 12443648 52706 /dmabuf:
MyApp 3399 root 168u 0000 0,9 12443648 52707 /dmabuf:
MyApp 3399 root 169u 0000 0,9 12443648 52708 /dmabuf:
MyApp 3399 root 170u 0000 0,9 12443648 52709 /dmabuf:
MyApp 3399 root 171u 0000 0,9 12443648 52710 /dmabuf:
MyApp 3399 root 172u 0000 0,9 12443648 52711 /dmabuf:
MyApp 3399 root 173u 0000 0,9 12443648 52712 /dmabuf:
MyApp 3399 root 174u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 175u 0000 0,9 8388608 55768 /dmabuf:
MyApp 3399 root 176u CHR 507,9 0t0 196 /dev/nvhost-msenc
MyApp 3399 root 177u a_inode 0,12 0 9053 nvhost-syncpt
MyApp 3399 root 178u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 179u 0000 0,9 32768 55758 /dmabuf:
MyApp 3399 root 180u 0000 0,9 32768 55759 /dmabuf:
MyApp 3399 root 181u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 182u CHR 507,13 0t0 197 /dev/nvhost-nvenc1
MyApp 3399 root 183u a_inode 0,12 0 9053 nvhost-syncpt
MyApp 3399 root 184u CHR 507,0 0t0 193 /dev/nvhost-ctrl
MyApp 3399 root 185u 0000 0,9 32768 55760 /dmabuf:
MyApp 3399 root 186u 0000 0,9 32768 55761 /dmabuf:
MyApp 3399 root 187u 0000 0,9 8388608 55762 /dmabuf:
MyApp 3399 root 188u 0000 0,9 8388608 55762 /dmabuf:
MyApp 3399 root 189u 0000 0,9 4194304 55763 /dmabuf:
MyApp 3399 root 190u 0000 0,9 4194304 55763 /dmabuf:
MyApp 3399 root 191u 0000 0,9 8388608 55764 /dmabuf:
MyApp 3399 root 192u 0000 0,9 8388608 55764 /dmabuf:
MyApp 3399 root 193u 0000 0,9 4194304 55765 /dmabuf:
MyApp 3399 root 194u 0000 0,9 4194304 55765 /dmabuf:
MyApp 3399 root 195u 0000 0,9 8388608 55766 /dmabuf:
MyApp 3399 root 196u 0000 0,9 8388608 55766 /dmabuf:
MyApp 3399 root 197u 0000 0,9 4194304 55767 /dmabuf:
MyApp 3399 root 198u 0000 0,9 4194304 55767 /dmabuf:
MyApp 3399 root 199u 0000 0,9 8388608 55768 /dmabuf:
MyApp 3399 root 200u 0000 0,9 4194304 55769 /dmabuf:
MyApp 3399 root 201u 0000 0,9 4194304 55769 /dmabuf:
... ...abount 2000 /dmabuf
MyApp 3399 root 2236u 0000 0,9 12845056 52841 /dmabuf:
MyApp 3399 root 2237u 0000 0,9 12845056 52841 /dmabuf:
MyApp 3399 root 2238u 0000 0,9 12845056 52841 /dmabuf:
MyApp 3399 root 2239u unknown /proc/3399/fd/2239 (readlink: No such file or directory)
MyApp 3399 root 2240u 0000 0,9 12845056 52883 /dmabuf:
MyApp 3399 root 2241u 0000 0,9 12845056 52883 /dmabuf:
MyApp 3399 root 2242u 0000 0,9 12845056 52883 /dmabuf:
MyApp 3399 root 2243u 0000 0,9 12845056 52883 /dmabuf:
MyApp 3399 root 2244u 0000 0,9 12845056 52884 /dmabuf:
MyApp 3399 root 2245u 0000 0,9 12845056 52884 /dmabuf:
MyApp 3399 root 2246u 0000 0,9 12845056 52884 /dmabuf:
MyApp 3399 root 2249u sock 0,7 0t0 58595 protocol: TCP
R32 lsof result(Some repeated information was removed)
DecoderDemo 10688 root 0r CHR 1,3 0t0 1185 /dev/null
DecoderDemo 10688 root 1w CHR 1,3 0t0 1185 /dev/null
DecoderDemo 10688 root 2w CHR 1,3 0t0 1185 /dev/null
DecoderDemo 10688 root 5u unix 0xffffffc1b869b400 0t0 66143493 type=DGRAM
DecoderDemo 10688 root 6u sock 0,8 0t0 66144292 protocol: UDP
DecoderDemo 10688 root 7u IPv4 66144293 0t0 TCP *:20086 (LISTEN)
DecoderDemo 10688 root 8u REG 179,1 0 28841 /mnt/vion/start_va_flock
DecoderDemo 10688 root 11u CHR 242,0 0t0 1259 /dev/nvhost-ctrl
