R36.4.3 L4T 版本 HDMI 不显示
Hi, Nvidia,
问题背景:我们使用 AGX Orin 32G SOM + r36.4.3 L4T 版本 + 自研载板,系统启动后HDMI 不显示
我们目前的调查情况:
  1. 代码改动如下:
    (1) 直接抄了tegra234-dcb-p3767-0000-hdmi.dts 这个文件中nvidia,dcb-image 这个节点的内容并且确认系统启动后是生效的。
    (2) 热插拔引脚的配置包括dts 中的os_gpio_hotplug_a 配置和pinmux 中的配置
  2. 系统启动过程中在bootloader 阶段HDMI 是有显示的,如下图:
所以基本能够证明我们的硬件设计是没有问题的
  1. 系统启动后通过查看/var/log/Xorg.0.log 发现显示器已经连接成功:
    NVIDIA(GPU-0): DELL S2721DS (DFP-0): connected
    NVIDIA(GPU-0): DELL S2721DS (DFP-0): Internal TMDS
    NVIDIA(GPU-0): DELL S2721DS (DFP-0): 600.0 MHz maximum pixel clock
详细的log 如下:
xorg_log.txt (22.7 KB)
  1. dmesg log 中没有看到异常,log 如下:
    dmesg.txt (58.8 KB)
  2. xrandr 没有显示:
    seyond@ubuntu:~$ export DISPLAY=:0
    seyond@ubuntu:~$ xrandr
    Authorization required, but no authorization protocol specified
    Can’t open display :0
    seyond@ubuntu:~$
    seyond@ubuntu:~$ export DISPLAY=:1
    Can’t open display :1
  3. 显示器显示有信号输入,但是又显示不了任何东西,基本就是黑屏,我们换过显示器,也换过其他设备,现象都一样。
所以请帮忙看下这个问题,谢谢
  1. Is this carrier board every validated on rel-35 before?
  2. If you remove the monitor cable, would you see xorg log give you “disconnected”?
Hi, Wayne,
I try the r36.4 L4T this afternoon, and HDMI work fine based on this L4T.
@WayneWWW
We have completed the tests based on the AGX orin module +NVIDIA AGX XAVIER carrier board, using the L4T R35.5.0 and R36.4 image then HDMI display was OK, but using the L4T R36.4.3 image HDMI display was abnormal. The L4T r36.4.3 HDMI display may be a bug
Do you have Orin NX and Xavier NX devkit carrier board on your side?
We don’t have them.
It is not possible to do check under this situation.
There is no other users ever reporting rel-36.4.3 has issue on their custom board but rel-36.4 can work.
I could only suggest
  1. Try rel-36.4.2 and see what is the status there
  2. Get one Orin NX module and Xavier NX carrier board. Flash it with p3509 config and that is the only way to validate whether that monitor is able to work on a NV devkit or not.
Hi, Wayne,
It seems that we have found the trigger condition about this issue on r36.4.3 L4T.
Before using flash.sh to flash our device, we will use l4t_create_default_user.sh to create a default user account.
when we run: "./tools/l4t_create_default_user.sh -u seyond -p seyond -n ubuntu --accept-license " to create a account, and then flash.sh, after system boot up, the HDMI can’t display.
but when we run "./tools/l4t_create_default_user.sh -u seyond -p seyond -n ubuntu -a --accept-license " to create a account, and then flash.sh, after system boot up, the HDMI can display.
So it seems that the key is the “-a” when we create default user account. If this account auto log in, the HDMI can display.
Also we try "./tools/l4t_create_default_user.sh -u seyond -p seyond -n ubuntu --accept-license " on r36.4 L4T, the HDMI can display.
We tried the same steps as you said but we cannot reproduce this issue.
No matter that “-a” is added or not, we can always see the HDMI monitor.
