主要新增這個設定 就可以直接轉為usb2.0 device
usb2-0 {
mode = "peripheral";
vbus-supply = <&vdd_5v0_sys>;
status = "okay";
usb-role-switch;
role-switch-default-mode = "peripheral";
use command:
sudo ./flash.sh jetson-agx-orin-devkit internal
燒錄OK
燒錄成功後
插拔燒錄USB線 顯示
# dmesg -c
[2435069.741137] usb 1-4: USB disconnect, device number 79
[2435069.741910] rndis_host 1-4:1.0 enxca01b8df4340: unregister ‘rndis_host’ usb-0000:00:14.0-4, RNDIS device
[2435069.801503] cdc_ncm 1-4:1.5 enxca01b8df4342: unregister ‘cdc_ncm’ usb-0000:00:14.0-4, CDC NCM (NO ZLP)
[2435071.482493] usb 1-4: new high-speed USB device number 80 using xhci_hcd
[2435071.609617] usb 1-4: New USB device found, idVendor=0955, idProduct=7020, bcdDevice= 0.02
[2435071.609636] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[2435071.609645] usb 1-4: Product: Linux for Tegra
[2435071.609652] usb 1-4: Manufacturer: NVIDIA
[2435071.609658] usb 1-4: SerialNumber: 1422125066918
[2435071.616301] rndis_host 1-4:1.0 usb0: register ‘rndis_host’ at usb-0000:00:14.0-4, RNDIS device, ca:01:b8:df:43:40
[2435071.618271] cdc_acm 1-4:1.2: ttyACM0: USB ACM device
[2435071.619968] usb-storage 1-4:1.4: USB Mass Storage device detected
[2435071.620453] scsi host6: usb-storage 1-4:1.4
[2435071.644535] cdc_ncm 1-4:1.5: MAC-Address: ca:01:b8:df:43:42
[2435071.645086] cdc_ncm 1-4:1.5 usb1: register ‘cdc_ncm’ at usb-0000:00:14.0-4, CDC NCM (NO ZLP), ca:01:b8:df:43:42
[2435071.659403] cdc_ncm 1-4:1.5 enxca01b8df4342: renamed from usb1
[2435071.665409] rndis_host 1-4:1.0 enxca01b8df4340: renamed from usb0
[2435072.636297] scsi 6:0:0:0: Direct-Access Linux File-Stor Gadget 0515 PQ: 0 ANSI: 2
[2435072.637133] sd 6:0:0:0: Attached scsi generic sg2 type 0
[2435072.637354] sd 6:0:0:0: Power-on or device reset occurred
[2435072.637874] sd 6:0:0:0: [sdc] 32768 512-byte logical blocks: (16.8 MB/16.0 MiB)
[2435072.638023] sd 6:0:0:0: [sdc] Write Protect is on
[2435072.638032] sd 6:0:0:0: [sdc] Mode Sense: 0f 00 80 00
[2435072.638208] sd 6:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[2435072.641033] sdc:
[2435072.641335] sd 6:0:0:0: [sdc] Attached SCSI removable disk
root@iei-Z370P-D3:/home/iei# ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp6s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether e0:d5:5e:43:24:20 brd ff:ff:ff:ff:ff:ff
inet 10.10.50.46/23 brd 10.10.51.255 scope global dynamic noprefixroute enp6s0
valid_lft 1192727sec preferred_lft 1192727sec
inet6 fe80::2e8:309b:2dc0:5f7c/64 scope link noprefixroute
3: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
link/ether 4e:bf:b2:41:f6:64 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
65: enxca01b8df4340: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
link/ether ca:01:b8:df:43:40 brd ff:ff:ff:ff:ff:ff
inet 192.168.55.100/24 brd 192.168.55.255 scope global dynamic noprefixroute enxca01b8df4340
valid_lft 13sec preferred_lft 13sec
inet6 fe80::a0ba:7e41:f1b9:f86a/64 scope link noprefixroute
66: enxca01b8df4342: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether ca:01:b8:df:43:42 brd ff:ff:ff:ff:ff:ff
inet6 fe80::7078:4c62:1c96:6949/64 scope link noprefixroute
使用 l4t_initrd_flash 燒錄 LOG 1215l4t_initrd_flash_flashonly.txt
./tools/kernel_flash/l4t_initrd_flash.sh --flash-only jetson-agx-orin-devkit mmcblk0p1
顯示錯誤
Formatting APP parition done
Formatting APP partition /dev/mmcblk0p1 …
tar --checkpoint-action=“ttyout=Hit %s checkpoint #%u%*\r” -x -I ‘zstd -T0’ -pf /mnt/internal/system.img --warning=no-timestamp --numeric-owner --xattrs --xattrs-include=* -C /tmp/ci-uGtm0cRJRV
writing item=78, 1:3:secondary_gpt, 61203267072, 16896, gpt_secondary_1_3.bin, 16896, fixed–0, 3ccddddb468ecc830ac193341ca075bdd798771f
[ 214]: l4t_flash_from_kernel: Successfully flash the emmc
[ 214]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
[ 214]: l4t_flash_from_kernel: Error flashing qspi
Flash failure
Either the device cannot mount the NFS server on the host or a flash command has failed. Check your network setting (VPN, firewall,…) to make sure the device can mount NFS server. Debug log saved to /tmp/tmp.lqabRl7eiZ. You can access the target’s terminal through “sshpass -p root ssh root@fc00:1:1:0::2”
Cleaning up…
確認usb0裝置
[2438811.676237] NFSD: Using nfsdcld client tracking operations.
