hi:
我看开发文档中有这一项,用T5000的模组模拟t3000的性能,我按照那个命令发现烧录失败,能帮忙看看是哪里的问题,谢谢!
sudo ./l4t_initrd_flash.sh p3834-0008-as-p5767-0000-nvme internal
mingming@xyz-build:~/Workspace/jp7.2.1/Linux_for_Tegra$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0bda:b00c Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 033: ID 0955:7020 NVIDIA Corp. L4T (Linux for Tegra) running on Tegra
Bus 001 Device 049: ID 0955:7026 NVIDIA Corp. APX
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
mingming@xyz-build:~/Workspace/jp7.2.1/Linux_for_Tegra$ sudo ./l4t_initrd_flash.sh p3834-0008-as-p5767-0000-nvme internal
./l4t_initrd_flash.sh: line 238: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
# Entry added by NVIDIA initrd flash tool
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
Export list for localhost:
14:30:08.402 - Debug: Checking UFW status and NFS port rules...
14:30:08.459 - Debug: UFW is not active. NFS port is accessible.
14:30:08.460 - Debug: Checking VPN connections...
14:30:08.464 - Debug: IPSec service is not running.
14:30:08.466 - Debug: VPN routes none in tun|tap|ppp|vpn|gpd.
14:30:08.467 - Debug: No VPN connection detected.
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash p3834-0008-as-p5767-0000-nvme internal
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 49: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 50: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 52: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 53: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 54: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 55: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 56: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 57: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.func: line 310: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
* Step 1: Generate flash packages *
Run image gen script: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh --boot-chain-flash ALL --boot-chain-select A p3834-0008-as-p5767-0000-nvme internal
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh: line 467: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh: line 744: /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY="" /home/mingming/Workspace/jp7.2.1/Linux_for_Tegra/flash.sh --no-flash --sign --boot-chain-flash ALL --boot-chain-select A p3834-0008-as-p5767-0000-nvme internal
Error: Invalid target board - p3834-0008-as-p5767-0000-nvme.
Usage: sudo ./flash.sh [options] <target_board> <rootdev>
Where,
target board: Valid target board name or 'autodetect'
rootdev: Proper root device.
options:
-b <emc_bctfile> ------ use the specified emc_bct file.
-c <cfgfile> ---------- Flash partition table config file.
-d <dtbfile> ---------- device tree file.
-e <bpmp_file> -------- use the specified bpmp file.
-f <flashapp> --------- Path to flash application (tegraflash.py)
-g <bpmp_dtb_file> ---- use the specified bpmp dtb file
-h -------------------- print this message.
-i <enc rfs key file>-- key for disk encryption support.
-k <partition id> ----- partition name or number specified in flash.cfg.
-l <tbcdtbfile> ------- cpu bootloader dtb file.
-m <mts preboot> ------ MTS preboot such as mts_preboot_si.
-n <nfs args> --------- Static nfs network assignments
<Client IP>:<Server IP>:<Gateway IP>:<Netmask>
-o <odmdata> ---------- ODM data.
-r -------------------- skip building and reuse existing system.img.
-u <PKC key file>------ PKC key or PKC keylist used for odm fused board.
This option is also used for cpu-bootloader signing in PV key feature.
-v <SBK key file>------ Secure Boot Key (SBK) key used for ODM fused board.
-w <wb0boot> ---------- warm boot binary such as nvtbootwb0.bin
-x <tegraid> ---------- Tegra CHIPID.
-B <boardid> ---------- BoardId.
-C <cmdline> ---------- Kernel commandline arguments.
WARNING:
Each option in this kernel commandline gets
higher preference over the values set by
flash.sh. In case of NFS booting, this script
adds NFS booting related arguments, if -i option
is omitted.
-F <uefi_bin_name> ---- UEFI binary name such as uefi_t26x_general.bin.
-G <file name> -------- Read partition and save image to file.
-I <initrd> ----------- initrd file. Null initrd is default.
-K <kernel> ----------- Kernel image file such as zImage or Image.
-L <bootloader> ------- Bootloader such as cboot.bin or u-boot-dtb.bin.
-M <mts boot> --------- MTS boot file such as mts_si.
-N <nfsroot> ---------- i.e. <my IP addr>:/my/exported/nfs/rootfs.
-R <rootfs dir> ------- Sample rootfs directory.
