系统版本:R36.3.0
设备型号:ORIN NANO 8GB开发套件
问题:根据https://forums.developer.nvidia.com/t/jetson-orin-nano-hw-faq/249118中的第16条进行压力测试时,发现需要手动安装并编译cuda示例,git下载示例后执行make编译出现以下问题
make[1]: Leaving directory '/home/nvidia/cuda-samples/Samples/4_CUDA_Libraries/simpleCUBLAS'
make[1]: Entering directory '/home/nvidia/cuda-samples/Samples/4_CUDA_Libraries/jitLto'
/usr/local/cuda/bin/nvcc -ccbin g++ -I../../../Common -I/usr/local/cuda/include -m64 --threads 0 --std=c++11 -o jitLto.o -c jitLto.cpp
jitLto.cpp: In function ‘int main(int, char**)’:
jitLto.cpp:136:25: error: ‘nvJitLinkVersion’ was not declared in this scope; did you mean ‘nvJitLinkResult’?
136 | nvJitLinkResult res = nvJitLinkVersion(&cuda_major, &cuda_minor);
| nvJitLinkResult
make[1]: *** [Makefile:392: jitLto.o] Error 255
make[1]: Leaving directory '/home/nvidia/cuda-samples/Samples/4_CUDA_Libraries/jitLto'
make: *** [Makefile:45: Samples/4_CUDA_Libraries/jitLto/Makefile.ph_build] Error 2
nvidia@ubuntu:~/cuda-samples$
请问应该怎么解决?
