( R39.2.0 ) apt-get error: File has unexpected size… Mirror sync in progress?
Please see following picture, I got “Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r39.2/main/binary-arm64/Packages.gz File has unexpected size (63810 != 63578). Mirror sync in progress? [IP: 23.211.113.18 443]”, when I trying to run the “./install-jetpack-keep-bsp.sh” from “Making sure you're not a bot!”.
Hi Amber,
Thank you for reporting this issue. We have confirmed that the NVIDIA APT repository metadata is currently inconsistent. I will contact our internal team to have it corrected.
Please allow us some time. I will update this topic once the issue is fixed.
We don’t observe the issue on developer kit:
R39.2 common apt repo: Packages index is newer than the signed Release — apt update fails with "File has unexpected size" - #8 by DaneLLL
If you still hit the issue, please check and share full steps.
Dear @DaneLLL,
I think your team fixed the problem.
I can’t reproduce the problem I faced yesterday.
Everything works well now, many thanks.