-S <size> ------------- Rootfs size in bytes. Valid only for internal
rootdev. KiB, MiB, GiB short hands are allowed,
for example, 1GiB means 1024 * 1024 * 1024 bytes.
-T <ext num sectors> ---The number of the sectors of the external storage device.
The default value is 119537664 if this option is not set.
-U <int num sectors> ---The number of the sectors of the internal storage device.
-Z -------------------- Print configurations and then exit.
--no-flash ------------ perform all steps except physically flashing the board.
This will create a system.img.
If combined with --rcm-boot, the command will generate rcmboot_blob.
If combined with --read-info, the command will generate readinfocmd.txt.
--external-device------ Generate flash images for external devices
--sparseupdate--------- only flash partitions that have changed. Currently only support SPI flash memory
--no-systemimg -------- Do not create or re-create system.img.
--bup ----------------- Generate bootloader update payload(BUP).
--single-image-bup <part name> Generate specified single image BUP, this must work with --bup.
--bup-type <type> ----- Generate specific type bootloader update payload(BUP), such as bl or kernel.
--multi-spec----------- Enable support for building multi-spec BUP.
--clean-up------------- Clean up BUP buffer when multi-spec is enabled.
--usb-instance <id> --- Specify the USB instance to connect to;
<id> = USB port path (e.g. 3-14).
--no-root-check ------- Typical usage of this script require root permissions.
Pass this option to allow running the script as a
regular user, in which case only specific combinations
of command-line options will be functional.
--uefi-keys <keys_conf> Specify UEFI keys configuration file.
--rcm-boot ------------ Do RCM boot instead of physically flashing the board.
--sign ---------------- Sign images and store them under "bootloader/signed"
directory. The board will not be physically flashed.
--image --------------- Specify the image to be written into board.
--boot-chain-flash <c> Flash only a specific boot chain (ex. "A, "B", "all").
Defaults to "all", inputs are case insensitive.
Not suitable for production.
--boot-chain-select <c> Specify booting chain (ex. "A" or "B") after the board is flashed.
Defaults to "A", inputs are case insensitive.
--pv-crt -------------- The certificate for the key that is used to sign cpu_bootloader
--with-systemimg ------ Generate system images also when using -k option
--pv-enc <enc_key>----- The encryption key that is used to encrypt cpu_bootloader.
--uefi-enc <uefi_enc_key> Key file (0x23: 32-byte) to encrypt UEFI payloads
--uda-dir-------------- Directory to store user data that will be encrypted in UDA partition.
--generic-passphrase -- Use generic passphrase for disk encryption.
--disable-random-iv --- Disable generation of random IV, SALT1, SALT2 and DERSTR.
--read-info ----------- Read and display board related info, fuse info (based on fuse_t234.xml),
and EEPROM content.
--reuse-uuid --------- Reuse uuid which is already generated first time.
--qspi-only --------- Flash QSPI device only.
--passthrough -------- Additional options to passthrough the tegraflash command
--read-ramcode ------- Generate read_ramcode script in the flashcmd.txt command script.
--gen-read-eeprom ---- Generate read_eeprom script with all signed binaries. User later can run
read_eeprom.sh from host to dump EEPROM content on a target device after
putting the target device in RCM mode. Since all binaries are signed already,
there is no key needed even the device has PKC fuse burned.
--hsm ---------------- Enable HSM for signing (and encrypting) images. This option must be used with
-u option (image signing). -v or --pv-enc is optional (image encryption).
--debug -------------- Enable debug mode, and enable '--keep' option to tegraflash.py
For now, the debug mode will enable saving of unencrypted and unsigned files
for UEFI encryption/signing debugging.
--gen-systemimg-only - Generate system.img only, program then exits.
Error: failed to generate images
Cleaning up...
我们自己设计的板子,估计是用下面的命令
sudo EXT_NUM_SECTORS=239075328 SKIP_EEPROM_CHECK=1 UNIFIED_FLASH=1 ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --external-device nvme1n1 -c tools/kernel_flash/flash_l4t_t264_nvme_rootfs_ab.xml --showlogs --erase-all p3834-0008-as-p5767-0000-nvme nvme1n1p1
p3834-0008-as-p5767-0000-p4071-0000-nvme.conf
hi:
我还想问下是不是 要用这个p3834-0008-as-p5767-0000-p4071-0000-nvme 编译一遍,然后再烧录?
