Hi NVIDIA,
目前使用AGX Orin devkit Jetpack 6版本
測試 SD 卡讀寫速率大約都只有20 MB/s左右
先前在Jetpack 5 測試讀寫大約 89 / 59 MB/s
使用的SD Card : Transcend 128G(TS128GUSD460T)
這部分可以再麻煩協助釐清嗎?
Hi NVIDIA,
這部分可以再麻煩協助釐清嗎?
Have you set the maximum performance on the system?
That seems to be an issue at R36.3 release, we’re doing the investigating now.
Please apply this patch to 36.3 kernel.
From e395d23e8b6d9696f3f4a14d8dcd65bbc81951c8 Mon Sep 17 00:00:00 2001
Date: Tue, 25 Jun 2024 13:13:43 +0800
Subject: [PATCH] mmc: host: Remove prod framework changes
Fixed specific vendor/brand sd can't
switch to ultra high speed
.../drivers/mmc/host/sdhci-tegra.c | 42 -------------------
.../kernel-jammy-src/include/linux/mmc/host.h | 1 -
2 files changed, 43 deletions(-)
diff --git a/kernel/kernel-jammy-src/drivers/mmc/host/sdhci-tegra.c b/kernel/kernel-jammy-src/drivers/mmc/host/sdhci-tegra.c
index 928ce47f9..01eec6ce1 100644
--- a/kernel/kernel-jammy-src/drivers/mmc/host/sdhci-tegra.c
+++ b/kernel/kernel-jammy-src/drivers/mmc/host/sdhci-tegra.c
@@ -27,7 +27,6 @@
#include <linux/ktime.h>
#include <linux/iommu.h>
#include <linux/bitops.h>
-#include <linux/tegra_prod.h>
#include <soc/tegra/common.h>
@@ -136,20 +135,6 @@
SDHCI_TRNS_BLK_CNT_EN | \
SDHCI_TRNS_DMA)
-static char prod_device_states[MMC_TIMING_COUNTER][20] = {
- "prod_c_ds", /* MMC_TIMING_LEGACY */
- "prod_c_hs", /* MMC_TIMING_MMC_HS */
- "prod_c_hs", /* MMC_TIMING_SD_HS */
- "prod_c_sdr12", /* MMC_TIMING_UHS_SDR12 */
- "prod_c_sdr25", /* MMC_TIMING_UHS_SDR25 */
- "prod_c_sdr50", /* MMC_TIMING_UHS_SDR50 */
- "prod_c_sdr104", /* MMC_TIMING_UHS_SDR104 */
- "prod_c_ddr52", /* MMC_TIMING_UHS_DDR50 */
- "prod_c_ddr52", /* MMC_TIMING_MMC_DDR52 */
- "prod_c_hs200", /* MMC_TIMING_MMC_HS200 */
- "prod_c_hs400", /* MMC_TIMING_MMC_HS400 */
struct sdhci_tegra_soc_data {
const struct sdhci_pltfm_data *pdata;
u64 dma_mask;
@@ -199,7 +184,6 @@ struct sdhci_tegra {
bool enable_hwcq;
unsigned long curr_clk_rate;
u8 tuned_tap_delay;
- struct tegra_prod *prods;
u32 streamid;
@@ -401,19 +385,12 @@ static void tegra_sdhci_reset(struct sdhci_host *host, u8 mask)
struct sdhci_tegra *tegra_host = sdhci_pltfm_priv(pltfm_host);
const struct sdhci_tegra_soc_data *soc_data = tegra_host->soc_data;
u32 misc_ctrl, clk_ctrl, pad_ctrl;
- int err;
sdhci_and_cqhci_reset(host, mask);
if (!(mask & SDHCI_RESET_ALL))
return;
- err = tegra_prod_set_by_name(&host->ioaddr, "prod",
- tegra_host->prods);
- if (err)
- dev_err(mmc_dev(host->mmc),
- "Failed to set prod-reset settings %d\n", err);
tegra_sdhci_set_tap(host, tegra_host->default_tap);
misc_ctrl = sdhci_readl(host, SDHCI_TEGRA_VENDOR_MISC_CTRL);
@@ -1053,10 +1030,8 @@ static void tegra_sdhci_set_uhs_signaling(struct sdhci_host *host,
bool set_default_tap = false;
bool set_dqs_trim = false;
bool do_hs400_dll_cal = false;
- bool set_padpipe_clk_override = false;
u8 iter = TRIES_256;
u32 val;
- int ret;
tegra_host->ddr_signaling = false;
switch (timing) {
@@ -1103,17 +1078,6 @@ static void tegra_sdhci_set_uhs_signaling(struct sdhci_host *host,
else
- /*set padpipe_clk_override*/
- if (set_padpipe_clk_override) {
- ret = tegra_prod_set_by_name_partially(&host->ioaddr,
- prod_device_states[timing], tegra_host->prods,
- 0, SDHCI_TEGRA_VENDOR_CLOCK_CTRL,
- SDHCI_CLOCK_CTRL_PADPIPE_CLKEN_OVERRIDE);
- if (ret < 0)
- "Failed to set padpipe clk override value for timing %d, %d\n",
- timing, ret);
if (set_dqs_trim)
tegra_sdhci_set_dqs_trim(host, tegra_host->dqs_trim);
@@ -1184,12 +1148,6 @@ static int sdhci_tegra_start_signal_voltage_switch(struct mmc_host *mmc,
static int tegra_sdhci_init_pinctrl_info(struct device *dev,
struct sdhci_tegra *tegra_host)
- tegra_host->prods = devm_tegra_prod_get(dev);
- if (IS_ERR_OR_NULL(tegra_host->prods)) {
- dev_err(dev, "Prod-setting not available\n");
- tegra_host->prods = NULL;
tegra_host->pinctrl_sdmmc = devm_pinctrl_get(dev);
if (IS_ERR(tegra_host->pinctrl_sdmmc)) {
dev_dbg(dev, "No pinctrl info, err: %ld\n",
diff --git a/kernel/kernel-jammy-src/include/linux/mmc/host.h b/kernel/kernel-jammy-src/include/linux/mmc/host.h
index 867aa18e9..a4ec7269b 100644
--- a/kernel/kernel-jammy-src/include/linux/mmc/host.h
+++ b/kernel/kernel-jammy-src/include/linux/mmc/host.h
@@ -63,7 +63,6 @@ struct mmc_ios {
#define MMC_TIMING_MMC_HS400 10
#define MMC_TIMING_SD_EXP 11
#define MMC_TIMING_SD_EXP_1_2V 12
-#define MMC_TIMING_COUNTER 11
unsigned char signal_voltage; /* signalling voltage (1.8V or 3.3V) */
2.25.1
Hi WayneWWW,
上完patch, sd card 讀寫速率已恢復正常
