R39.2 common apt repo: Packages index is newer than the signed Release — apt update fails with "File has unexpected size"
Environment: Jetson AGX Orin Developer Kit 32GB, flashed with JetPack 7.2.0 / L4T r39.2.0.
sudo apt update fails on the r39.2 common repo:
Err:8 https://repo.download.nvidia.com/jetson/common r39.2/main arm64 Packages
File has unexpected size (63810 != 63578). Mirror sync in progress?
Hashes of expected file:
  • Filesize:63578
  • SHA256:db1134087a5927b7ecb107354f0a112b392b50f3ed47016c5ecf46204c9d005b
    Release file created at: Wed, 12 Aug 2026 01:53:33 +0000
The som and ffmpeg suites for r39.2 fetch fine — only common fails.
Packages.gz (arm64) has last-modified Fri, 04 Sep 2026 15:04:44 GMT and content-length 63810, and the index contains nvidia-jetpack 7.2.1-b49. The Release/InRelease is dated Wed, 12 Aug 2026 01:53:33 UTC and still advertises Packages.gz at 63578 bytes (SHA256 db113408…).
It looks like the Packages index was regenerated on Sep 4 without re-issuing the signed Release, so apt rejects the index and no client of the r39.2 common repo can run apt update.
Using SDK Manager to install components runs into the same error.
Could you refresh/re-sign the Release (InRelease) for the r39.2 common suite so it matches the current Packages index? I’m happy to provide any additional logs.
Please try the script and see if the error still shows up:
Making sure you're not a bot!
@DaneLLL
Please see following picture, I got “Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r39.2/main/binary-arm64/Packages.gz File has unexpected size (63810 != 63578). Mirror sync in progress? [IP: 23.211.113.18 443]”, when I trying to run the “./install-jetpack-keep-bsp.sh”
I’m not a bot. I’ve been a member of this forum for years.
I get the same error with the script:
==> installed L4T build : 39.2.0-20260601141651
==> nv_tegra_release : # R39 (release), REVISION: 2.0, GCID: 45755727, BOARD: generic, EABI: aarch64, DATE: Mon Jun 1 09:28:48 PM UTC 2026
==> refreshing APT metadata
E: Failed to fetch https://repo.download.nvidia.com/jetson/common/dists/r39.2/main/binary-arm64/Packages.gz File has unexpected size (63810 != 63578). Mirror sync in progress? [IP: 58.27.5.89 443]
  • Filesize:63578 [weak]
  • SHA1:78f891796f1e8bbd794db79c6f991a6027fcab73 [weak]
  • MD5Sum:d20150ea99a48753076b4b69062ed471 [weak]
    E: Some index files failed to download. They have been ignored, or old ones used instead.
We set up AGX Orin developer kit in Jetpack 7.2 r39.2 and run the commands successfully:
$ sudo ./install-jetpack-keep-bsp.sh
$ sudo apt-cache policy nvidia-jetpack
nvidia-jetpack:
  Installed: 7.2-b187
  Candidate: 7.2-b187
  Version table:
     7.2.1-b49 600
        600 https://repo.download.nvidia.com/jetson/common r39.2/main arm64 Packages
 *** 7.2-b187 900
        100 /var/lib/dpkg/status
     7.2-b184 600
$ head -1 /etc/nv_tegra_release
$ sudo apt update
[sudo] password for nvidia:
Hit:1 https://repo.download.nvidia.com/jetson/common r39.2 InRelease
Hit:2 https://repo.download.nvidia.com/jetson/som r39.2 InRelease
Hit:3 https://repo.download.nvidia.com/jetson/ffmpeg r39.2 InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports noble InRelease
Get:5 http://ports.ubuntu.com/ubuntu-ports noble-updates InRelease [126 kB]
Hit:6 http://ports.ubuntu.com/ubuntu-ports noble-backports InRelease
Hit:7 http://ports.ubuntu.com/ubuntu-ports noble-security InRelease
Get:8 http://ports.ubuntu.com/ubuntu-ports noble-updates/main arm64 Packages [1,317 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports noble-updates/universe arm64 Packages [1,731 kB]
Fetched 3,174 kB in 8s (396 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
358 packages can be upgraded. Run 'apt list --upgradable' to see them.
Don’t hit the issue you are seeing. Please check and share the full steps to replicate the issue. We can then follow the steps to replicate it and check.
Dear @DaneLLL
I think your team fixed the problem.
I can’t reproduce the problem I faced yesterday.
Everything works well now, many thanks.