I think so. Here’s the file and nr_cpus=8 mem=32G"; looks like the description of T3000 from the webpage for your picture above.
platform_emulation_overlay()
CMDLINE_ADD+=" nr_cpus=8 mem=32G";
OVERLAY_DTB_FILE+=",tegra264-p4071-0000+p3834-0008-as-p5767-0000.dtbo";
BPFDTB_FILE="tegra264-bpmp-3834-0008-as-5767-0000-4071-xxxx.dtb";
大神,这个问题解决了吗?我这边也遇到这个问题了,用p3834-0008-as-p5767-0000-p4071-0000-nvme这个配置也不行,和你不同的是,我用的是官方的AGX Thor 完整的一整套开发套件,核心板是T5000,目前跑的是R39.2.0版本SDK,设备进入Recovery模式下后进行的操作如下:
ubuntu@krinwave:/media/data/zhongzy/r39.2.1/Linux_for_Tegra$ sudo ./l4t_initrd_flash.sh p3834-0008-as-p5767-0000-nvme internal
[sudo] password for ubuntu:
./l4t_initrd_flash.sh: line 238: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
11:21:49.264 - Debug: Checking UFW status and NFS port rules…
11:21:49.314 - Debug: UFW is not active. NFS port is accessible.
11:21:49.315 - Debug: Checking VPN connections…
11:21:49.318 - Debug: IPSec service is not running.
11:21:49.319 - Debug: VPN routes none in tun|tap|ppp|vpn|gpd.
11:21:49.320 - Debug: No VPN connection detected.
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash p3834-0008-as-p5767-0000-nvme internal
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 49: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 50: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 52: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 53: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 54: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 55: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 56: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh: line 57: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.func: line 310: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
Run image gen script: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh --boot-chain-flash ALL --boot-chain-select A p3834-0008-as-p5767-0000-nvme internal
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh: line 467: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh: line 744: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/p3834-0008-as-p5767-0000-nvme.conf: No such file or directory
ADDITIONAL_DTB_OVERLAY=“” /media/data/zhongzy/r39.2.1/Linux_for_Tegra/flash.sh --no-flash --sign --boot-chain-flash ALL --boot-chain-select A p3834-0008-as-p5767-0000-nvme internal
Where,
target board: Valid target board name or ‘autodetect’
options:
-c ---------- Flash partition table config file.
-d ---------- device tree file.
-f --------- Path to flash application (tegraflash.py)
-i – key for disk encryption support.
-k ----- partition name or number specified in flash.cfg.
-l ------- cpu bootloader dtb file.
-m ------ MTS preboot such as mts_preboot_si.
-n --------- Static nfs network assignments
-o ---------- ODM data.
-u ------ PKC key or PKC keylist used for odm fused board.
-v ------ Secure Boot Key (SBK) key used for ODM fused board.
-w ---------- warm boot binary such as nvtbootwb0.bin
-x ---------- Tegra CHIPID.
-B ---------- BoardId.
-C ---------- Kernel commandline arguments.
WARNING:
is omitted.
-G -------- Read partition and save image to file.
-I ----------- initrd file. Null initrd is default.
-K ----------- Kernel image file such as zImage or Image.
-L ------- Bootloader such as cboot.bin or u-boot-dtb.bin.
-M --------- MTS boot file such as mts_si.
-N ---------- i.e. :/my/exported/nfs/rootfs.
-R ------- Sample rootfs directory.
-S ------------- Rootfs size in bytes. Valid only for internal
-T —The number of the sectors of the external storage device.
-U —The number of the sectors of the internal storage device.
–no-flash ------------ perform all steps except physically flashing the board.
–external-device------ Generate flash images for external devices
–sparseupdate--------- only flash partitions that have changed. Currently only support SPI flash memory
–no-systemimg -------- Do not create or re-create system.img.
–bup ----------------- Generate bootloader update payload(BUP).
–single-image-bup Generate specified single image BUP, this must work with --bup.
–bup-type ----- Generate specific type bootloader update payload(BUP), such as bl or kernel.
–multi-spec----------- Enable support for building multi-spec BUP.
–clean-up------------- Clean up BUP buffer when multi-spec is enabled.
–usb-instance — Specify the USB instance to connect to;
–no-root-check ------- Typical usage of this script require root permissions.