DecoderDemo 10688 root 12u CHR 242,17 0t0 1277 /dev/nvhost-vic
DecoderDemo 10688 root 13u CHR 10,61 0t0 1136 /dev/nvmap
DecoderDemo 10688 root 14u CHR 506,2 0t0 12655 /dev/nvhost-ctrl-gpu
DecoderDemo 10688 root 15u a_inode 0,11 0 8365 nvhost-gv11b-fd15
DecoderDemo 10688 root 16u a_inode 0,11 0 8365 [eventfd]
DecoderDemo 10688 root 17u CHR 239,0 0t0 12296 /dev/tegra_dc_ctrl
DecoderDemo 10688 root 18u CHR 239,1 0t0 10245 /dev/tegra_dc_0
DecoderDemo 10688 root 19u CHR 29,0 0t0 10387 /dev/fb0
DecoderDemo 10688 root 20u CHR 239,2 0t0 9226 /dev/tegra_dc_1
DecoderDemo 10688 root 21u CHR 29,1 0t0 9227 /dev/fb1
DecoderDemo 10688 root 22u IPv4 66142774 0t0 TCP *:10087 (LISTEN)
DecoderDemo 10688 root 23u sock 0,8 0t0 66142777 protocol: UDP
DecoderDemo 10688 root 24u IPv4 66138979 0t0 TCP localhost.localdomain:54956->192.168.5.2:9999 (ESTABLISHED)
DecoderDemo 10688 root 34u IPv4 66143520 0t0 TCP *:10088 (LISTEN)
DecoderDemo 10688 root 35u CHR 242,17 0t0 1277 /dev/nvhost-vic
DecoderDemo 10688 root 36r unknown anon_inode (stat: No such file or directory)
DecoderDemo 10688 root 42u CHR 506,2 0t0 12655 /dev/nvhost-ctrl-gpu
DecoderDemo 10688 root 43u CHR 506,4 0t0 12657 /dev/nvhost-prof-gpu
DecoderDemo 10688 root 44u a_inode 0,11 0 8365 nvhost-gv11b-fd44
DecoderDemo 10688 root 45r FIFO 0,10 0t0 66141944 pipe
DecoderDemo 10688 root 46w FIFO 0,10 0t0 66141944 pipe
DecoderDemo 10688 root 47u a_inode 0,11 0 8365 nvgpu-gv11b-tsg47
DecoderDemo 10688 root 48u a_inode 0,11 0 8365 nvhost-17000000.gv11b-fd48
DecoderDemo 10688 root 49u a_inode 0,11 0 8365 nvhost-17000000.gv11b-fd49
DecoderDemo 10688 root 50u a_inode 0,11 0 8365 nvhost-17000000.gv11b-fd50
DecoderDemo 10688 root 51u a_inode 0,11 0 8365 nvhost-17000000.gv11b-fd51
DecoderDemo 10688 root 52u a_inode 0,11 0 8365 nvhost-event-poll-fd
DecoderDemo 10688 root 53u a_inode 0,11 0 8365 nvgpu-gv11b-tsg53
DecoderDemo 10688 root 54u a_inode 0,11 0 8365 nvhost-17000000.gv11b-fd54
DecoderDemo 10688 root 55u a_inode 0,11 0 8365 nvhost-event-poll-fd
DecoderDemo 10688 root 56r FIFO 0,10 0t0 66141947 pipe
DecoderDemo 10688 root 57w FIFO 0,10 0t0 66141947 pipe
DecoderDemo 10688 root 58u a_inode 0,11 0 8365 nvgpu-event1-fd58
DecoderDemo 10688 root 59u a_inode 0,11 0 8365 nvgpu-event4-fd59
DecoderDemo 10688 root 60u a_inode 0,11 0 8365 nvgpu-event3-fd60
DecoderDemo 10688 root 61u a_inode 0,11 0 8365 nvgpu-event0-fd61
DecoderDemo 10688 root 62r FIFO 0,10 0t0 66141948 pipe
DecoderDemo 10688 root 63w FIFO 0,10 0t0 66141948 pipe
DecoderDemo 10688 root 64u REG 179,1 0 29394 /mnt/vion/create_decoder_flock
DecoderDemo 10688 root 65u CHR 242,9 0t0 11266 /dev/nvhost-nvdec
DecoderDemo 10688 root 67u CHR 242,9 0t0 11266 /dev/nvhost-nvdec
DecoderDemo 10688 root 68u CHR 242,13 0t0 11268 /dev/nvhost-nvdec1
DecoderDemo 10688 root 69u REG 179,1 0 29394 /mnt/vion/create_decoder_flock
DecoderDemo 10688 root 70u CHR 242,9 0t0 11266 /dev/nvhost-nvdec
DecoderDemo 10688 root 71u CHR 242,17 0t0 1277 /dev/nvhost-vic
DecoderDemo 10688 root 72u CHR 242,9 0t0 11266 /dev/nvhost-nvdec
DecoderDemo 10688 root 73u CHR 242,13 0t0 11268 /dev/nvhost-nvdec1
DecoderDemo 10688 root 74u CHR 242,9 0t0 11266 /dev/nvhost-nvdec
