I am planning to set up cuBB and noticed that the R750 server is recommended in the manual. However, our purchasing team informed me that the R750 has been discontinued, and only the R760 is available.
Can I use the R760 instead?
Thank you.
Thank you.
Hi @namikim
Welcome and thank you for reaching out.
It should be good to run cuBB on R760 assuming you use A100/H100 GPU and Bluefield3 for FH. We do not expect to achieve compatible capacity achieved on R750 as described in Manual. On R750, we use the converged card with build-in pcie switch for GPU and NIC.
Thank you for your response.
To clarify, do you mean that even though the maximum speed might not be achieved, I can still use the following combinations?
Thank you.
Yes, you can use both combinations and expect to have lower performance w/ combination #1 than with combination #2.