–uefi-keys <keys_conf> Specify UEFI keys configuration file.
–rcm-boot ------------ Do RCM boot instead of physically flashing the board.
–sign ---------------- Sign images and store them under “bootloader/signed”
–image --------------- Specify the image to be written into board.
–boot-chain-flash Flash only a specific boot chain (ex. "A, “B”, “all”).
Defaults to “all”, inputs are case insensitive.
–boot-chain-select Specify booting chain (ex. “A” or “B”) after the board is flashed.
Defaults to “A”, inputs are case insensitive.
–pv-crt -------------- The certificate for the key that is used to sign cpu_bootloader
–with-systemimg ------ Generate system images also when using -k option
–pv-enc <enc_key>----- The encryption key that is used to encrypt cpu_bootloader.
–uefi-enc <uefi_enc_key> Key file (0x23: 32-byte) to encrypt UEFI payloads
–uda-dir-------------- Directory to store user data that will be encrypted in UDA partition.
–generic-passphrase – Use generic passphrase for disk encryption.
–disable-random-iv — Disable generation of random IV, SALT1, SALT2 and DERSTR.
–read-info ----------- Read and display board related info, fuse info (based on fuse_t234.xml),
and EEPROM content.
–reuse-uuid --------- Reuse uuid which is already generated first time.
–qspi-only --------- Flash QSPI device only.
–passthrough -------- Additional options to passthrough the tegraflash command
–read-ramcode ------- Generate read_ramcode script in the flashcmd.txt command script.
–gen-read-eeprom ---- Generate read_eeprom script with all signed binaries. User later can run
–hsm ---------------- Enable HSM for signing (and encrypting) images. This option must be used with
–debug -------------- Enable debug mode, and enable ‘–keep’ option to tegraflash.py
–gen-systemimg-only - Generate system.img only, program then exits.
Cleaning up…
ubuntu@krinwave:/media/data/zhongzy/r39.2.1/Linux_for_Tegra$ sudo ./l4t_initrd_flash.sh p3834-0008-as-p5767-0000-p4071-0000-nvme internal
/media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash p3834-0008-as-p5767-0000-p4071-0000-nvme internal
Run image gen script: /media/data/zhongzy/r39.2.1/Linux_for_Tegra/tools/kernel_flash/l4t_create_images_for_kernel_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t264_nvme.xml --boot-chain-flash ALL --boot-chain-select A p3834-0008-as-p5767-0000-p4071-0000-nvme internal
ADDITIONAL_DTB_OVERLAY=“” /media/data/zhongzy/r39.2.1/Linux_for_Tegra/flash.sh --no-flash --sign --boot-chain-flash ALL --boot-chain-select A p3834-0008-as-p5767-0000-p4071-0000-nvme internal
L4T BSP Information:
R39 , REVISION: 2.1
User release: 0.0
Target Board Information:
Name: p3834-0008-as-p5767-0000-p4071-0000-nvme, Board Family: generic, SoC: Tegra 234,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
Error: The Actual SoC ID(0x23) mismatches intended p3834-0008-as-p5767-0000-p4071-0000-nvme SoC ID(0x26).
Cleaning up…
ubuntu@krinwave:/media/data/zhongzy/r39.2.1/Linux_for_Tegra$ lsusb
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 413c:301a Dell Computer Corp. Dell MS116 Optical Mouse
Bus 001 Device 005: ID 0955:7323 NVIDIA Corp. APX
Bus 001 Device 007: ID 1a86:7523 QinHeng Electronics CH340 serial converter
Bus 001 Device 078: ID 413c:2113 Dell Computer Corp. KB216 Wired Keyboard
Bus 001 Device 125: ID 0955:7026 NVIDIA Corp. APX
Bus 002 Device 002: ID 05e3:0612 Genesys Logic, Inc. Hub
Bus 002 Device 003: ID 0bda:0328 Realtek Semiconductor Corp. USB3.0-CRW
设备要么找不到模拟用的配置文件,要么设备ID匹配不上。
也请各路大神指导,官方人员看到也请解答一下,非常感谢。
I do not know if you must use boardctl as described below, but that is what is in this document.