DecoderDemo 10688 root 75u CHR 242,13 0t0 11268 /dev/nvhost-nvdec1
DecoderDemo 10688 root 76u CHR 242,25 0t0 1287 /dev/nvhost-msenc
DecoderDemo 10688 root 83u CHR 242,9 0t0 11266 /dev/nvhost-nvdec
DecoderDemo 10688 root 84u CHR 242,13 0t0 11268 /dev/nvhost-nvdec1
DecoderDemo 10688 root 85u unknown /proc/10688/fd/85 (readlink: No such file or directory)
DecoderDemo 10688 root 86r REG 179,11 15323200 1455 /root/simsun.ttc
DecoderDemo 10688 root 87r REG 179,11 15323200 1455 /root/simsun.ttc
DecoderDemo 10688 root 88u CHR 242,25 0t0 1287 /dev/nvhost-msenc
DecoderDemo 10688 root 89u CHR 242,25 0t0 1287 /dev/nvhost-msenc
DecoderDemo 10688 root 90u CHR 242,17 0t0 1277 /dev/nvhost-vic
DecoderDemo 10688 root 91u CHR 242,29 0t0 11269 /dev/nvhost-nvenc1
DecoderDemo 10688 root 92u CHR 242,25 0t0 1287 /dev/nvhost-msenc
DecoderDemo 10688 root 93u CHR 242,29 0t0 11269 /dev/nvhost-nvenc1
DecoderDemo 10688 root 94u CHR 242,17 0t0 1277 /dev/nvhost-vic
DecoderDemo 10688 root 95u CHR 242,25 0t0 1287 /dev/nvhost-msenc
DecoderDemo 10688 root 96u CHR 242,29 0t0 11269 /dev/nvhost-nvenc1
DecoderDemo 10688 root 97r a_inode 0,11 0 8365 sync_fence
DecoderDemo 10688 root 98u CHR 242,17 0t0 1277 /dev/nvhost-vic
DecoderDemo 10688 root 99r DIR 179,11 4096 840 /root/UserApp/vioncfg/NDR
DecoderDemo 10688 root 100u CHR 242,17 0t0 1277 /dev/nvhost-vic
DecoderDemo 10688 root 101u CHR 242,25 0t0 1287 /dev/nvhost-msenc
DecoderDemo 10688 root 102u CHR 242,29 0t0 11269 /dev/nvhost-nvenc1
DecoderDemo 10688 root 104u IPv4 66144600 0t0 TCP *:2526 (LISTEN)
DecoderDemo 10688 root 105r a_inode 0,11 0 8365 sync_fence
DecoderDemo 10688 root 106u IPv4 67555500 0t0 TCP localhost.localdomain:40872->localhost.localdomain:1935 (ESTABLISHED)
DecoderDemo 10688 root 108u IPv4 66143084 0t0 UDP *:51732
DecoderDemo 10688 root 109u unknown /proc/10688/fd/109 (readlink: No such file or directory)
DecoderDemo 10688 root 110u sock 0,8 0t0 66144601 protocol: UDP
DecoderDemo 10688 root 112u IPv4 66144602 0t0 TCP *:10101 (LISTEN)
DecoderDemo 10688 root 113r a_inode 0,11 0 8365 sync_fence
DecoderDemo 10688 root 1024u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1025u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1026u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1027u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1028u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1029u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1030u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1031u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1032u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1033u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1034u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1035u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1036u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1037u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1038u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1039u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1040u a_inode 0,11 0 8365 dmabuf
DecoderDemo 10688 root 1041u a_inode 0,11 0 8365 dmabuf