[2438811.676247] NFSD: no clients to reclaim, skipping NFSv4 grace period (net f0000000)
[2438812.468114] NFSD: Using nfsdcld client tracking operations.
[2438812.468124] NFSD: no clients to reclaim, skipping NFSv4 grace period (net f0000000)
[2438821.210563] usb 1-4: USB disconnect, device number 86
[2438834.383051] usb 1-4: new high-speed USB device number 87 using xhci_hcd
[2438834.514818] usb 1-4: New USB device found, idVendor=0955, idProduct=7035, bcdDevice= 0.01
[2438834.514822] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[2438834.514824] usb 1-4: Product: Linux for Tegra
[2438834.514825] usb 1-4: Manufacturer: NVIDIA
[2438834.514826] usb 1-4: SerialNumber: 1422125066918
[2438834.517541] rndis_host 1-4:1.0 usb0: register ‘rndis_host’ at usb-0000:00:14.0-4, RNDIS device, 56:fa:6e:52:cb:c1
[2438834.542515] rndis_host 1-4:1.0 enx56fa6e52cbc1: renamed from usb0
# ip addr show
valid_lft 1189327sec preferred_lft 1189327sec
67: enx56fa6e52cbc1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
link/ether 56:fa:6e:52:cb:c1 brd ff:ff:ff:ff:ff:ff
inet6 fc00:1:1::1/64 scope global
inet6 fe80::54fa:6eff:fe52:cbc1/64 scope link
inet6 fe80::2/64 scope link
確認最基本的連通性:使用 ping6 測試 : 可以連線
# ping6 fc00:1:1:0::2
PING fc00:1:1:0::2(fc00:1:1::2) 56 data bytes
64 bytes from fc00:1:1::2: icmp_seq=1 ttl=64 time=0.299 ms
64 bytes from fc00:1:1::2: icmp_seq=2 ttl=64 time=0.349 ms
64 bytes from fc00:1:1::2: icmp_seq=3 ttl=64 time=0.355 ms
64 bytes from fc00:1:1::2: icmp_seq=4 ttl=64 time=0.320 ms
^C
-– fc00:1:1:0::2 ping statistics —
4 packets transmitted, 4 received, 0% packet loss, time 3049ms
rtt min/avg/max/mdev = 0.299/0.330/0.355/0.022 ms
改用SSH指令 指定IP為不壓縮的完整形式 連接:可以連到ORIN
# ssh root@fc00:0001:0001:0000:0000:0000:0000:0002
The authenticity of host ‘fc00:1:1::2 (fc00:1:1::2)’ can’t be established.
ED25519 key fingerprint is SHA256:kaPwbA4ELCm+EgzZARfRRp5pUG/vdheLDQzx9LStsN8.
This key is not known by any other names
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added ‘fc00:1:1::2’ (ED25519) to the list of known hosts.
root@fc00:1:1::2’s password:
-bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
-bash-5.1#
-bash-5.1# exit
logout
Connection to fc00:1:1::2 closed.
重新用 sshpass -p root ssh root@fc00:1:1:0::2 可連線成功
# sshpass -p root ssh root@fc00:1:1:0::2
-bash-5.1#
-bash-5.1# exit
logout
再次執行 ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only jetson-agx-orin-devkit mmcblk0p1 燒錄
還是失敗
但確認 sshpass -p root ssh root@fc00:1:1:0::2 是可以連線的
確認HOST PC是否有問題
使用 sdkmanager 版本 JetPack_6.2.1_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
測試指令
sudo ./tools/kernel_flash/l4t_initrd_flash.sh jetson-agx-orin-devkit mmcblk0p1
是可以正常燒錄