https://docs.nvidia.com/jetson/archives/r39.2.1/DeveloperGuide/SD/PlatformPowerAndPerformance/JetsonThor.html#platform-emulation
To emulate the T3000 module by using the Jetson AGX Thor developer kit with this BSP, follow these steps:
Untar the Jetpack 7.2.1 bsp package:
tar xf ${L4T_RELEASE_PACKAGE}
sudo tar xpf ${SAMPLE_FS_PACKAGE} -C Linux_for_Tegra/rootfs/
cd Linux_for_Tegra/
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./apply_binaries.sh --openrm
Put the Jetson AGX Thor developer kit into recovery mode:
./tools/board_automation/boardctl -t thor-jetson recovery
Flash the board using the corrected T3000 emulation flash configuration
Reset the board:
./tools/board_automation/boardctl -t thor-jetson reset
非常感谢您的答疑,我先前就是像你回答的那样操作的,
现在问题已解决,问题出现在烧录系统的Ubuntu主机端,除了连接了进入了Recovery模式的Thor设备外,同时该主机也连接了另一台同样进入了Recovery模式的Orin NX设备,匹配设备ID时可能错误地用Orin NX设备id去匹配了,导致烧录失败。
现在有个疑问,既然每个型号的PID都不一样,NVIDIA官方是否可以在多型号设备烧录时自动匹配设备ID ?如果可以实现的话,建议纳入官方的优化项。
This looks like it could help your case.
Linux_for_Tegra$ grep -A58 “findadev(” nvautoflash.sh
nvmassfusegen.sh has a copy of this function too.
findadev()
# Splitting this line is too dangerous.
local devpaths=($(find /sys/bus/usb/devices/usb*/ -name devnum -print0 | {
local fn_devnum;
local found=();
while read -r -d "" fn_devnum; do
local dir;
local vendor;
local product;
local busnum;
local devpath;
local fn_busnum;
local fn_devpath;
dir="$(dirname "${fn_devnum}")";
vendor="$(cat "${dir}/idVendor")";
if [ "${vendor}" != "0955" ]; then
continue
fi;
product="$(cat "${dir}/idProduct")";
case "${product}" in
"7023") ;; # AGX Orin
"7223") ;; # SKU4 Orin
"7323") ;; # Orin NX 16GB
"7423") ;; # Orin NX 8GB
"7523") ;; # Orin Nano 8GB
"7623") ;; # Orin Nano 4GB
"7026") ;; # AGX Thor
"7226") ;; # AGX Thor T4000
"7326") ;; # AGX Thor prod fused
*) continue ;;
esac
fn_busnum="${dir}/busnum";
if [ ! -f "${fn_busnum}" ]; then
continue;
fi;
fn_devpath="${dir}/devpath";
if [ ! -f "${fn_devpath}" ]; then
continue;
fi;
# Only include devices for which the DEVNAME exists. In a container
# environment, the DEVNAME for this device may not have been mapped
# in, which is the case for when a device is in recovery mode, but
# that device is not mapped into the current container.
devname=$(udevadm info --query=property "$dir" | grep DEVNAME | cut -d= -f2)
if [ ! -e "$devname" ]; then
continue
fi
busnum="$(cat "${fn_busnum}")";
devpath="$(cat "${fn_devpath}")";
found+=("${busnum}-${devpath}");
done;
echo "${found[@]}";
echo "${#devpaths[@]}";
Or
sudo grep -ir idProduct --include=*.sh --exclude-dir=rootfs --exclude-dir=source |sort
nvautoflash.sh: product="$(cat "${dir}/idProduct")";
nvmassfusegen.sh: product="$(cat "${dir}/idProduct")";
nvmassfusegen.sh: product="\\\$(cat "\\\${dir}/idProduct")"
nvsdkmanager_flash.sh: for f in /sys/bus/usb/devices/*/idProduct; do
tools/kernel_flash/initrd_flash/nv_enable_remote.sh: echo 0x7035 > idProduct
tools/kernel_flash/initrd_flash/nv_enable_remote.sh: echo 0x7100 > /sys/kernel/config/usb_gadget/l4t/idProduct
tools/kernel_flash/initrd_flash/nv_enable_remote.sh: # If this script is modified outside NVIDIA, the idVendor and idProduct values
tools/kernel_flash/l4t_initrd_flash_internal.sh:# respectively, vendor, model, idVendor, idProduct, and serial.
tools/kernel_flash/l4t_initrd_flash.sh: product="$(cat "${dir}/idProduct")"
