R36.4.3 libnvisppg.so version question
Continuing the discussion from R36.4.3 libnvisppg.so version question:
I have already correctly replaced the parameters and set the appropriate permissions.
Based on the provided context, I will provide a comprehensive answer to the question.
The discussion from R3643 libnvisppgso version question seems to be related to the Jetson Orin Nano module, specifically regarding the version of libnvisppgso. However, the provided context does not explicitly mention the question.
To provide a comprehensive answer, I will summarize the key points from the context:
  1. The Jetson Orin Nano module has different variants, including 4GB-DRAM and 8GB-DRAM, with different production and development statuses.
  2. The Jetson Orin Nano reference carrier board (P3768-0000) is compatible with both 4GB-DRAM and 8GB-DRAM modules.
  3. The Jetson Orin Nano Developer Kit Carrier Board Specification (SP-11324-001_v1.3) provides details on the carrier board’s features, including USB ports, Gigabit Ethernet, and more.
  4. The Jetson Linux 36.4.3 release supports new reference power modes on Jetson Orin Nano and Jetson Orin NX production modules, delivering up to 2x generative AI performance.
  5. There are various discussions and questions related to the Jetson Orin Nano and Jetson AGX Orin modules, including topics such as HDMI interface settings, power sequencing, and PCIe bus errors.
Comparing the Jetson Orin Nano and Jetson AGX Orin modules, we can see that:
  • Both modules have different variants with varying amounts of DRAM.
  • The Jetson Orin Nano module has a more compact design and is suitable for smaller form factors.
  • The Jetson AGX Orin module has more powerful GPUs and is suitable for more demanding applications.
  • Both modules support various features, including USB ports, Gigabit Ethernet, and PCIe interfaces.
In conclusion, while the specific question from R3643 libnvisppgso version question is not explicitly mentioned, the provided context highlights the key features and differences between the Jetson Orin Nano and Jetson AGX Orin modules. If you have any further questions or would like more information on a specific topic, please feel free to ask.
R36.4.3 libnvisppg.so version question - Jetson & Embedded Systems / Jetson Orin Nano - NVIDIA Developer ForumsThe link already contains detailed information, and we have tried all the previously provided solutions, but none of them have shown significant effect on the current stubborn pixel defects.
It’s known problem for the bad pixel correction and still debugging it.
Will update it once get result.
Hello, could you please let us know how long it will take to fix this issue, or when we can expect to receive a corrected solution? We look forward to your reply. Thank you.
Could you please tell me when this issue is expected to be resolved?
It may take some time for it. Will update the solution once get result.
In our ISP file, we have the following parameters:`
detailenhancement.DynamicProps[0].DetailGainPercentage = 9;
badPixelCorrection.v5[0].Or2NoiseFunction[12].X = 0.0866047;
badPixelCorrection.v5[0].Or2NoiseFunction[12].Y = 0.0239761;
badPixelCorrection.v5[0].Or2NoiseFunction[12].Slope = 0.00231147;
badPixelCorrection.v5[0].Or2NoiseFunction[13].X = 0.141264;
badPixelCorrection.v5[0].Or2NoiseFunction[13].Y = 0.0241022;
badPixelCorrection.v5[0].Or2NoiseFunction[13].Slope = 0.00229859;
badPixelCorrection.v5[0].Or2NoiseFunction[14].X = 0.230422;
badPixelCorrection.v5[0].Or2NoiseFunction[14].Y = 0.0243065;
badPixelCorrection.v5[0].Or2NoiseFunction[14].Slope = 0.00227833;
badPixelCorrection.v5[0].Or2NoiseFunction[15].X = 0.375852;
badPixelCorrection.v5[0].Or2NoiseFunction[15].Y = 0.024636;
badPixelCorrection.v5[0].Or2NoiseFunction[15].Slope = 0.00224638;
badPixelCorrection.v5[0].Or2NoiseFunction[16].X = 0.613068;
badPixelCorrection.v5[0].Or2NoiseFunction[16].Y = 0.0251642;
badPixelCorrection.v5[0].Or2NoiseFunction[16].Slope = 0.00219703;
badPixelCorrection.v5[0].Or2NoiseFunction[17].X = 1;
badPixelCorrection.v5[0].Or2NoiseFunction[17].Y = 0.0260028;
badPixelCorrection.v5[0].Or2NoiseFunction[17].Slope = 0.00216722;
However, when these parameters are output in the backend, we encountered the error shown in the attached image. Could you please help us understand why this error occurs?
This is the error log, could it be that these parameters haven’t taken effect? We strictly used the parameters generated through calibration.
Using V6 for Orin instead of V5
hello,Why are the following parameters not taking effect?detailenhancement.DynamicProps[0].DetailGainPercentage = 9; detailenhancement.DynamicProps[1].DetailGainPercentage = 9; detailenhancement.DynamicProps[2].DetailGainPercentage = 9; detailenhancement.DynamicProps[3].DetailGainPercentage = 9; detailenhancement.DynamicProps[4].DetailGainPercentage = 9; detailenhancement.DynamicProps[5].DetailGainPercentage = 9; detailenhancement.DynamicProps[6].DetailGainPercentage = 9; detailenhancement.DynamicProps[7].DetailGainPercentage = 9; Additionally, regarding the bad pixel correction parameters: we have defined entries from index [0] to [17], but the error message only reports indices [12] through [17] as invalid.
