I am trying to implement Radix Sort in CUDA, but I am encountered with a strange problem. My code gives corect solution upto the point where the hardware can run all threads as a single warp. For example if each SIMD core has 32 SMs then I get correct answer for 32 but as soon as I exceed that value the solution is incorrect. Here is my code
#include <stdio.h>
#include <cuda.h>
#include <cuda_runtime.h>
#include <driver_functions.h>
#include <thrust/scan.h>
#include <thrust/extrema.h>
#include <thrust/device_ptr.h>
#include <thrust/device_malloc.h>
#include <thrust/device_free.h>
#include <time.h>
#include <stdlib.h>
#include "CycleTimer.h"
#define SIZE 8192
#define THREADSIZE 64
#define BLOCKSIZE ((SIZE-1)/THREADSIZE + 1)
#define RADIX 10
__global__ void copyKernel(int * inArray, int * semiSortArray, int arrayLength){
int index = blockIdx.x * blockDim.x + threadIdx.x;
if(index < arrayLength){
inArray[index] = semiSortArray[index];
__global__ void histogramKernel(int * inArray, int * outArray, int * radixArray, int arrayLength, int significantDigit){
__shared__ int inArrayShared[THREADSIZE];
__shared__ int outArrayShared[RADIX];
__shared__ int radixArrayShared[THREADSIZE];
int thread = threadIdx.x;
int blockIndex = blockIdx.x * RADIX;
int radix;
int arrayElement;
int i;
if(thread == 0){
for(i =0; i < RADIX; i ++){
outArrayShared[i] = 0;
inArrayShared[thread] = inArray[index];
__syncthreads();
arrayElement = inArrayShared[thread];
radix = ((arrayElement/significantDigit) % 10);
radixArrayShared[thread] = radix;
atomicAdd(&outArrayShared[radix], 1);
radixArray[index] = radixArrayShared[thread];
if(thread == 0){
outArray[blockIndex + i] = outArrayShared[i];
__global__ void combineBucket(int * blockBucketArray, int * bucketArray){
__shared__ int bucketArrayShared[RADIX];
int i;
bucketArrayShared[index] = 0;
for(i = index; i < RADIX*BLOCKSIZE; i=i+RADIX){
atomicAdd(&bucketArrayShared[index], blockBucketArray[i]);
bucketArray[index] = bucketArrayShared[index];
__global__ void indexArrayKernel(int * radixArray, int * bucketArray, int * indexArray, int arrayLength, int significantDigit){
int i;
int radix;
int pocket;
if(index < RADIX){
for(i = 0; i < arrayLength; i++){
radix = radixArray[arrayLength -i -1];
if(radix == index){
pocket = --bucketArray[radix];
indexArray[arrayLength -i -1] = pocket;
__global__ void semiSortKernel(int * inArray, int * outArray, int* indexArray, int arrayLength, int significantDigit){
int arrayElement;
int arrayIndex;
arrayElement = inArray[index];
arrayIndex = indexArray[index];
outArray[arrayIndex] = arrayElement;
void printArray(int * array, int size){
int i;
printf("[ ");
for (i = 0; i < size; i++)
printf("%d ", array[i]);
printf("]\n");
int findLargestNum(int * array, int size){
int i;
int largestNum = -1;
for(i = 0; i < size; i++){
if(array[i] > largestNum)
largestNum = array[i];
return largestNum;
void cudaScanThrust(int* inarray, int arr_length, int* resultarray) {
int length = arr_length;
thrust::device_ptr<int> d_input = thrust::device_malloc<int>(length);
thrust::device_ptr<int> d_output = thrust::device_malloc<int>(length);
cudaMemcpy(d_input.get(), inarray, length * sizeof(int), cudaMemcpyHostToDevice);
thrust::inclusive_scan(d_input, d_input + length, d_output);
cudaThreadSynchronize();
cudaMemcpy(resultarray, d_output.get(), length * sizeof(int), cudaMemcpyDeviceToHost);
thrust::device_free(d_input);
thrust::device_free(d_output);
void radixSort(int * array, int size){
double startTime;
double endTime;
double duration;
int significantDigit = 1;
int threadCount;
int blockCount;
threadCount = THREADSIZE;
blockCount = BLOCKSIZE;;
int * outputArray;
int * inputArray;
int * radixArray;
int * bucketArray;
int * indexArray;
int * semiSortArray;
int * blockBucketArray;
cudaMalloc((void **)& inputArray, sizeof(int)*size);
cudaMalloc((void **)& indexArray, sizeof(int)*size);
cudaMalloc((void **)& radixArray, sizeof(int)*size);
cudaMalloc((void **)& outputArray, sizeof(int)*size);
cudaMalloc((void **)& semiSortArray, sizeof(int)*size);
cudaMalloc((void **)& bucketArray, sizeof(int)*RADIX);
cudaMalloc((void **)& blockBucketArray, sizeof(int)*RADIX*BLOCKSIZE);
cudaMemcpy(inputArray, array, sizeof(int)*size, cudaMemcpyHostToDevice);
int largestNum;
thrust::device_ptr<int>d_in = thrust::device_pointer_cast(inputArray);
thrust::device_ptr<int>d_out;
d_out = thrust::max_element(d_in, d_in + size);
largestNum = *d_out;
printf("\tLargestNumThrust : %d\n", largestNum);
startTime = CycleTimer::currentSeconds();
while (largestNum / significantDigit > 0){
int bucket[RADIX] = { 0 };
cudaMemcpy(bucketArray, bucket, sizeof(int)*RADIX, cudaMemcpyHostToDevice);
histogramKernel<<<blockCount, threadCount>>>(inputArray, blockBucketArray, radixArray, size, significantDigit);
combineBucket<<<1, RADIX>>>(blockBucketArray,bucketArray);
cudaScanThrust(bucketArray, RADIX, bucketArray);
indexArrayKernel<<<blockCount, threadCount>>>(radixArray, bucketArray, indexArray, size, significantDigit);
semiSortKernel<<<blockCount, threadCount>>>(inputArray, semiSortArray, indexArray, size, significantDigit);
copyKernel<<<blockCount, threadCount>>>(inputArray, semiSortArray, size);
significantDigit *= RADIX;
endTime = CycleTimer::currentSeconds();
duration = endTime - startTime;
cudaMemcpy(array, semiSortArray, sizeof(int)*size, cudaMemcpyDeviceToHost);
printf("Duration : %.3f ms\n", 1000.f * duration);
cudaFree(inputArray);
cudaFree(indexArray);
cudaFree(radixArray);
cudaFree(bucketArray);
cudaFree(blockBucketArray);
cudaFree(outputArray);
cudaFree(semiSortArray);
int main(){
printf("\n\nRunning Radix Sort Example in C!\n");
printf("----------------------------------\n");
int size = SIZE;
int* array;
int i;
int list;
srand(time(NULL));
for(i =0; i < size; i++){
list[i] = SIZE -i;
array = &list[0];
printf("\nUnsorted List: ");
printArray(array, size);
radixSort(array, size);
printf("\nSorted List:");
printf("\n");
return 0;