Below is the full configuration for badPixelCorrection (for single-exposure SDR):`# badPixelCorrection for single exposure SDR:
badPixelCorrection.v5[0].Or2NoiseFunction[0].X = 0.000244141;
badPixelCorrection.v5[0].Or2NoiseFunction[0].Y = 0.333676;
badPixelCorrection.v5[0].Or2NoiseFunction[0].Slope = 0.00270772;
badPixelCorrection.v5[0].Or2NoiseFunction[1].X = 0.000398228;
badPixelCorrection.v5[0].Or2NoiseFunction[1].Y = 0.333676;
badPixelCorrection.v5[0].Or2NoiseFunction[1].Slope = 0.00271749;
badPixelCorrection.v5[0].Or2NoiseFunction[2].X = 0.000649566;
badPixelCorrection.v5[0].Or2NoiseFunction[2].Y = 0.233677;
badPixelCorrection.v5[0].Or2NoiseFunction[2].Slope = 0.00278115;
badPixelCorrection.v5[0].Or2NoiseFunction[3].X = 0.00105954;
badPixelCorrection.v5[0].Or2NoiseFunction[3].Y = 0.233678;
badPixelCorrection.v5[0].Or2NoiseFunction[3].Slope = 0.00279903;
badPixelCorrection.v5[0].Or2NoiseFunction[4].X = 0.00172825;
badPixelCorrection.v5[0].Or2NoiseFunction[4].Y = 0.13368;
badPixelCorrection.v5[0].Or2NoiseFunction[4].Slope = 0.00276136;
badPixelCorrection.v5[0].Or2NoiseFunction[5].X = 0.00281902;
badPixelCorrection.v5[0].Or2NoiseFunction[5].Y = 0.0237816;
badPixelCorrection.v5[0].Or2NoiseFunction[5].Slope = 0.0023315;
badPixelCorrection.v5[0].Or2NoiseFunction[6].X = 0.00459823;
badPixelCorrection.v5[0].Or2NoiseFunction[6].Y = 0.0237857;
badPixelCorrection.v5[0].Or2NoiseFunction[6].Slope = 0.00233078;
badPixelCorrection.v5[0].Or2NoiseFunction[7].X = 0.00750036;
badPixelCorrection.v5[0].Or2NoiseFunction[7].Y = 0.0237925;
badPixelCorrection.v5[0].Or2NoiseFunction[7].Slope = 0.00233054;
badPixelCorrection.v5[0].Or2NoiseFunction[8].X = 0.0122342;
badPixelCorrection.v5[0].Or2NoiseFunction[8].Y = 0.0238035;
badPixelCorrection.v5[0].Or2NoiseFunction[8].Slope = 0.00232911;
badPixelCorrection.v5[0].Or2NoiseFunction[9].X = 0.0199556;
badPixelCorrection.v5[0].Or2NoiseFunction[9].Y = 0.0238215;
badPixelCorrection.v5[0].Or2NoiseFunction[9].Slope = 0.0023272;
badPixelCorrection.v5[0].Or2NoiseFunction[10].X = 0.0325505;
badPixelCorrection.v5[0].Or2NoiseFunction[10].Y = 0.0238508;
badPixelCorrection.v5[0].Or2NoiseFunction[10].Slope = 0.00232434;
badPixelCorrection.v5[0].Or2NoiseFunction[11].X = 0.0530945;
badPixelCorrection.v5[0].Or2NoiseFunction[11].Y = 0.0238985;
badPixelCorrection.v5[0].Or2NoiseFunction[11].Slope = 0.00231934;
badPixelCorrection.v5[0].Or2NoiseFunction[17].Slope = 0.00216722;`
Hello, could you please provide us with a complete set of reference parameters for NR (Noise Reduction) and bad pixel correction based on the V6 version?
Please consult with camera partner for tuning parameters.
We don’t support tuning problem on forum.
Hello, we have successfully applied the following parameters on JP5.1.2, but the same parameters did not take effect on JP6.2. Could you please explain what might be causing this issue?# badPixelCorrection for single exposure SDR: badPixelCorrection.v6[0].Or2Mode = 1; badPixelCorrection.v6[0].Or2NoisePorfileEnabled = true; badPixelCorrection.v6[0].Or2StatsEnabled = true; badPixelCorrection.v6[0].Or2NoiseFunction[0].X = 0.000244141; badPixelCorrection.v6[0].Or2NoiseFunction[0].Y = 0.333676; badPixelCorrection.v6[0].Or2NoiseFunction[0].Slope = 0.00270772; badPixelCorrection.v6[0].Or2NoiseFunction[1].X = 0.000398228; badPixelCorrection.v6[0].Or2NoiseFunction[1].Y = 0.333676; badPixelCorrection.v6[0].Or2NoiseFunction[1].Slope = 0.00271749; badPixelCorrection.v6[0].Or2NoiseFunction[2].X = 0.000649566; badPixelCorrection.v6[0].Or2NoiseFunction[2].Y = 0.233677; badPixelCorrection.v6[0].Or2NoiseFunction[2].Slope = 0.00278115; badPixelCorrection.v6[0].Or2NoiseFunction[3].X = 0.00105954; badPixelCorrection.v6[0].Or2NoiseFunction[3].Y = 0.233678; badPixelCorrection.v6[0].Or2NoiseFunction[3].Slope = 0.00279903; badPixelCorrection.v6[0].Or2NoiseFunction[4].X = 0.00172825; badPixelCorrection.v6[0].Or2NoiseFunction[4].Y = 0.13368; badPixelCorrection.v6[0].Or2NoiseFunction[4].Slope = 0.00276136; badPixelCorrection.v6[0].Or2NoiseFunction[5].X = 0.00281902; badPixelCorrection.v6[0].Or2NoiseFunction[5].Y = 0.0237816; badPixelCorrection.v6[0].Or2NoiseFunction[5].Slope = 0.0023315; badPixelCorrection.v6[0].Or2NoiseFunction[6].X = 0.00459823; badPixelCorrection.v6[0].Or2NoiseFunction[6].Y = 0.0237857; badPixelCorrection.v6[0].Or2NoiseFunction[6].Slope = 0.00233078; badPixelCorrection.v6[0].Or2NoiseFunction[7].X = 0.00750036; badPixelCorrection.v6[0].Or2NoiseFunction[7].Y = 0.0237925; badPixelCorrection.v6[0].Or2NoiseFunction[7].Slope = 0.00233054; badPixelCorrection.v6[0].Or2NoiseFunction[8].X = 0.0122342; badPixelCorrection.v6[0].Or2NoiseFunction[8].Y = 0.0238035; badPixelCorrection.v6[0].Or2NoiseFunction[8].Slope = 0.00232911; badPixelCorrection.v6[0].Or2NoiseFunction[9].X = 0.0199556; badPixelCorrection.v6[0].Or2NoiseFunction[9].Y = 0.0238215; badPixelCorrection.v6[0].Or2NoiseFunction[9].Slope = 0.0023272; badPixelCorrection.v6[0].Or2NoiseFunction[10].X = 0.0325505; badPixelCorrection.v6[0].Or2NoiseFunction[10].Y = 0.0238508; badPixelCorrection.v6[0].Or2NoiseFunction[10].Slope = 0.00232434; badPixelCorrection.v6[0].Or2NoiseFunction[11].X = 0.0530945; badPixelCorrection.v6[0].Or2NoiseFunction[11].Y = 0.0238985; badPixelCorrection.v6[0].Or2NoiseFunction[11].Slope = 0.00231934; badPixelCorrection.v6[0].Or2NoiseFunction[12].X = 0.0866047; badPixelCorrection.v6[0].Or2NoiseFunction[12].Y = 0.0239761; badPixelCorrection.v6[0].Or2NoiseFunction[12].Slope = 0.00231147; badPixelCorrection.v6[0].Or2NoiseFunction[13].X = 0.141264; badPixelCorrection.v6[0].Or2NoiseFunction[13].Y = 0.0241022; badPixelCorrection.v6[0].Or2NoiseFunction[13].Slope = 0.00229859; badPixelCorrection.v6[0].Or2NoiseFunction[14].X = 0.230422; badPixelCorrection.v6[0].Or2NoiseFunction[14].Y = 0.0243065; badPixelCorrection.v6[0].Or2NoiseFunction[14].Slope = 0.00227833; badPixelCorrection.v6[0].Or2NoiseFunction[15].X = 0.375852; badPixelCorrection.v6[0].Or2NoiseFunction[15].Y = 0.024636; badPixelCorrection.v6[0].Or2NoiseFunction[15].Slope = 0.00224638; badPixelCorrection.v6[0].Or2NoiseFunction[16].X = 0.613068; badPixelCorrection.v6[0].Or2NoiseFunction[16].Y = 0.0251642; badPixelCorrection.v6[0].Or2NoiseFunction[16].Slope = 0.00219703; badPixelCorrection.v6[0].Or2NoiseFunction[17].X = 1; badPixelCorrection.v6[0].Or2NoiseFunction[17].Y = 0.0260028; badPixelCorrection.v6[0].Or2NoiseFunction[17].Slope = 0.00216722;
Could you try Modify Or2Mode to 2.
badPixelCorrection.v6[0].Or2Mode = 2;
Hello, we have tried using the parameters you provided, but they still had no effect on JP6.2. Could you please suggest any methods we can use to troubleshoot the root cause?
The bad pixel correct on Orin for JP6 still on debug.
Hello, could you please tell me if there are any commands to view the AWB logs?
There’s no command for it.
